| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Hyperblue BRZ
Wheel noob here, have a few questions!
I'm sure these questions have been answered various times so forgive me!
Q1: Does center bore measurements matter? The stock cb is 56.1mm and the aftermarket wheels I am looking at has the diameter of 73mm. Will this still fit? (Wheels in question: http://www.wheeldude.com/catalog/pro...oducts_id=6869 ) Q2: What is offset? I had this explained to me by a friend but I still can't quite grasp the concept. I.E. What's the difference between a large offset (40mm) and a smaller offset (20mm). Thanks for helping me out guys!
#2 |
Loading...████████] 99%
Drives: #0517
center bore matters in that you can't fit a wheel with a SMALLER bore onto your car if it is smaller than the hub. for your example, you can get centering rings to fill in that spacing, though some will say they are not necessary. up to you.
in a broad sense...higher offset=wheel more inset in wheel well, lower offset=wheel will stick out more. to be more specific, the offset is the distance measured from the center of the wheel. use the wheel directory/gallery to see what fitment works for your own goals here: http://www.ft86club.com/forums/showthread.php?t=7535 here's a photo to help you picture it:
| The Following User Says Thank You to asdf For This Useful Post: | Strife (07-21-2016) |
#3 |
@asdf Thanks for the help, one more question haha! For wheel spacers should the center bore be the same diameter of stock specs (56.1) then a rim with a cb of say 71 should fit perfectly fine on the spacer?
#4 | |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | Strife (07-22-2016) |
| Few Questions for a Noob | Falltima | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-02-2015 10:47 PM |
| Car noob questions | Aenv | BRZ First-Gen (2012+) — General Topics | 14 | 12-17-2014 04:42 PM |
| noob questions | theflathead | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-13-2014 08:57 AM |
| Noob wheel questions | pornflakes | AUSTRALIA | 11 | 05-31-2013 01:43 AM |
| Noob Questions | travace | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 11-04-2012 11:37 PM |
