Old 06-20-2012, 10:07 PM   #113
OrbitalEllipses
Drives: Attitude
Originally Posted by Draco-REX View Post
If they want teams to start using the WRX in the WRC again, they have to make it smaller. Current WRC cars are build on the Super2000 rules with cars the size of the Ford Fiesta. The current outgoing WRX is way too big and heavy to be competitive in the WRC.
I'm thinking the cries for a small, turbo, AWD coupe will be answered with the new clean-sheet WRX
I'm of the same opinion, which is why people need to stop bitching about an AWD BRZ.
Old 06-21-2012, 10:14 AM   #114
WillieRX
Mountain Road Recon
Drives: '06 Subaru WRX TR
I figured that AWD will not come to this car, and I don't expect it to. However, I think F/I will very much benefit the car, especially to us people at 6,000+ ft (8,000+ ft regularly for me). NA engines, especially 4-cylinder, lose alot of power up here. A good way to fix that problem is forced induction. So I am all for a F/I BRZ down the road. I don't think a 250HP NA engine will mitigate the altitude issue.
I do think, if/when they make a upper performance version of this car, they should at "least" attempt to get it around the 10-11 lbs / 1 HP ratio.
WillieRX is offline   Reply With Quote
Old 06-21-2012, 10:44 AM   #115
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
True, the drag on the engine is much higher with a supercharger. But the trade off is worth it in my opinion.
I own an STI and a WRX. The STI is just stage 1, power-wise, but the WRX is a full stage 2. With the WRX's little donut-sized turbo, it spools nearly instantly. But it still doesn't have the throttle response that a N/A engine does. As powerful as the STI is, it feels downright sleepy compared to the BRZ.
I think blunting the engine's response would be counter-productive to the BRZ's chassis.
They need to keep it normally aspirated or go with twin turbos with each turbo have twin scrolls. But we talking mad expensive!
Just give ups 250HP and 185 ft/lbs torque NA and we are good. They could also easily shave off 100 pounds from this car too..
tripjammer is offline   Reply With Quote
Old 06-21-2012, 02:55 PM   #116
Zadkiel
Drives: CBS BRZ Limited 6MT
It'd require a lot of engine work to get FI though. The FA20's compression is up in the 12's right?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 06-21-2012, 03:03 PM   #117
WillieRX
Mountain Road Recon
Yeah, that high compression would pose a problem if just a S/C or T/C was thrown on as-is. I imagine if TRD/SPT/STi (whoever the factory developer will be) were to smack on a S/C on the engine as it stands, it probably would be low boost, even then it would be very beneficial at high altitude.
But for higher boost applications, my guess is methods to lowering compression such as different pistons, different combustion chamber setup etc...
Old 06-21-2012, 03:23 PM   #118
SnapOv3st3r
Drives: 400whp Scion tC
No it would not require a lot of engine work. Not if you run low boost. If detonation is still an issue, and you don't want to tear into the block, then you would tune it with Methanol Injection to keep the temps down. It should not require a lot of boost anyway due to the compression. Minimal boost should break the 250whp+ range easily.
SnapOv3st3r is offline   Reply With Quote
Old 06-21-2012, 05:37 PM   #119
Zadkiel
But then why even take the risk when intake and exhaust tuning from the aftermarket has already shown 7-15hp gains? Tune the intake and exhaust, give the ECU with a more aggressive tune, and find other areas to gather some more hp and you'll have 250hp easily. Then you don't have to worry about the extra compression from the turbo.
Couple that with even more weight savings and you'd have a mid-high 5 second 0-60. That's not even counting a more aggressive suspension setup, wider tires, improved brakes, and stickier rubber. Then you A. Eliminate the need for a turbo that would increase delay in response and B. retain the overall balance of the car.
They wouldn't need to engineer new mounting points for new components and they'd be able to offer it without charging an insane amount. I'd say about $2000-$3000 over the Limited.
Old 06-22-2012, 08:18 AM   #120
SnapOv3st3r
Risk is how you learn. Play it safe and you get left behind is how I see it. Pioneers are ones who take risk....Adding Methanol injection to the tune may be considered a risk to some, but it's a very well calculated one. Especially if it's done by a well respected and reputable shop who knows what they are doing. Not just blow schmoe at Lubes R Us.
7-15 vs 100....that could be a possible reason, just saying. A lot of people are talking about throttle response of N/A and what not. That stance is very valid....for "track" people. I don't think the vast majority of people on here talking about it though, are real hardcore track junkies. And if you don't plan on taking this to the track quite often and you just want that extra kick out of your street car, then throttle response takes more of a back seat and power is more of a desirable factor.
Sorry, but not everyone wants to build an N/A machine this is a given. It is the inevitable that someone will want to do 400, 500, 600+ whp out of an FR-S/BRZ and you are not getting there the N/A route, nor are you going to be faster N/A than a 500whp F/I version. Maybe if you did an N/A build + tuned on a 100shot then you would have power and throttle response. But again...throttle isn't going to be that much of a factor on a street car.
The whole turbo setup throwing off balance doesn't hold any weight to me. The benefits drastically out weigh that extra what 50lbs you added.
There are going to be guys slamming it to the ground with heavy but nice looking wheels, audio systems that weigh way more than a turbo setup and the like, so a turbo setup is welcomed for the sake of R&D from a performance stand point. Besides, there is already a turbo setup being developed, so it will be nice to see what power can be made.
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
Dadhawk (06-22-2012)
Old 06-22-2012, 08:57 AM   #121
yuli8466
Drives: MX5
Originally Posted by ngabdala View Post
what you want is a high-tuned legacy gt ( turbo, awd, big power)
yuli8466 is offline   Reply With Quote
Old 06-22-2012, 09:00 AM   #122
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
wont EVER happen from factory.
Subaru will keep the FI for the WRX and toyota is already working on the bigger brother for the 86, probably FI(fingers crossed for Supra!)
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 06-22-2012, 10:17 AM   #123
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Ill quote you again when you are wrong.
chulooz is offline   Reply With Quote
Old 06-22-2012, 01:02 PM   #124
Zadkiel
B was in reference to the AWD throwing off the weight. I think you're confused though. I'm talking about FROM THE FACTORY. The aftermarket can do whatever the heck they want to it. A factory built BRZ STi would be NA in the realm of 250hp, lose about 100lbs-200lbs, bigger brakes, better tires(wider, stickier), and probably have the suspension tuned more aggressively on a FACTORY BUILT BRZ Sti.
Old 06-22-2012, 06:38 PM   #125
SnapOv3st3r
If you are talking about from the factory, then why speak of compression? You mentioned high compression. If they were going to make a factory F/I BRZ/FR-S then they would lower the compression naturally. So, when you spoke of the high compression and how boost would be require a lot of motor work...I naturally thought you were talking about aftermarket. Cause a OEM would not make a high compression + boosted car. Not this day and age.
Old 06-22-2012, 06:50 PM   #126
OrbitalEllipses
Drives: Attitude
A factory STI version would probably gain weight...you guys do know the (Impreza) STI weighs more than the WRX?
[Norcal] *Works is looking for an R&D car Lonewolf Southern California 8 06-09-2012 04:38 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Who here works for Toyota and/or Scion? PAImportTuner Off-Topic Lounge [WARNING: NO POLITICS] 11 12-28-2011 12:38 AM
Who works on your vehicle? Midship Runabout Other Vehicles & General Automotive Discussions 23 09-25-2011 02:57 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
