Old 05-20-2016, 08:37 PM   #309
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by socal_48 View Post
Got it fixed, downloaded the latest firmware and updated the system. Everything works as it should.
Awesome, glad it was easy!
-Josh
Old 05-23-2016, 04:53 PM   #310
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Originally Posted by Yoshoobaroo View Post
Is there any word on when a lollipop version of the custom fit one will be available? (the one without the gaps on the side)
-Josh
I'd love some info on this too , been holding off on purchasing the current Android 4.4 Toyota Fit model.
shadoken is offline   Reply With Quote
Old 05-23-2016, 06:11 PM   #311
Yoshoobaroo
TRACKBREAD
Seems they're not too far away: http://www.ft86club.com/forums/showthread.php?t=106005
-Josh
Old 05-31-2016, 11:28 AM   #312
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
FYI http://forum.xda-developers.com/show....php?t=3385522
Rican_D is offline   Reply With Quote
Old 06-24-2016, 03:12 AM   #313
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I'm really on the fence for the Joying Android 5.1 Universal 7" : https://www.carjoying.com/android-5-...rt-revers.html
People who have the 5.1.1 Joying Universal HUs..
1) Is there any noticeable bugs or complaints you have? Is there an off the shelf spacer that can fill the gap on left and right?
2) Is the RK3188 enough power to not lag? especially when running google maps while playing music? I am also considering the Octacore InDashNet due to performance and looks but it seems too new and less support.
3) What output connections are available on this? It looks like there is an SD card in the front and you can use two adapters to use the factory AUX and USB locations?
After parsing through a couple of pages I think I got an idea of the process, can someone help me confirm the following is all I need?
1) Purchase 2016 5.1.1 Universal 7" double din
2) Purchase Joying Aftermarket Toyota Harness
3) Purchase Toyota USB cable adapter to plug into original USB slot.
4) Purchase Antenna Adapter for Radio
5) Sand/file away some edges to make the OEM brackets to fit.
6) Remove pin 8 and move to pin 9 (amp).
7) Everything else is plug and play?
And lastly take a visit to OEM Audio+ to get my DSP retuned for this guy?? Hopefully that's it as it sounds pretty simple.
Thank you!
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
malubawla (06-24-2016)
Old 06-25-2016, 08:35 AM   #314
Ketchum88
Ketchum88's Avatar
Drives: 2013 FR-S Hot Lava
Thank you!
I will say that minus the screen resolution and size most of these units have the same internal specs regarding hardware. Honestly I would wait for the Toyota universal unit to come out because it just looks stock.
Ketchum88 is offline   Reply With Quote
Old 06-28-2016, 03:02 AM   #315
l0aded
Addicted
l0aded's Avatar
Yeah after doing more research that is what I will be doing. As of now it does not look like ANY manufacturer has one for Toyota (200mm x 100mm panel) with Android 5.1+
Old 07-07-2016, 03:02 PM   #316
XtremeMaC
Drives: Asphalt Grey FR-S
Do you have such a rumor for a Toyota Universal unit? Do you know a time frame?
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 07-08-2016, 11:46 AM   #317
Ketchum88
Ketchum88's Avatar
No idea, there is a guy that is a rep for Joying USA that has an account on here and has posted a few times in this thread you may want to try asking him for an update.
Old 07-16-2016, 08:47 AM   #318
exE36M3
Umm.... you guys see this on Amazon? It's a unit with Android 5.1.
Description says it fits the GT86.
https://www.amazon.com/Android-Lolli...android+toyota
exE36M3 is offline   Reply With Quote
The Following User Says Thank You to exE36M3 For This Useful Post:
Yoshoobaroo (07-16-2016)
Old 07-16-2016, 12:20 PM   #319
Rican_D
Rican_D's Avatar
Must mean they have the update for the HU already.
Old 07-18-2016, 11:06 AM   #320
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
I don't see anything on the Joying website about the supposed unit. Not sure what's up with that...
eggncheese is offline   Reply With Quote
Old 07-20-2016, 03:28 PM   #321
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Looks like its up now.
https://www.carjoying.com/android-5-...n-dash-ca.html
Anyone know Where do I buy so that I get US warranty? The Amazon site? Its much cheaper here tho.
Old 07-21-2016, 03:33 AM   #322
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Originally Posted by doctorman View Post
JOYING-USA
Hey Guys,
I am authorized repair center and seller of Joying Head units in New York USA,
Units bought through me get USA warranty.
If there are any question I will try to answer them.
Hey where do we buy this headunit from to get US warranty?
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 01:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 12:55 PM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 12:57 PM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 03:42 AM
