| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2015 White BRZ MT
Is aftermarket Fan and Radiator worth it?
Hi guys,
I'm not too savvy with the technicals, so I'd love to hear your opinions about buying an aftermarket radiator and fans. My practically new BRZ just had an overheating issue, so maybe I am just being paranoid - but I'd like to explore options for cooling my engine better. How useful would an aftermarket radiator be? I've head that an electric fan can be very helpful if replacing an engine driven fan. Is the stock fan engine driven? Will installing either of these be an issue when the NE winter hits? Thanks everybody for your suggestions! |
#2 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Why did your BRZ overheat? What happened?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#3 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
as shiumai said, getting to the bottom of why it overheated in the first place should be step one. Did your temp needle actually go all the way to the top or did you use something like torque to see the temp increase?
We'll help you work through this, but we're gonna need to know what you are doing to cause it to overheat so that we know what course of action to recommend.
#4 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Answers are in red |
#5 |
Drives: ...Cars...
I have tracked my car all over the Southeast in blistering hot temps and never had an issue with the OEM Cooling system in the last year of use.
#6 |
Senior Misanthrope
Something is wrong, and you should talk to the dealership. I've done 30 minute track sessions in 98* ambient with stock radiator and fans and never had an issue.
#7 |
Thanks for all your replies. To clarify, the overheating was due to a head gasket leak which is being serviced at the moment.
I doubt that improving the stock cooling system will prevent this from happening again, but I am just traumatized from seeing my new cars temp gage rise haha. |
#8 | |
Drives: 2005 Toyota Camry
A head gasket failure has nothing to do with the cooling system unless you have a leak somewhere that contributed to overheating or warped cylinder heads. Upgrading your cooling system bc of a head gasket leak solves nothing in the long run, and is like putting out a house fire by building another house on top of the existing fire. Your best bet is to go with an OE-style oil cooler (Forester DIY or Cusco) and call it a day, if you wanted better cooling. -alex |
#9 |
Drives: 2014 BRZ Limited
OEM is fine. Just service it as indicated in the service schedule. Your overheating issue was a manufacturing defect, and there was not really anything you could have done to prevent that. Aftermarket parts wouldn't have helped. The service techs will get you squared away.
I would still send off an oil sample a few thousand miles after they finish the work, just to be on the safe side. But I seriously doubt you have any reason to worry. If you do send off a sample, be sure to include an explanation of the work done for the oil analysis tech so they don't misinterpret the results. |
#10 |
*Some really cool title*
^ basically what he said. In this day and age it's almost unheard of to get cooling issues with an OEM system. The only way it would be plausible would be either A. you drove the car insanely hard for an insanely long time or B. you went FI and didn't install an intercooler. Basically the point is to not judge the stock cooling system based off a defect. I'm not saying a new fan or radiator would be useless, because they would certainly help, but you might as well spend money on things that are more needing of change, like tires, exterior stuff, etc.
#11 |
TRACKBREAD
#12 |
| The Following User Says Thank You to Silver Cervy For This Useful Post: | Yoshoobaroo (07-20-2016) |
| WTB: Aftermarket Radiator + upgraded axles | mkivalex | Canada Classifieds | 2 | 01-30-2016 06:22 PM |
| WTB: OEM Radiator, Radiator Fan Assembly, Airbox, Condenser, Washer Reservoir, Winjet | Xanatos | Want-To-Buy Requests | 1 | 01-05-2016 02:24 PM |
| Stock radiator + aftermarket Shroud to fit SPAL fans | jflogerzi | Forced Induction | 18 | 09-08-2014 11:55 PM |
| FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 15 | 05-27-2014 12:18 PM |
| Are aftermarket intakes worth it? | wbsrazzle | Engine, Exhaust, Transmission | 100 | 05-15-2013 02:51 PM |
