Old 07-17-2016, 10:59 PM   #281
zeal86
zeal86's Avatar
Drives:
I got around to modifying and installing my HKS air intake duct today...as mentioned earlier in this thread, the HKS instructions state the duct can be installed without modification... not the case though.
Anyways, this is how it turned out...
stencil made out of construction paper...
Lined out...
Minor adjustments...
Edges filed smooth and blended in with flat black paint.
Installed...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 07-18-2016, 04:55 AM   #282
Apex-Apex
Apex-Apex's Avatar
So a small review so far. The car feels pretty good and drives well at times. The biggest flaw to me with the sc kit is the HKS tune that comes with it. I'm running their e85 map and have been having some issues with it. At first I thought it was bad gas but I have been through 2 tanks of e85 and I'm starting to lean towards tuning issues. The two issues I've noticed is the delay the car has when tipping in throttle and the slight bogging you feel below 4k RPM. I'm going to be making an appointment with Evasive soon to get a retune but if I had known that I would need this, I would not have purchased the kit with their limited engine management.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following 2 Users Say Thank You to Apex-Apex For This Useful Post:
saj (07-18-2016), zeal86 (07-18-2016)
Old 07-19-2016, 05:42 AM   #283
blindfold
Drives: brz
Originally Posted by Apex-Apex View Post
Yes, if you run their e85 tune, you will need Deathswerke 700cc.
can this upgraded pulley be used with 93octane gas? How many psi with smaller pulley, thank you sir.
blindfold is offline   Reply With Quote
Old 07-19-2016, 11:18 AM   #284
Grozniy
Drives: GT86
What's pulley ? 80 mm or 85 mm
Grozniy is offline   Reply With Quote
Old 07-19-2016, 01:58 PM   #285
Apex-Apex
Apex-Apex's Avatar
I'm not sure if it's safe but their 93 tune is meant with the larger pulley. From what I've read, the smaller pulley is 11.5 psi.
100mm for the smaller
IG: @apexapexapex
Old 07-19-2016, 02:03 PM   #286
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Exactly, both the HKS 91 and 93 tunes are tuned for the standard pulley (110mm).
Only the HKS E85 tune is tuned for the smaller (100mm) pulley. You can run the smaller pulley with 93 octane, or even 91, but you have to have the fuel and tune to support it. That's just not a solution HKS sells.
Torry@HKSUSA is offline   Reply With Quote
Old 07-19-2016, 10:10 PM   #287
blindfold
Drives: brz
so basically you could run the e85 set up (700cc+fuel pump) on 93octane, not exactly sure if the gains are adequate enough for such an upgrade
Old 07-19-2016, 10:42 PM   #288
blindfold
Drives: brz
installation is underway, I found out that with Koyo radiator, it pushes the charge pipe right against the crashbeam and it must be notched at least 10mm or so to get everything clear, maybe zeal86's way of using an after market smaller crashbeam is a better way since everything roughly occupies the same space
Old 07-24-2016, 08:39 PM   #289
sebastiansim
Drives: 2015 Crystal Black Silica Brz MT
Sorry if it's been stated before but I couldn't find it searching around, but is the flash editor being compatible for 2015+ models been sorted out yet?
sebastiansim is offline   Reply With Quote
Old 07-24-2016, 09:15 PM   #290
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Guys, I did a thing.... Haha
HuntingtonFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to HuntingtonFRS For This Useful Post:
Apex-Apex (07-24-2016), CxG (07-25-2016)
Old 07-25-2016, 08:44 AM   #291
Torry@HKSUSA
Drives: HKS
Yes! It works with all manual transmission ECU ID's 2013-2016.
Old 07-25-2016, 12:56 PM   #292
sebastiansim
Yessss! Thank you! Looks like im buying this kit next summer
Old 07-25-2016, 06:33 PM   #293
zeal86
zeal86's Avatar
Drives:
Some engine bay pics with my HKS GT supercharger v3 installed...
Old 07-25-2016, 07:40 PM   #294
HuntingtonFRS
What do you use to clean and shine the engine bay?
supercharger help... sosick Forced Induction 25 08-15-2013 11:02 PM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 06:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
