Old 07-19-2016, 01:10 PM   #1499
GT86Asia
Drives: 2016 BRZ
Originally Posted by Kodename47 View Post
- Keep an eye on the AFRs/fueling. It's likely that will change the MAF readings, by how much you'll have to test.
- It's unlikely that you're changing the amount of air that's going into the SC, so the pressure change inside the bay will be minimal/nothing.
- Make a heat shield under the intake, should help with IATs a little from heat from the radiator. The change in IATs is probably due to the flow of air through the filter more than anything else.
Yeah that was forseen by my tuners, and they told me I could not mess with the MAF sensor, so the sensor is exactly in the same place, i didn't touch that. The only thing I did was change the filter head. Everything else is eactly the same.
So i do not forsee any trouble with the AFR
GT86Asia is offline   Reply With Quote
Old 07-19-2016, 01:22 PM   #1500
Kodename47
Kodename47's Avatar
Drives: UK GT86
Still changes airflow over the sensor.....
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-19-2016, 01:25 PM   #1501
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I guess this is how I'm rationalizing all of this, haha. Anyone wanna pitch in?
True, if you did in fact increase the surface area and the flow, that would explain why your IATs are "reacting" faster, ie the hot/cold air is hitting your sensor (I believe the IATs are measured from the MAP) faster.
I would still check it. If you are in fact increasing the flow, your MAF readings, and therefore fueling etc, will be off.
All very good points. I would almost suggest you stick with the previous air filter and just extend it with an elbow to point it farther away from the headers and closer towards the hole where the snorkel used to be (kinda like the JRSC layout). If you do go that route, heat shielding would still help.
Old 07-19-2016, 02:19 PM   #1502
Sargy
Long Distance Driver
Sargy's Avatar
Time to turn this forum around a bit. Supercharger has been very impressive.
Some big changes coming soon. Hopefully a few weeks
[ame="https://www.youtube.com/watch?v=so5KE0i1rc0"]https://www.youtube.com/watch?v=so5KE0i1rc0[/ame]
Sargy is offline   Reply With Quote
Old 07-19-2016, 02:26 PM   #1503
Reamer
Drives: 2015 FRS
4th redlines ~90+ with a 4.88FD?
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
Old 07-19-2016, 02:44 PM   #1504
Sargy
Sargy's Avatar
If your redline is at 8K, you can very well see that happening, otherwise your just cracking 90mph
Old 07-19-2016, 02:47 PM   #1505
Reamer
Drives: 2015 FRS
Wow, that's super short gearing compared to stock. Which gear is closer to the 1:1 ratio after changing to the 4.88 FD? 5th? Or do you no longer have an OD gear? I might be misunderstanding this altogether since gearing is fairly new to me as far as how it interacts with the car.
Sent from my HTC 10 using Tapatalk
Old 07-19-2016, 02:50 PM   #1506
Sargy
Sargy's Avatar
5th
Old 07-19-2016, 05:50 PM   #1507
BigFatFlip
BigFatFlip's Avatar
So I finally got a chance to install and try out the Edelbrock specific "D-box" from Delicious tuning. Thanks @sales@delicioustuning.com for helping me out, always great customer service!
Install:
Quick and easy. I actually got the unit on a Fri and I was so excited I did the whole install on the parking lot after work
Didn't come with any instructions but very self explanatory, just unplug the "extension" harness that came with the SC kit and replace with the Dbox connectors (I believe its a couple TMAP's, a MAF and a MAP connector. I suggest you check out steps 160 & 161 on the Edelbrock install manual).
I actually left the existing harness in place and just zip-tied them nearby, just in case something happens to the box. Took me about 10 mins to route the lines and another 10 mins of meticulous zip-tying to keep the lines clean. It also came with some adhesive-backed velcro to attach it to the fuse box lid, which worked pretty nicely.
Impressions w/ Delicious tune
Everything just feels "smoother". Can't really feel any difference when driving around normally. I did, however, notice the engine sound and feel "smoother"(less harsh) at the upper rev range when doing a a couple red line pulls. Butt dyno hints that there's more power there, but its probably measurement error.
Also, prior to the D-box, I was actually getting some pretty bad "bucking", where I would violently jerk back and forth, like a newb stick-shift driver, when starting from stop or cruising at low speed (<25 mph). I felt that the car would initiate the "buck" and when I try to modulate the gas, it would jerk me forward, causing me to tap the gas again, further perpetuating the buck some more. About the only thing I can do to stop it is to let off the gas completely and clutch-in. This was part of the reason I got this unit as recommendation by Zach. Now, with the D-box, I think it has alleviated that quite a bit, with me being able to "modulate" it away once I feel it start, instead of having to clutch-in. Or its all placebo effect... and I just suck a driving... probably...
Impressions w/ CARB tune:
Pretty much the same impressions as above. Can't notice anything during regular driving, but much smoother on the upper rev range. Same butt dyno readings here. I never had the "bucking" issue with the CARB tune, but I think that was mostly due to the "softer" throttle mapping that it comes with.
Over all, I'm happy with my purchase. I wouldn't say its a "must buy" but definitely a "nice to have" for a smoother driving experience. Now, I need to stop staring at that spot where the other "D-box" (FlexFuel) should be...
Old 07-19-2016, 05:55 PM   #1508
Heist
Heist's Avatar
Drives: 10 Series
I've noticed I get the same bucking even though I started on the D box. It only happens when the engine is cold on e85 though. After about 2 minutes, all of the bucking goes away.
Sent from my Nexus 6P using Tapatalk
Heist is offline   Reply With Quote
Old 07-19-2016, 10:50 PM   #1509
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I also have 4.88s and e-85 with the Edelbrock Supercharger. But mine is the automatic. Couldn't be more happy. Pretty easy to get sub 5 second 0 to 60 times.
Can't say enough about Shawn Church.. Had a glitch in the tune and he figured it out with out even putting the car on the dyne. He's the best.
Lunatic is offline   Reply With Quote
Old 07-19-2016, 10:55 PM   #1510
Reamer
Drives: 2015 FRS
What is the gear limited speed for the AT with the 4.88?
Old 07-19-2016, 11:57 PM   #1511
Lunatic
Lunatic's Avatar
Sorry, I'm not sure what you mean.
Old 07-20-2016, 12:10 AM   #1512
Reamer
Drives: 2015 FRS
What's the top speed with the new FD?
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
