Old 07-18-2016, 06:09 AM   #1
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Help finding thread?
Can anyone direct me to threads where I can find info on stance (wheel fitment, coilovers, brake clearance, offset, camber..)..?
Not looking to slam but I do want to lower to improve overall cosmetics but not CRAZY low or a ton of camber you know? Just a clean look. No idea where to start or what wheel/tire brands to look at or what will even fit/ look nice and flush with fenders and such.. Also not sure if I need fender rolling or not..
BASICALLY I know nothing as to what to search for. All I know is what I think looks nice ¯\_(ツ)_/¯
Pictures of your setups will also be a plus!
Thanks,
Forum noob
mattaubel is offline   Reply With Quote
Old 07-18-2016, 12:17 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I suggest looking in this subforum. There are TONS of people posting their fitments with different wheels and what suspension they are on.
It's common to do a 1" drop with 20mm spacers on the stock wheels as it kills the wheel gap, and handles well without costing much or ruining geometry, though it's best to add LCA's with a toe arm solution, (like the SPC), and camber bolts.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
mattaubel (07-18-2016)
Old 07-18-2016, 12:50 PM   #3
8R6
8R6's Avatar
Drives: FRS
i would begin with looking through the different suspension setup threads. most people in those threads will have aftermarket wheels. then after, i would look through the wheel directory thread to see the different sizes/styles with tires and see how they fit. at the end, itll basically be a combination of both wheel/tires and suspension as this is the only way to figure out "wheel fitment". cant have one without the other
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
BRZ NAV not finding satellites DSPographer Electronics | Audio | NAV | Infotainment 116 01-05-2020 09:42 PM
FINDING SBD TURBO KIT THREAD myioz86 Forced Induction 2 01-21-2015 12:00 AM
Need help finding Part # 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 0 06-17-2014 08:41 PM
need help finding this Shipwreck Cosmetic Modification (Interior/Exterior/Lighting) 10 05-24-2013 01:06 AM
Help finding thread about startup rpm needle Prava Electronics | Audio | NAV | Infotainment 2 07-01-2012 02:29 PM
