Old 07-15-2016, 04:34 PM   #7379
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by camelflage View Post
Correct, it came with 80.
Sent from my HTC6500LVW using Tapatalk
I thought we were talking 335. I've been running a 72.5 on the 210 now for almost 2 weeks with no temp probs.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 07-15-2016, 04:57 PM   #7380
Dream20b
Y u do dis?
ran 70mm pulley on my previous 210 kit for almost a year, beat the piss out of it, and it never had temp problems on e85
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 07-15-2016, 05:39 PM   #7381
riboyster
riboyster's Avatar
I'm on 92 octane. Wish we had e85 here
What happened to your old kit?
Old 07-15-2016, 07:21 PM   #7382
camelflage
Drives: pinto power
That's good to know. Eventually I'll step down I'm sure.
camelflage is offline   Reply With Quote
Old 07-16-2016, 01:28 AM   #7383
riboyster
riboyster's Avatar
You'll feel the difference. Especially from 80mm. I wouldn't go to 69mm without cooling though. I'm planning on water injection.
I've heard the intercooler ****s up airflow near redline.
Old 07-17-2016, 06:15 PM   #7384
Linkfrs
Drives: Frs 2013 supercharged sprintex
Guys a have big problems , a got a spritex kit not intercool no oil cooler and a have big promble every time a roll whit the cars the check engine light pop the code is p1170 and p117b help me please ..
Linkfrs is offline   Reply With Quote
Old 07-17-2016, 08:29 PM   #7385
Kodename47
Kodename47's Avatar
Drives: UK GT86
From the help pdf:
P1170 Port Injector Fuel Performance Does not come on DTC
P117B Direct Injector Fuel Performance Does not come on DTC
Is the DI ECU earthed correctly?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-19-2016, 11:07 AM   #7386
GT86NZID
GT86NZID's Avatar
Drives: GT86 '14, F10 '15 & AMG GTS '16
I accidentally bought a sprintex 335. Will there be any problem if i install it on my stock motor and running it on 98 octane pump gas?
GT86NZID is offline   Reply With Quote
Old 07-19-2016, 11:13 AM   #7387
brianhj
Drives: 2017 Camaro 1SS
lol what
You will greatly risk blowing up your motor. Only safe way to run it would be with E85 and a large pulley.
brianhj is offline   Reply With Quote
Old 07-19-2016, 11:23 AM   #7388
8686
8686's Avatar
Drives: 86
You need to contact @moto-mike as he was the only person who didnt blow an engine with 335
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 07-19-2016, 12:07 PM   #7389
riboyster
riboyster's Avatar
You should probably just contact sprintex and ask if you can swap it with a 210
Old 07-19-2016, 12:17 PM   #7390
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Originally Posted by brianhj View Post
lol what
^this
But contact moto-mike @ motoeast.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 07-19-2016, 12:18 PM   #7391
stockysnail
Just the tip
stockysnail's Avatar
You can run it but you will need a new stronger clutch at a minimum and you'll want @moto-mike to tune it for you so you don't blow the engine. Mike and Moto East are the only ones I know of that tuned it for a stock engine and it didn't blow up. Also e85 fuel injectors and fuel pump is recommended as well. It will take extra work to get it in but then you won't need to upgrade later or deal with shipping and other crap if exchanging to the 210. Hopefully your 335 came with an intercooler and the 85mm pulley or larger.
Old 07-19-2016, 07:36 PM   #7392
walletsr
Drives: 2014
So my oil leak only happens during spirited driving. It comes out of the bottom of the turbine housing but above the black plate, if that makes sense. Is that sealed with a sealant? I don't see any bolts or anything holding it on.
walletsr is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
