Old 07-14-2016, 12:53 PM   #14085
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Buy the ducts and not the hoses and they pull decent air in but not as much as in the front grill area. They make for a nice stealth look if they are black cores too. Want me to share some pictures of the ducts with no hoses so you can visually see how it will all work out??
Thanks for the offer but I have seen how it looks with the circular fog holes as well as dremmeling out the plastic in between the "trapezoidal" pattern on the non fog housings for a really stealth look
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline
The Following User Says Thank You to Tectoniic For This Useful Post:
go_a_way1 (07-14-2016)
Old 07-14-2016, 01:07 PM   #14086
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I personally love the look of the APR ones and the OEM trapezoids cut out.
go_a_way1 is offline
Old 07-14-2016, 01:08 PM   #14087
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Find one that fits nice, send it off to be coated. Just cause it's not available in gold doesn't mean you can't change it
Yeah but I haven't found a intercooler with piping like the SBD kit coming from the top. Honestly didn't look too hard
Old 07-14-2016, 01:18 PM   #14088
Ashikabi
Ashikabi's Avatar
They got it from somewhere unless they make it themselves. I have looked into water to air intercoolers and found 2 places that make them in just about every imaginable configuration so I don't see why air to air wouldn't be the same
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 07-14-2016, 01:50 PM   #14089
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
OMFG.... I am so bored today
Old 07-14-2016, 01:56 PM   #14090
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
well I am downloading Pokémon go right now to kill some time...
Old 07-14-2016, 02:01 PM   #14091
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
don't play in traffic.
echo419 is offline
The Following User Says Thank You to echo419 For This Useful Post:
Old 07-14-2016, 02:04 PM   #14092
Teseo
Drives: frs
Noob. Play the originals. Or try Marver Future Fight
Teseo is offline
Old 07-14-2016, 02:20 PM   #14093
Phijkchu
Phijkchu's Avatar
Drives: Feet
Watch out you're gonna have to use your legs.
Phijkchu is offline
Old 07-14-2016, 02:35 PM   #14094
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah its weird....
Old 07-14-2016, 02:41 PM   #14095
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
On a scale of Being super polite to a Beaver getting a Gordy Howe hat trick how Canadian is this?
http://jalo.ps/D9nIsLj
finch1750 is offline
Old 07-14-2016, 03:21 PM   #14096
p1l0t
p1l0t's Avatar
I'm not sure if the brz's lighting is similar but I think you can on the frs. If i have the light stalk set to the setting between auto and low beams it has my DRLs and the front turn signals illuminated (Diode Dynamics switchback turns so all the lights are a bright white) and it should allow you to put the fogs on on that setting as well.
EDIT: I'm gonna retest this at lunch. Honestly don't remember
Yeah on the BRZ the HIDs must be on for the fog lights to work I just checked again.
p1l0t is offline
Tectoniic (07-14-2016)
Old 07-14-2016, 04:22 PM   #14097
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
For anyone thinking they are having a bad day.
http://www.6speedonline.com/forums/a...firestone.html
tl;dr -- Guy took his Aston Martin Vantage to Firestone for new tires. Firestone jacked the car up by the tubs rather than proper jack points. Car was totaled.
ScoobsMcGee is offline
Old 07-14-2016, 04:26 PM   #14098
FX86
why would a guy than can afford an aston martin go to firestone in the first place?
FX86 is offline
The Following User Says Thank You to FX86 For This Useful Post:
anytimeparking (07-14-2016)
