| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Amateur Drifter
Drives: '13 FRS
I've had some relatively good luck with Nankang NS20's. They last awhile (when you arent hot lapping) and smoke up nice!
| The Following User Says Thank You to gatorbushmen For This Useful Post: | sosick (07-15-2016) |
#16 |
[insert cool phrase here]
Drives: BRZ Premium
All you need is cheap tires. And practice. Stock tires would do but why pay $180+ when $60 would do the same exact thing.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | sosick (07-14-2016) |
#17 |
Drives: '24 GR86
What is your setup? Suspension, tires, alignment etc.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | sosick (07-14-2016) |
#18 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Fortune auto coils. 10 dampening in front on 6 k springs and 15 dampening in rear with 7k springs. Stock tires and wheels in rear. 17x8 +20 in front with 2254517 fierce instinct in front. 0 toe all the way around. -3 camber in front 0 camber rear
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#19 | |
Drives: '24 GR86
Seems like too much grip for the power you have. I'd increase damping in the rear and/or up tire pressures. 0 camber in rear isn't all that great either on these cars, unless you're running super soft spring rates. Typically -1 to -1.5 or so is solid; but there's no real right or wrong, just whatever feels best. I'd try taking some grip out of the rear end of the car though. Make it easier to lose traction so you aren't fighting it, which could cause the car to feel "snappy". Maybe even change to a 215/45 tire.
#20 | |
fastest frs in sbg
2014 turbo ultramarine frs Sold 2014 firestorm frs Last edited by sosick; 07-15-2016 at 03:34 PM. |
#21 | |
Drives: '24 GR86
I also ran 8k/9k springs with no front sway bar, and removing the front sway bar dramatically improved the snappy tendencies on transition. I had the same issue though when I first started with this car. A bit to snappy and inconsistent. I came to find out I just had a bit too much rear end grip dialed into the car and it was causing some snap oversteer. So I bumped up the tire pressures from aroudn 35psi cold to 40psi cold and it helped a bit. Helped even more when I increased the spring rate and increased the damper settings - I ended up with 4 clicks from full stiff on the rear.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | sosick (07-16-2016) |
#22 | |
fastest frs in sbg
I suppose ill try those things before buying tires. Ill start with checking air pressure. Dampening settings. Then alignment. Remove or switch to a smaller swaybar then lastly tires. That way i can see the changes. Appreciated
| GReddy X Scion Racing Drift FR-S new look for the 2013 Formula Drift Season | switchlanez | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 29 | 04-07-2013 01:20 PM |
| Ken Gushi Teaches Joey Logano How To Drift FR-S and GReddy Racing Drift FR-S | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 07-05-2012 03:06 PM |
