Old 07-12-2016, 07:18 PM   #1051
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by CarzCarzCarz View Post
Are you running the sames tires on the street that you drift with, and that's why your not getting much grip during rain? Or it just happened to rain at the last drift event? 225 should give you enough grip in the fronts.
I've tried Federal SS-595's, Accelera Alphas, and Kenda Kaisers, and all have been pretty good. Kenda's didn't seem to do as well up front (soft sidewall maybe), but do last a while in the back.
Ues these are my street tires. I figured they had lots of life on it that i could just drift on them. Drifted half the day while it was sunny then it rained. Thanks ill take a look into those options
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 07-23-2016, 12:26 PM   #1052
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
Due to a bungle between the wheel manufacturer and the seller, my wheels were misordered and they almost sent me the wrong lug pattern. Refunded as the proper pattern is on backorder for 3 or 4 weeks. Back to the drawing board...
Still cant make up my mind between 16 or 17 inch. 17 seems like the way to go for tire selection, but 16 seems to be best for reduced rotational mass... blehhhh wish i could get 17x9 +20ish watanabe...
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 07-31-2016, 07:06 PM   #1053
sosick
fastest frs in sbg
sosick's Avatar
Whos all drifting while boosted?
2014 firestorm frs
The Following User Says Thank You to sosick For This Useful Post:
MrFisty (08-10-2016)
Old 07-31-2016, 07:16 PM   #1054
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
I'm still learning gonna probably practice some more today!!
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
sosick (07-31-2016)
Old 07-31-2016, 07:29 PM   #1055
sosick
fastest frs in sbg
sosick's Avatar
Ive been to a couple events. Did well in stock form but with this new turbo setup i wonder if i could just power over instead of clutch kicking. Btw arent u running the map 5858 turbo? Did u have issues with the intake pipe also?
2014 firestorm frs
Old 07-31-2016, 07:41 PM   #1056
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yes I am and yes intake pipe is not perfect fit no big deal and you'll still need to clutch kick for the turbo lag.
sosick (07-31-2016)
Old 07-31-2016, 07:54 PM   #1057
sosick
fastest frs in sbg
sosick's Avatar
Did u end up cutting the intake pipe? Mine wont bolt on at all. Even if i shove it into the turbo lol
2014 firestorm frs
Old 08-01-2016, 04:39 PM   #1058
Shady195
Drives: '13 10 Series FRS #1203
As of this past weekend, officially I am.
Drifted this thing for the past 2 years with just a header, exhaust and OTS Tune
Took it out for the first time last Friday. All I can say is, I basically need to re-learn how to drive the car.
As I'm sure you may know if you have drifted this car in stock form, it requires speed, momentum and lots of clutch kicking to keep the cars tires spinning. Many times on tight technical areas, even while beating the car she just would not have the steam and would scrub a lot of angle and speed.
My first run, I ran it like I was used to, I went in hard, flicked in and mashed the throttle. Well, now theres power behind it and I quickly spun around. Realizing I now needed to use a lot more throttle input, my re-initiation wen't well, gave a quick kick of the clutch and feathered the throttle.
as I went around the final turn, onto the "straight" I manjied, and boy its so much easier, and also a bit more scary with power behind it.
It's a lot easier to carry angle, and get more of it when you have more control over the car with throttle.
Overall, I'm VERY happy I learned to drift the car in its stock form, mainly because I think the learning curve would be much higher, and the risk much more being able to carry the speed I am now versus stock.
Shady195 is offline   Reply With Quote
The Following 5 Users Say Thank You to Shady195 For This Useful Post:
2015firestormFRS (02-03-2017), JDM Haze (08-01-2016), MrFisty (08-10-2016), SoCal80six (08-07-2016), sosick (08-02-2016)
Old 08-05-2016, 11:46 AM   #1059
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Not sure what everybody else is doing tomorrow for 8-6 day, but luckily down here we have a great celebration day going on.
http://www.tx86day.com/
Happy Drifting & 86 day
CarzCarzCarz is offline   Reply With Quote
Old 08-07-2016, 07:02 PM   #1060
Kristian
I was out at Formula Drift Seattle on Friday and Saturday. Fun event. Here are some photos and videos if you're interested - http://apexrally.blogspot.com/2016/0...down-2016.html .
I'm just daily driving my FR-S. It would be fun to try drift / other track stuff at some point...
Hey, for folks looking for 18" tires they had a lot of free ones at the Formula Drift race (used of course but still had a fair amount of tread left).
Kristian is offline   Reply With Quote
Old 08-07-2016, 07:07 PM   #1061
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
No I did not cut my pipe at all.
sosick (08-08-2016)
Old 08-08-2016, 06:21 PM   #1062
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Last event I went to they drilled holes in the sidewalls to prevent this.
Liability reasons.
The Following User Says Thank You to x808drifter For This Useful Post:
Old 08-09-2016, 02:30 PM   #1063
Kristian
Hmm. They didn't do that in Seattle...
Old 08-09-2016, 03:20 PM   #1064
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You won't want those anyways. Most of them are very large in size, like 265 width or bigger, and are pretty grippy for our cars to use as drift spares.
They're pretty much useless.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
