Old 07-11-2016, 10:05 AM   #71
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
Final MoTec piece of the puzzle has arrived. Will be attempting to have it mocked up and mounted in the dash asap.
wnt3d is offline   Reply With Quote
Old 07-12-2016, 02:59 AM   #72
adjusts
adjusts's Avatar
Drives: 86
one of my favorite builds. great job.
adjusts is offline   Reply With Quote
Old 07-12-2016, 01:42 PM   #73
zenkaru
Drives: 2014 Scion Fr-s
A.C.E ftw
Instagram: eugenekiiim
zenkaru is offline   Reply With Quote
Old 07-12-2016, 09:07 PM   #74
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
Originally Posted by zenkaru View Post
A.C.E ftw
is hot. color A.C.E lip plus the RB v1 fenders really does go well together. Never been much of a RB fan, but that front end is hot!
Old 07-17-2016, 07:49 AM   #75
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
Managed to dismantle my spare oem instrument cluster to mock up a mounting panel for the c187 dash. The cluster basically has 4 sections ; the clear outer lens, cluster bezel and surround, electronic section and the rear plastic case. I ended up dremeling away the bezel circular frame that separates the tachometer from the rest. The spacing between the cluster surround to the rear plastic case is almost perfect to accommodate the c187 dash which is 24.9mm thick. The rear plastic piece had to be trimmed to allow the 79 pin autosport connector and mini usb port to slip through. Had some spare carbon sheets so I quickly cut some pieces to fill in the side voids. Turned out pretty neat for a quick dummy up. I will be design up a better designed aluminium rear bracket with CAD and have the carbon pieces CNC cut for a perfect fit, but pretty happy with how it turned out.
Also still waiting for the tuner to come back so we can start installing the M10 and setting it all up for another retune. The thought of switching the rear turbo housing to a 0.86 is also on my mind.
Old 08-21-2016, 08:47 AM   #76
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
New ecu and dash finally in and up and running. Still needs a thorough retune and time setting up the dash and functions correctly. Have also purchased some Bride Stradia's for both driver and passenger seats. Loving the new office!
Old 04-24-2017, 03:40 PM   #77
CortJester24
CortJester24's Avatar
Drives: 2017
Are the GTC01RR a 5x100 bolt pattern? I'd really like to run these wheels but I don't see a +35 offset available in a 5x100 pattern (at least here in the US).
CortJester24 is offline   Reply With Quote
Old 07-17-2017, 03:35 PM   #78
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
In for images. I'm strongly considering the Arising 2 back bumper right now, but I'm trying to see what aero combinations people are using for the rest of the car. None of your images are loading, so I hope you get them back up soon!
TheBRZsKnees is offline   Reply With Quote
boost, e85
Red GT86 from Europe - Slow build - Daily+track. Iceman Member's Car Journals 53 12-22-2020 02:59 PM
Pacific Auto Films' Daily/Track Build Pacific Auto Member's Car Journals 9 10-29-2015 09:48 AM
FRS slow daily/ drift build SciOnDrifTtSlIdeR Member's Car Journals 7 04-19-2015 01:50 AM
Daily Driver + Autocross/Track Car build on a Budget ToyoburuBRZ Member's Car Journals 29 12-19-2014 09:32 AM
