| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | ||
Proud of BOXER
Drives: Subaru Boxer
Any updates?
#16 |
Drives: 2013 ARGENTO A/T
I'm upwards of 800 miles on the tires now, and while things have gotten a LOT better..something still just feels off. The squirming has mostly dwindled away but the steering still feels numb and most aggrevatingly, unpredictable. Speed in the corners has picked up so much that I feel like Im cornering faster over the Primacies but it's a lot more nerve racking because out of no where you will just get this extra angle of body roll when you dont expect it.
Lastly it feels as if 30 degrees were added to the steering wheel. It just takes Soooo much to get any movement. Sometimes when Im doing 60 on the highway I just rapidly wiggle the wheel left and right seemingly 15 to 20 degrees and absolutely nothing happens. I'm pretty much summing this up to the hankooks at this point but I still have nothing to compare on the new wheels. Here is an article I found that drew a lot of the same experiences. http://www.corvetteforum.com/forums/...ve-review.html |
#17 | ||
Proud of BOXER
Thanks for the update! Sounds like you're definitely experiencing a few of the same things mentioned in that other guy's review. Specifically this part:
"The car feels like it gained a good deal of body roll due to the sidewall structure of the tires being far too soft. This is also further demonstrated by the dramatic softening over bumps. High speed stability feels awful with the car floating around while switching lanes or making a change of direction. Throwing around the car in the twisties is a bit scary because there is often a discrepancy from where you point the car and where it ends up. This is due to the sidewall flex." Perhaps these particular tires just aren't a good match for our cars? Quote:
#18 | |
#19 |
After TRD lowering springs.
| The Following User Says Thank You to Spacemane969 For This Useful Post: | Cheeky (04-05-2019) |
| Wheel Directory: BBS RF 17x7.5 +48 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 112 | 11-02-2023 06:40 AM |
| Wheel Directory: BBS RK 17x7.0 +48 | Laika | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 05-21-2017 06:31 PM |
| Wheel Directory: XXR 521 17x7.0 +38 | ML | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 08-23-2015 09:26 PM |
| Wheel Directory: STR 601 17x7.5 +40 | Cross | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-06-2014 08:57 PM |
| Wheel Directory: BBS CF 17x7.5 +35 | elbles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 12-02-2013 03:18 PM |
