Old 07-08-2016, 07:52 PM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
Car won't start, won't crank, no ecu communication
Back story:
I was at the track and popped an oil cooler line which resulted in a fire. The fire was small and put out immediately but they spayed the crap out of the engine bay.
Now the car won't start, won't crank, and tried two scanners that couldn't communicate with the ecu. I've gone through the fuses and they look good. I'm kind of assuming the lack of ecu communication is preventing the car from starting?
Any ideas?
redlined600 is offline   Reply With Quote
Old 07-08-2016, 08:03 PM   #2
You might check the battery terminals......
mdm (07-09-2016)
Old 07-08-2016, 08:05 PM   #3
steve99
Drives: FT86
Originally Posted by redlined600 View Post
Back story:
Any ideas?
The main engine ecu is under the dash on drivers side for you guy so unlikely the fire got to that. The thing that looks like an ecu under bonnett is actually the controller for the direct injection. However most of the electronic control unit in car including ecu dash imobiliser and traction control direct injection computer all talk on a can buss which is a pair of wires connected to all these units, it possible wiring has been damaged shorted etc or one of the units is damaged effecting communications on can buss.
going to be very difficult to diagnose.
their are three or so fuse box locations have you checked them all
does dash light up and key symbol go green on dash if they key symbol is red or yellow the key is nor being read by the imobiliser or the imobiliser module cannot talk to dash and ecu.
clutch or park switch fail will also stop car starting
i think your going to need an auto electrician or specilist subaru person
Old 07-08-2016, 08:37 PM   #4
redlined600
Drives: Fr-s
Update: the car keeps blowing the ego(ctrl) fuse. I need to look at a wiring diagram.
Old 07-08-2016, 08:41 PM   #5
redlined600
Drives: Fr-s
If I jump the starter it will crank.
Old 07-08-2016, 09:44 PM   #6
steve99
Drives: FT86
http://www.ft86club.com/files/BRZwiringi.pdf
redlined600 (07-10-2016)
Old 07-08-2016, 09:53 PM   #7
steve99
Drives: FT86
sure thats not EFI(CTRL) ???
Old 07-08-2016, 10:28 PM   #8
redlined600
Drives: Fr-s
Yes, mis- type
Old 07-09-2016, 12:49 AM   #9
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Maybe your wiring harness got burned, alot of twins my friend buys don't start because of a small cut of the fuse box wires. Only 4-5 wires are cut but it doesn't start, maybe theres an exposed wire shorting the fuse?
mulekr1 is offline   Reply With Quote
Old 07-09-2016, 10:21 AM   #10
redlined600
Drives: Fr-s
This is likely. I need to dig deeper but at first glance it looks like it's the engine harness, efi computer, or associated sensors.
Old 07-09-2016, 12:55 PM   #11
redlined600
Drives: Fr-s
Got it going! Both cam sensors and wires were torched. I pulled them apart, taped them up and the car starts, no check engine lights even. Looks like a new engine harness(and a lot of clean up) will get it back to 100%
Thanks for the suggestions.
The Following User Says Thank You to redlined600 For This Useful Post:
TheBRZsKnees (05-24-2017)
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 05:57 AM
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 06:30 PM
Vendor's communication yomny User/Vendor/Sponsor Reviews, Feedback, Comments 19 02-13-2015 11:06 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 06:22 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
