Old 02-14-2016, 09:33 PM   #15
sw20monster
Drives: 2002 MR-2 Spyder
I just recently had issues with my 2016. It connects and shows different songs but I can't use the skip feature. What I have to do is shut off the phone and reconnect. But it starts to act up as soon as I stop the car again. Galaxy Note 3.
sw20monster is offline   Reply With Quote
Old 03-07-2016, 03:21 PM   #16
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
I've only had my BRZ for less than a week. I've been looking for a thread on the 2016 HU. I have a Galaxy S5. I can get Pandora to work fine BT, it takes a little bit to find the connection but it's been pretty solid otherwise. Same for the BT connection when I listen to a podcast. The starlink rarely works though, it just tells me there is an error most of the time. My biggest confusion is how the phone works. I've transferred my phone book but sometimes when I get a call it shows the phone number but there is no green pick up the call icon only a hang up one. not sure what's going on there. Has anyone used the voice control? If I press the button nothing happens ever. No voice prompts or anything. My 2010 Legacy worked pretty much without issue and the same with the wife's 2013 Outback. BT in those cars is not bad at all.
Peaty is offline   Reply With Quote
Old 03-07-2016, 04:18 PM   #17
Mmmankey
Mmmankey's Avatar
Drives: Subaru BRZ Series.HyperBlue
The phone is a little wonky for me too. Some numbers will show up as the name and some will just show up as the number. On a few occasions I have picked up but no voice both ways. However, once connected no one has complained about call quality. Overall the system works for listening and calling just wished it was as smooth as the F150 and Focus I've ridden in.
Mmmankey is offline   Reply With Quote
Old 03-07-2016, 09:31 PM   #18
Peaty
Scooby***s Guy
Peaty's Avatar
I've messed with the voice control some more, it seems it's my phone because it works fine unless my phone (Galaxy S5) is hooked up to BT. My wife's Droid works fine. I need to investigate more I guess, anyone else with a Galaxy S5 and the 2016 HU get voice control to work?
Old 03-08-2016, 09:55 AM   #19
Peaty
Scooby***s Guy
Peaty's Avatar
Well it took a while but I figured out why my voice commands weren't working. In the event someone else has this issue and the off chance they search, this is what worked for me.
This is with a Galaxy S5 (may be the same for other phones I don't know) and the 2016 6.2 head unit. Issue was the voice command would not come on when pressing the voice button (bottom left on head unit) When I say not come on, nothing happened like I didn't even press the button.
I will spare you the trial and error it took to figure this out but essentially, I believe because I sent my whole address book, relatively large amount of contacts, from my phone to the head unit, it somehow borked the voice command. I deleted my phone from the head unit's blue tooth and unpaired my phone. This removed my contact list. I re-paired my phone with the head unit and sent only a handful of contacts, maybe 20, over one by one. Took a little while but that seemed to do the trick everything works now with the voice command.
To send single address over with the S5. Select contacts, import contacts, then single contact (not exact wording but something like that) on the head unit getting it ready to accept a number, next open the contact you want to send on your phone, at the top right pick share card, select BT for share, select the head unit then send. That will send it over. After it's in go to the next one and so on.
Sorry for putting this here not sure where else to put it. Any specific questions I can try to answer
Old 06-06-2016, 02:31 PM   #20
Da Brz
Drives: 2016 Subaru BRZ
I've had my 2016 BRZ for almost a month now. I've pretty much given up using the HU for anything outside of FM radio.
Out of Pandora, phone calls, and blue tooth, only one ever works at one time and sometimes none of it works. Twice now, I've tried to use Pandora and it just switches on and off and never connects.
I've also experienced max volume "pops" of sound when trying to switch from phone calls to something else.
I've disconnected and reconnected my LG smartphone about seven times now. No help.
Da Brz is offline   Reply With Quote
Old 06-16-2016, 11:30 AM   #21
Da Brz
So I switched back to an older phone and all my troubles went away.
Guess I need a different phone.
Old 07-07-2016, 02:08 PM   #22
SullyStyle
Drives: Hyperblue BRZ 2016
Originally Posted by Mim View Post
I've never bought a car and thought to my self, wow what a great sound system and it does all that I want!
Bought the BRZ with just the base shity stereo sans touch screen and installed one of these http://www.pioneer.com.au/au/product...50BT/page.html
Added speakers, amp and a reversing camera and could not be happier.
Takes SD cards so popped a 32GB one in there with music and video's, yes it plays just about any format video file, but I don't use that function myself.
Blue tooth syncs flawlessly the moment I start the car and it just keeps playing where I left off (if streaming from the phone). Song metadata streams to the screen correctly and even the siri functions work through blue tooth, if I want to just voice dial contacts.
The screen is very responsive and the GUI is nicely designed and layed out. The street directory is awesome.
Note the only drawback for Apple Car play is the need to plug your phone in for it to work. Not a feature I bother using to be honest.
TL;DR - Buy an aftermarket head unit and call it a day.
Does it support other text languages? Will it display Korean/Japanese, or will it just show boxes/blanks for those kr/jp songs?
SullyStyle is offline   Reply With Quote
Old 07-07-2016, 11:07 PM   #23
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Hmm I am not sure on that point. I'll need to check for you. Got some anime OST's sitting round that I'll need to pop on the phone and test.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 09-28-2016, 01:28 PM   #24
Da Brz
I'm still having issues with my HU. I had to go back to my other phone, but I think some of this is unacceptable. The phone I'm using meets every requirement listed in the manual.
Today, I couldn't get anything to connect, so I just hooked up the aux cable. Even that didn't work. Sound was not coming through the phone either, so I don't think it's the aux jack on my phone.
Day before yesterday, I received a call and it wouldn't hang up. I had to hang up using the phone, but the HU still showed my call as ongoing. It ran like that for over a minute.
Also last week, I received a call on the phone and my car didn't put it through. It paused my music, so it knew I was getting a call, it just didn't tell me.
My rear view camera has locked up once. Everything else seems to work only about 60% of the time.
I'd rather have a more reliable HU with more limited capability than something that promises the moon but can only deliver a rock.
I experience lag and connection issues multiple times on a daily basis with this car.
Junk.
2016 FR-S vs 2016 MX-5 Coupe NWFRS FR-S / BRZ vs.... 55 11-29-2013 11:17 AM
Bluetooth and Nav System slizoth Issues | Warranty | Recalls / TSB 8 11-01-2013 01:32 PM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 05:48 PM
