Old 06-29-2016, 06:24 PM   #3557
CSG Mike
CSG Mike's Avatar
Originally Posted by Xuningshen View Post
not so much related to our SC but...
does anybody have any oil pressure logs or something from their car? just curious with it getting warmer. My oil pressure seems tapers off around 4.5k-5k rpms. holding the same PSI until redline. after sitting in traffic it'll be in the 50's after 5k rpm with 5w30 and the air to oil, oil cooler
you guys all seeing similar?
Unrelated, but that's about what I see on heat soaked Porsches and Lamborghinis.
Old 06-30-2016, 06:50 AM   #3558
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
I just purchased a JR kit and I can't wait to get it. i hope my previous nightmare of a supercharger with broken belts all the time will be a thing of the past.
morswestford is offline   Reply With Quote
Old 06-30-2016, 11:07 AM   #3559
Xuningshen
Drives: Subaru BRZ
I'm just asking because everything has been going so well on my car something is bound to fail soon lol, like the avcs. I was under the impression for awhile that oil pressure rises linear with our rpm. but I guess thats not the case after heat soaked. thanks
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 06-30-2016, 12:10 PM   #3560
CSG Mike
CSG Mike's Avatar
Oil pressure typically plateaus, instead of continuing to rise, once you're at full operating temp.
Old 06-30-2016, 04:53 PM   #3561
vagthomas
Drives: Toyota GT86
Hi guys!
I am thinking of installing Jackson Racing Rotrex, but I seem to be missing some further info that i haven't been able to find in the thread; Based on what i've read, rotrex is considered quite reliable. So the questions are as follows:
- What's Rotrex temp during operation?
- How much boost for 280 bhp with 100 octane gasoline?
- What is the AFR compared to stock car? Is it really even down to 10.94, as found in another thread, at max RPM and max load for the stock car?
vagthomas is offline   Reply With Quote
Old 06-30-2016, 05:06 PM   #3562
CSG Mike
CSG Mike's Avatar
Originally Posted by vagthomas View Post
Hi guys!
- The supercharger itself?
- the stock pulley will take you to 280bhp on 100 octane gasoline easily; ~9.5 psi (~0.65 bar)
- gasoline AFR stays steady at around 11.5 at WOT (open loop). It depends on the exact fuel blend.
Old 06-30-2016, 05:15 PM   #3563
vagthomas
Drives: Toyota GT86
Thanks a lot for that quick reply!!
- Yes the supercharger itself
- And one more; what is the optimum air inlet temp to get 280 bhp with 11.5 AFR at 0.65 bar?
Old 07-05-2016, 05:08 PM   #3564
Aaronimoe
C38 JRSC w/ catless uel header - 225whp and peak boost of only 7lbs...
*e-tuned by motoeast. kit was DIY installed
trying to figure out If there is something that isnt right here.. Has anybody ran into issues with that hose popping off under boost? its the hose underneath the intake manifold.. Could that cause an issue like this?
Aaronimoe is offline   Reply With Quote
Old 07-05-2016, 06:01 PM   #3565
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
I'd check for a leak. Does seem pretty damn low, and PRT is a good shop.
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 07-05-2016, 06:16 PM   #3566
Aaronimoe
It was actually remote tuned by moto-east. I just used PRT's dyno.
Old 07-05-2016, 06:22 PM   #3567
CSG Mike
CSG Mike's Avatar
You're AFR should be much flatter than that.
Your torque stops climbing after 5500 RPM, whereas it should be climbing almost all the way up to the top.
Check for boost leaks. A hose that pops off would be VERY obvious; you may be just leaking boost.
Got a datalog of a pull I can look at?
Old 07-05-2016, 06:39 PM   #3568
Aaronimoe
https://drive.google.com/open?id=0B6...tlT1lPb0F2ZVBF
Old 07-05-2016, 06:59 PM   #3569
Aaronimoe
Just noticed this silicone tube was barely hanging onto the MAF tube. re-situated the silicone and gave the maf tube some more slack from the other end. I guess it was opening up once there was enough pressure (around ~4500rpm) ?
Old 07-05-2016, 07:09 PM   #3570
CSG Mike
CSG Mike's Avatar
Your MAF reading is inconsistent over 6000 RPM. Check your piping, placement, and MAF sensor.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
