Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-04-2016, 09:58 AM | #1 |
Drives: fr-s
searching for a hour no luck will these fit
19x10+26 mid disk 4" lip
5x100 original |
07-04-2016, 10:24 AM | #2 |
Off Topic
Here's an 18x10 +25, so it's 1mm different in offset. Look at the camber he's having to run to get the top of the wheel back into the fender. If that's the look you're going for, then great. There's a lot of parts and work involved to get them to fit though.
http://www.ft86club.com/forums/showthread.php?t=22655 |
07-04-2016, 11:45 AM | #3 |
Drives: fr-s
I found a set that are 18x9.5 +20 looks like they will be a better fit I can't run to much camber due to being 2j swaped I want the as much tire as possible on the ground
07-04-2016, 11:48 AM | #4 |
Drives: fr-s
I like the battle stance look. I can't be go low due to 3.5 inch exhaust might switch exhaust with oval pipe to help get more room
07-05-2016, 12:36 PM | #5 |
Country Boy 4 Life
+20 fits with poke. If that is your thing. |
07-05-2016, 02:30 PM | #6 | |
Drives: 2005 Toyota Camry
9.5" and a +35 or +40 offset. Or 10" around the same. We had 275 Hoosiers on 18x10" wheels in the rear with minimal fender roll. You'll just have to stagger your setup since the engine will give a lot of power oversteer anyhow. -alex |
Similar Threads | ||||
Searching for fog light bezel | idover | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-11-2022 09:39 AM |
Searching for correct fitment | Lischynski | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-17-2014 07:35 PM |
Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 10:32 AM |
Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 04:40 PM |
