Old 06-28-2016, 10:11 PM   #1
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Perrin BRZ Gurney flap
Hiya folks!
Just finished installing a Perrin gurney flap on my DMG 2015 BRZ...
First, the finished install looks great and really improves the look of the BRZ spoiler! As of now I don't know how it will effect downforce or drag/mileage...
The instructions are very complete and do a good job of getting you through the process. Below are a couple of my caveats to the instructions ....
1) have a extra pair of hands to help... You can do this by yourself by I wouldn't want to do it...
2) this is a big deal..! The middle 5 holes will need to be drilled through two layers of material. The first layer is the finished outer layer, I found the structural layer inside is to shallow to allow the rivnut to sit flush with the outer surface to allow proper tightening so you will need to drill into the support structure inside about an additional 1/8 to 1/4'inch deep too allow the rivnut to fit properly for tightening....
3) drilling... I have been working with composite, metal and wooden materials for a very long time... If your not comfortable with and don't have the drills and bits necessary, consider farming this out.... For this project I found a 3/8 inch flat wood bit worked very well in place of the HS drill bit suggestions...
4) masking... Don't skimp on this it is very easy to scratch the spoiler or body surfaces during the drilling and installing of the rivnuts. Plus the repeated install and uninstall of the flap... (This is were the extra hands are really helpful.)
5) the rivnuts. After you get past the first tight phase of crimping them into place the tightening will come easier. Once the easy phase is over resist the temptation to over tighten more than needed. There is no torque rating here so you need to do this by feel so as not to distort the rivnut at this point...
6) the last item... The washers have a smooth side and a rough side! During figment and adjusting the flap make sure to use the smooth side of washers against the flap to prevent scratches on the flap during test fittings. You can flip them during the finial install phase for a smoother look!
That's it! I will try to post some pics of the finial install tomorrow!
Good luck, Ed
BRZHarley is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZHarley For This Useful Post:
FRSBRZGT86FAN (06-29-2016), lbrixey (06-07-2018)
Old 06-29-2016, 02:28 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by BRZHarley View Post
Hiya folks!
Good luck, Ed
Great Writeup, it's too bad this isn't for more of the cars like the FR-S oem spoiler and that perrin hasn't released any COD statistics
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
BRZHarley (06-29-2016)
Old 07-01-2016, 07:06 PM   #3
BRZHarley
More pics
More pics!!
The Following User Says Thank You to BRZHarley For This Useful Post:
Old 07-01-2016, 07:16 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
STi claims that their Gurney flap does not increase the CD.
http://www.sti.jp/parts/catalogue/br...6010AS000.html
FRSBRZGT86FAN (07-01-2016)
Old 07-01-2016, 07:26 PM   #5
racecarshots
Drives: It alls slivery blue.
I totally do not like the stock BRZ wing, but this thing makes it look pretty darn good.
racecarshots is offline   Reply With Quote
Old 07-05-2016, 12:46 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
DRILL!? yep, lost interest in that product right there.
Dr. BRZ is offline   Reply With Quote
Old 07-05-2016, 01:07 PM   #7
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
I have actually read that the STI Gurney flap reduces the co-efficient of drag by 0.01.
I have one, I bought it mostly to complete the look of the spoiler. You are SUPPOSED to drill two holes in the spoiler, but I just used the supplied adhesive and stuck it on. I cut the push pegs so that they fit in the hole, but don't touch the spoiler underneath, and just super glued them in place. Works great, the supplied adhesive is pretty damn strong. So strong that I would think there may be paint damage if you were to try and remove it.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Perrin Gurney Flap for Stock Spoilers! m.box.design Northwest 38 02-05-2017 07:23 AM
WTB: Gurney Flap benrz Want-To-Buy Requests 0 04-24-2016 01:35 PM
BRZ Gurney Flap ScottDRFT Want-To-Buy Requests 2 10-05-2014 02:48 PM
BRZ gurney flap ScottDRFT Cosmetic Modification (Interior/Exterior/Lighting) 2 10-04-2014 04:35 PM
WTB BRZ STi Wing Gurney Flap monisan Want-To-Buy Requests 0 12-14-2013 05:15 AM
