Old 06-29-2016, 09:37 PM   #253
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Keep on eye on your hood when reaching high speeds though. You may notice it lifting due to air being forced more into the bay.
HuntingtonFRS is offline   Reply With Quote
Old 06-29-2016, 09:44 PM   #254
zeal86
zeal86's Avatar
Drives:
I guess I'm not following you... I see it as airflow being diverted through the radiator as opposed to directly into the engine bay... Also, I figure the hood vents will help to relieve any sort of pressure that could potentially lift the hood at high speeds.
__________________________________________
projekt zeal86 build
zeal86 is offline   Reply With Quote
Old 06-29-2016, 10:21 PM   #255
HuntingtonFRS
Hood vents! Then you're good. This was an issue with a friend's car until he got the vented hood.
Old 06-29-2016, 10:49 PM   #256
zeal86
zeal86's Avatar
Drives:
These are my hood vents...
Old 07-01-2016, 03:18 PM   #257
zeal86
zeal86's Avatar
Drives:
Drove the 86 yesterday with the radiator packing installed... Outside temp was @91-93°F. My coolant temps never passed 220°F...It hit 220° while driving away from wind. I hit 227-228°F in lower outside temps the other day.
I probably averaged @212-213°F...reached temps in the upper 190°F range while driving into a headwind. Overall, I think blocking off the sides of the radiator made my temps lower and more stable.
Old 07-01-2016, 03:45 PM   #258
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Intercooler outlet pipe prevents proper fitment.
zeal.eightsix Facebook
Instagram | zeal.eightsix
I wasn't with HKS when our kit was installed, but today we took off the bumper to see how it was set up with the HKS intake box. Our car *does* have the HKS intake on it, but it is cut to fit just like you'd have to do with the stock intake. Take a look.
Torry@HKSUSA is offline   Reply With Quote
Old 07-01-2016, 03:49 PM   #259
Torry@HKSUSA
Drives: HKS
What's the best option for us then as an intake?
Also, where can we buy more traction fluid? Mine leaks from the seal on the top of the container. I need to find another rubber seal or something.
Any HKS dealer can get traction fluid.
http://www.hksusa.com/supercharger-t...igh-viscosity/
Or for cold weather climates:
http://www.hksusa.com/12002-ak030-gt...tion-fluid-ii/
Old 07-01-2016, 03:57 PM   #260
zeal86
zeal86's Avatar
Drives:
Thanks for the update... I could have done that but chose not to... Too bad the fitment requires cutting.
Maybe down the line if I can acquire a used one I'd cut it.
Old 07-02-2016, 04:22 PM   #261
zeal86
zeal86's Avatar
Drives:
Old 07-04-2016, 05:08 PM   #262
HuntingtonFRS
So, the part I'm lost on are the pulley upgrades. If I'm running the V3 kit what options for pulley upgrades do I have and how exactly do they affect everything? I tried looking it up but this is about the only place we have info for our setup
Old 07-04-2016, 07:32 PM   #263
Apex-Apex
Apex-Apex's Avatar
You have the e85 upgrade pulley which will require you to run the DW 700cc injectors, upgraded fuel pump and e85. However, if you're not running hks tune, you can just buy smaller pulley, any injectors and get a retune.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 07-05-2016, 01:57 PM   #264
WRX4ME
Drives: 2016 BRZ HyperBlue, 2015 WRX Red
If you ever decide you want one, hit me up. I'll sell you mine very reasonably just to keep it from taking up space on a shelf in my garage.
WRX4ME is offline   Reply With Quote
Old 07-07-2016, 06:10 PM   #265
HuntingtonFRS
I'm trying to find the e85 kit from HKS. Is this just something that gets made by buying individual parts or is there an actual option from HKS?
Old 07-08-2016, 08:09 AM   #266
Torry@HKSUSA
Drives: HKS
You need 3 parts.
HKS 12002-KK001 Pulley Upgrade Kit
Deatschwerks 16U-02-0700-4 700cc Injectors
Deatschwerks 9-651-1010 Fuel Pump
The DW parts are what is recommended by HKS, but equivalent parts from another brand would work just the same. The only HKS part you need is the pulley. The pulley kit will also include a new belt.
supercharger help... sosick Forced Induction 25 08-15-2013 11:02 PM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 06:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
