Old 06-28-2016, 03:01 AM   #1415
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Infinity View Post
That is the same dyno I linked in my original post.
Apologies, I was being flippant with my replies and did not really think much of it. Just did a google image search for edelbrock dynos and linked the first one that popped up. I guess my point was that they are all very similar, just shifted up and down, depending on fuel or pulley size.
I believe someone mentioned earlier (@CSG Mike ?) that the Ace header improved the top end, getting rid of that drop near the end.
Old 06-28-2016, 10:31 AM   #1416
Infinity
Drives: 2016 Scion FR-S
It would be nice to see what kind of difference the Ace header could make.
Infinity is offline   Reply With Quote
Old 06-28-2016, 12:56 PM   #1417
CSG Mike
CSG Mike's Avatar
I know Jordan and Chris have Edelbrock + Ace setups, but I don't know their forum user names...
Old 06-28-2016, 01:35 PM   #1418
BigFatFlip
BigFatFlip's Avatar
Jordan @NotSoJDM
Old 06-28-2016, 11:51 PM   #1419
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Yeah that's pretty freaking rad
Freeman is offline   Reply With Quote
Old 06-29-2016, 10:59 AM   #1420
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Just ordered the DT d-box for fits n shiggles. Haven't had a mod in a while
didja get it yet?
shiumai is offline   Reply With Quote
Old 06-29-2016, 11:11 AM   #1421
BigFatFlip
BigFatFlip's Avatar
Originally Posted by shiumai View Post
didja get it yet?
Not yet, just got shipping confirmation, so probably before the weekend. What about you @Nitro22 ?
Old 06-29-2016, 11:32 AM   #1422
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
I received mine Monday so only had a few days to evaluate the D-box. The power increase is subtle, but it's there. It's hard to quantify it, but the power difference is analogous to the power difference you would see if lets say your IAM was 0.9 and now is 1. I think coupled with the new V19.5 Delicious tune, it makes for a smooth power delivery.
Nitro22 is offline   Reply With Quote
Old 06-29-2016, 03:01 PM   #1423
Colin86
Drives: 86
Do you need a rivet tool to install this kit or can you make due without?
Colin86 is offline   Reply With Quote
Old 06-29-2016, 03:25 PM   #1424
BigFatFlip
BigFatFlip's Avatar
I assume you are talking about the rivnut tool that you need to mount the DRL resistor (which only applies to certain cars, my BRZ didn't need it if I remember it correctly). If you do need it, there are a handful of ways to install it with out buying a tool.
[ame="https://www.youtube.com/watch?v=SzWj5y00sVg"]DIY Rivnut tool - YouTube[/ame]
Old 06-29-2016, 05:20 PM   #1425
wheelhaus
wheelhaus's Avatar
My biggest concern is durability and high temps for track days.
I've been set on the JR kit for this very reason, but now I'm curious about this kit, mostly because the midrange torque is more enticing for the other 360 days of the year. I decided against the Sprintex kit due to complaints about heat mitigation on track days so I'm curious how this system holds up.
I'm in Denver around ~5000ft altitude which seems to help mitigate high temps because there's less air density, so we're making a bit less power and heat; according to a Scangauge II my oil temps have peaked at 265°F after a solid 20 hard minutes.
I saw earlier in the thread someone was going to do some temp analysis from a track day, but couldn't find the results. How well does the system/CARB tune hold up to repeated laps?
Old 06-29-2016, 06:01 PM   #1426
BigFatFlip
BigFatFlip's Avatar
Not sure if it was posted on this thread, but this is probably what you were looking for, courtesy of @NotSoJDM
http://www.ft86club.com/forums/showp...5&postcount=85
I've only taken my car to a couple of track days and noticed similar temps: Oil temps peaked at 230F (w/ oil cooler) and coolant at ~200F, around 85F ambient. Note that I was running a DT tune at the time and was near sea level (Sonoma raceway and Thunderhill).
Old 06-29-2016, 06:12 PM   #1427
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Hi ! Some feedback on my car ...
I gutted the header 'cause of one shit ! I will start with this shit.
After i had install the edelbrock on my stock exhaust except agency power cat back i dyno it to 296hp (crank) (195 stock same dyno) i thought that my exhaust was to loud ! That was a shitty mistake !
I told myself to do something : making an axleback with a varex silencer and right single exit.and bolt it to the stock mid pipe
Take time, made plans, weld it like i want and put it on the car.
First time i drive it i noticed a little lose of power and no more sound going out of the car (open varex or not) not as much i want. Drive it like that, do some pulls.
And i decide to go to an invidia catless Front Pipe to put more sound out of this exhaust.
When i remove the stock front pipe a found pieces of the first cat in the second. At this time i didn't know that all this shit happens 'cause of my cat back set-up ...
I just put the new front pipe and decide to go for a ride see if the first cat will die or not, and booom 3 miles later no more power, go back to house and i "gutted" the stock header.
For sure, there were more sound, and horsepower were back. In my mind, because of the sound more agressive i thought the car were working better.
Took it to the dyno two days ago and what i got ? 249 HP :'( ....
Man at the dyno told me there were so much pressure in my exhaust something wasn't normal ... their big vacum or gaz absorber don't know how to name that in english, just fall down ! He told me it has never done that before !
he doesn't take a lot of time to understand where were goes all those Horses ! Just take a look under my car, see what i've done, immediatly told me that my exhaust for my kind of setup was horribly bad !
See the picture you can see that exhaust gaz was slow down by a lot of turn of the stock mid pipe and the axleback, single exit with 2.1" diameter ... he told me that my exhaust was pretty good done but will work on an NA car not one like me ..
This setup created a lot of heat, back pressure, pressure in the exhaust and i think that's why i kill my cat ...
We tested everything on the dyno, afr, supercharger pressure, no leaking ... curve where the same but down low. Pressure was damn not normal at the end of the exhaust. So we were absolutely sure that it's the exhaust that cause troubles ...
My exhaust was not the best you can do, bad axleback, shitty stock mid pipe, gutted header (just remove the cat in ..)
So there it goes, i go back to an other setup :
Mxp header EL
Mxp over pipe
Invidia catless front pipe
Greddy revolution rs 3" left single exit
Just spoke with zach at delicious tuning. He had something similar with the e-force, two cars, same setup but one with header stock and the other not. Stock header was making more power 25more ! Dafuck ?! There is something i don't understand here .. hope that my new setup will give me back my HP and maybe give me an extra bunch ! I know that i lose much more than the car zach dyno because of my BAAAD exhaust setup.
I will give you some info as soon as i put on my new exhaust and i dyno it.
Just oredered at ft86speedfactory 1hour ago my new greddy 3"cat-back and my MXP header+OP combo.
Dhl express, normaly 4-5 day to france.
Hope everything will return to normal ... bad mistake i've done here ...
If any body had problems with header just let me know ...
Paulo86 is offline   Reply With Quote
Old 06-29-2016, 06:46 PM   #1428
Colin86
Drives: 86
Exactly what I was looking for, thanks!
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
