Old 05-19-2016, 09:48 PM   #519
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
For what you're getting with the Emtron, it's really inexpensive. You can get an Emtron set up for what it costs for the hardware alone if you went the Motec route.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline
Old 05-20-2016, 02:37 AM   #520
Ross
Drives: 85 corolla gts
I found when doing a harness for an engine swap ems on this platform you end up splicing in to quite a bit of the factory wiring. As well there are a couple connectors, well at least with the 2j swap that are in high heat areas and could potentially cause issue. In those connectors are a handful of needed wires. I removed the connectors and excess wiring and repinned the wires still needed for for dtm connectors and changed their location. If someone (harness manufacturer for instance) was to follow the same rout as I did I do not think they would feel comfortable leaving that in the customers hands. If the customer was capable of dealing with that, they would be capable enough to build a harness them selves.
Ross is offline
Old 06-25-2016, 09:43 PM   #521
Godzilla35
Drives: Nissan GT-R
Subbed. And yes, I've been very patient. And I've been told yes, then no, then yes a million times.
Godzilla35 is offline
Old 06-25-2016, 10:32 PM   #522
brz11b
Drives: United States
I'm hoping this kit keeps moving forward
brz11b is offline
Old 06-29-2016, 08:21 AM   #523
Zer0
Drives: 2015 frs
Last time I contacted them they are waiting to release the swap kit until a electronics's solution has been found to keep the stock items working that need canbus signals.
Zer0 is offline
Old 06-29-2016, 07:59 PM   #524
boomslang
Drives: Toyota
OMG...Emtron IS the answer. Much better than two factory ECU's and a CAN box bandaid.
boomslang is offline
The Following User Says Thank You to boomslang For This Useful Post:
8686 (07-02-2016)
Old 07-19-2016, 10:39 AM   #525
Zer0
Drives: 2015 frs
@cf6mech would you happen to know the part numbers for the transmission components used in your swap I was looking to use the same transmission but have been unable to find a T56 magnum xl for a LS3. I contacted Vorshlag through a few separate channels and have not received a response as of yet. To be clear I made the inquiry yesterday so they may get back to me. I was going to order it through them if possible since they put in the work to figure it out.
Zer0 is offline
Old 07-19-2016, 01:52 PM   #526
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
We have the old pricing, but it has gone up a little since we bought one and I'm waiting for our builder to give me the current pricing.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline
The Following User Says Thank You to modernbeat For This Useful Post:
Zer0 (07-19-2016)
Old 07-19-2016, 02:31 PM   #527
slicktop
To reiterate. I have an Emtron EMS in my 2JZ swapped FRS. Everything works. Emtron is a verified solution. I believe Haltech and obviously Motec are also answers.
-slicktop
2013 Scion FRS
slicktop is offline
The Following 3 Users Say Thank You to slicktop For This Useful Post:
cf6mech (07-19-2016), CxG (07-19-2016), wparsons (07-19-2016)
Old 07-19-2016, 05:20 PM   #528
boomslang
Drives: Toyota
Please listen to this! I have the FR-S waiting along with an Emtron...I just need the Vorshlag kit hard parts.
Old 07-19-2016, 05:45 PM   #529
Zer0
Drives: 2015 frs
Thanks for the update. Once I get the current quote I will be buying it from your shop. I figure you should reap the rewards for putting in the work figuring out what transmission fits best. received a email with the old price and that's about what I expected. Can't wait to get it ordered.
Zer0 is offline
Old 07-20-2016, 08:09 PM   #530
wooly35
Drives: 2014 Scion FR-S LS3
Oh this makes me so happy! I've been waiting patiently for this kit to come out. LooKS like I need to be contacting vorshlag soon.
2014 scion FR-LS3 lol
wooly35 is offline
Old 07-21-2016, 05:55 AM   #531
Zer0
Drives: 2015 frs
I received a quote with updated pricing shipped along with pricing on the master cylinder,and hydraulic throwout bearing assembly. Thanks @modernbeat for the information will be placing my order for those parts Monday.
Zer0 is offline
The Following User Says Thank You to Zer0 For This Useful Post:
wooly35 (07-21-2016)
Old 08-06-2016, 03:33 AM   #532
Zer0
Drives: 2015 frs
I ordered the transmission and throwout bearing assembly from Vorshlag. It will take two weeks to put everything together is what I was told, then it will ship. I'm waiting on pricing for the master cylinder hopefully I can pick that up shortly. They have to fabricate parts to fit it to the FR-S. I'm just waiting for a quote on off the shelf parts and the materials and time for the fabrication of the custom parts.
Zer0 is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 02:19 PM
