Old 06-28-2016, 08:26 PM   #2423
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by BRZHarley View Post
On the topic of the Whiteline bushings and endlinks...
I recently installed a Whiteline 20mm bar with the new greaseless bushing, I decided to try them out and they work great! Greasing them isn't going hurt to anything either...
The clunky noise on the other hand drove me nuts for a week until I determine the cause... The Whiteline bar comes with a nice thick epoxy coating, I found that the coating was preventing a good tightening of the end link to bar connection. The end link to strut was just fine... My resolution was to use an abrasive pad on my air grinder to remove the excess coating around the hole on the bar, took about 5 minutes per side. Once my sons and I cleaned up the bar and retorqued the end end link the clunking was gone and hasn't come back!
Good luck,
Ed
Did you actually torque to spec or just nice and tight? If to spec what was it?
Old 06-28-2016, 08:56 PM   #2424
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Flinch
The first time I did it to spec.... Normally would not have as 40 years of experience spinning wrenches suggested otherwise...
The next two attempts were Ball Busting tight... They failed as well until the expoxy was removed on the finial attempt.... ��
Ed
BRZHarley is offline   Reply With Quote
The Following User Says Thank You to BRZHarley For This Useful Post:
finch1750 (06-30-2016)
Old 06-30-2016, 04:00 PM   #2425
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What are you guys using for camber plates? I've been using the stock tophats on my Tarmac 2's, but think it's time to get some good plates soon. I've heard good things about Raceseng, but they're so damn expensive. Ideally, I'd like something with adjustable caster that doesn't raise the ride height.
smg1138 is offline   Reply With Quote
Old 07-02-2016, 03:52 AM   #2426
AFRichZC6
AFRichZC6's Avatar
I'm actually in the market for camber plates as well. I saw you were looking for the HVT plates in another post.
This is the only place I found that still has HVT plates:
http://www.brz-parts.com/hvt-brz-camberplate.html
Also look into the Ground Control camber plates.
I'm not too worried about raising the ride height too much so I'm considering the ones from Vorshlag.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
smg1138 (07-02-2016)
Old 07-02-2016, 05:12 PM   #2427
bslate3
Drives: 2015 CWP BRZ
The Vorshlag camber plates are engineered well with extra positive caster built in. I had them on my WRX and loved them. I'll get some for my BRZ when I can afford to get some coilovers.
bslate3 is offline   Reply With Quote
Old 07-02-2016, 08:19 PM   #2428
redlined600
redlined600's Avatar
Drives: Fr-s
I really like the vorschlag camber plates as well. Racecomp claims there is plenty of travel but I have yet to verify I'm getting 100% of whats available. I have t2s s well, 450lb springs in front.
redlined600 is offline   Reply With Quote
Old 07-05-2016, 12:17 PM   #2429
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I have the Vorschlag plates...nice quality, huge range of adjustment, upper uniball mounts appear to be very high quality
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
smg1138 (07-05-2016)
Old 07-05-2016, 12:56 PM   #2430
smg1138
smg1138's Avatar
Do the Vorshlag plates reduce suspension travel? And if so, by how much?
Old 07-05-2016, 01:04 PM   #2431
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Can a camber plate reduce travel? Is that a thing?
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 07-05-2016, 02:02 PM   #2432
smg1138
smg1138's Avatar
From my understanding, most camber plates that mount from underneath raise ride height some. How much though, I'm not really sure.
Old 07-05-2016, 02:17 PM   #2433
e1_griego
e1_griego's Avatar
Drives: Many
IMO, the trick with camber plates is making sure they come with that radial bearing in the upper spring perch so that the spring can rotate independently of the shaft of the shock.
The Voshlag and Raceceng both have that, and GC plates have their own method of dealing with that though I'm not sure for which spring diameters.
e1_griego is offline   Reply With Quote
Old 07-05-2016, 02:28 PM   #2434
redlined600
Drives: Fr-s
Technically, no. But they can move the mounting point which trades bump travel for droop travel. Since most are lowering the car they give up even more bump travel. That's when it becomes a problem. This is all dependant on many variables, shock body length , ride height, spring rate, bumpstop length, camber plate mounting height is just one small piece of a larger puzzle.
The Following 2 Users Say Thank You to redlined600 For This Useful Post:
jbailey8748 (07-05-2016), strat61caster (07-05-2016)
Old 07-05-2016, 02:30 PM   #2435
jbailey8748
Good answer. +++
Old 07-06-2016, 10:52 AM   #2436
xwd
All things being equal with spring perch height, the traditional plates that go under the shock tower and attach the top of the shock there which ends up raising the car. So you have to lower the spring perches to get back to the lowered height, which is reducing travel. The Vorschlag are pretty traditional plates so they fall in that category.
Other plates like the HVT and those that come with the KW Clubsports mount the top of the shock above the tower so they don't raise the car at all. The Raceseng plates are domed a bit so they don't raise it much. Ground Control really is doing the same thing, just above the tower. I've looked into building a plate to use with the GCs so you can lower the car by raising the shock mounting even higher without reducing travel.
The Following User Says Thank You to xwd For This Useful Post:
smg1138 (07-06-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
