Old 06-26-2016, 02:59 AM   #29
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by nikitopo View Post
If your dealer told you that someone tried to flash your car with a COBB tune, you have to believe him. He knows something more than us. I would expect that someone in the tint shop did this and now they're trying to hide the truth. Obviously, they wanted to flash the car and go for a ride and have some fun going sideways. They were stupid because COBB creates tunes only for FI engines and there is no tune for our cars. They saw that it is a Subaru, but they didn't think it is not an STI! So they flashed your car with an incorrect tune. The easiest solution would be to find the guy with this COBB accessory and re-flash the original factory tune. Your factory tune is stored there. This will cost you nothing. Otherwise, good luck installing a new ECU unit from the factory? By the way, I am not sure how you could see this in the surveillance video. You alter the tune when you are inside the car. There is a port under the steering wheel. You don't need to open the engine or do anything else.
You have no clue what your saying, most of the techs are clueless, they simply diagnose an issue like a mechanic then look at a factory service manual to confirm. Sometimes they can't even do that because they know it will cost that franchised shop a bit too much and SOA won't pay. Also a cobb accessport literally won't flash a a file over to our ecus it won't get past the first tests to write it over. 0 values are being read most likely due to a damage wiring harness and the dealer has a preconceived notion about the BR-Z and the WRX STi immediately blaming it on a modification
The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Atropine (06-27-2016), brandonblt2 (06-27-2016), Jordan Silveira (06-26-2016), SK86 (06-27-2016)
Old 06-26-2016, 03:16 AM   #30
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
Thank you so much! I will definitely see if maybe I can redirect there immediate thoughts of a tune/flash to the engine wiring harness. If you don't mind me asking, you seem to know more than I would about why it would be producing "0's" and such. Is it possible to have a "2015 BRZ profile or tune" or whatever the service manager is claiming? Also what about the fact he's claiming I have calibration ID's and such that don't match?
Jordan Silveira is offline   Reply With Quote
Old 06-26-2016, 03:20 AM   #31
tyrantcf
Drives: '16 WRX, CBR1000RR
You don't have a Subaru problem, you have dealership problems. Take it back to the dealer that sold the car and get a real inspection done. I'd bet money you have a damaged ECU or something affiliated with it. If the Glendale dealer gives you the same runaround, I'd get SOA involved immediately if you haven't already.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 06-26-2016, 04:03 AM   #32
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
For sure there are bad and good technicians, but don't you think they have ways to find out if a car was flashed? They also mentioned that the calibration IDs are different. Check the comment below. I am not sure if a COBB flash can pass the first tests or not. Have you ever tried?
This is the main reason I believe this is what happened. How the dealer knew that the flash was made using a COBB unit and not something else? If he cannot provide a proof of this, then check if your ECU has an issue.
Old 06-26-2016, 04:47 AM   #33
steve99
Drives: FT86
If the dealer said a brz or 86 has a cobb tune its BS, cobb dont tune brz/86. The 86/brz ecu is different to wrx or wrx sti. the processor is different
FRSBRZGT86FAN (06-26-2016)
Old 06-26-2016, 05:08 AM   #34
steve99
Drives: FT86
If the dealer can read the ecu calid and the CVN then the ecu is working.
The zero values the dealer is talking about is likely whats shown below , shoen is toyota techstream diagnistics. all the se counters get reset on flat battery , battery disconnection, or if ecu us reset of reflashed.
This is normal and does not effect operation.
subaru SSM diagnostic toll shows similar counters/timers in ecu.
Old 06-26-2016, 07:13 AM   #35
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Your car couldn't start after the tint work.
If you tinted the windshield, was it possible that the tint shop did short-circuit your ECU? Because the ECU is located below the dash near the firewall, the water/solution used during the tint process might drip down pass the gap between the windshield and the top of the dashboard and reach the ECU/harness. Just a thought.
Spec C Wannabe is offline   Reply With Quote
The Following User Says Thank You to Spec C Wannabe For This Useful Post:
Braces (06-26-2016)
Old 06-26-2016, 10:44 AM   #36
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In any case I wouldn't like to be in such a situation. I hope this guy to find a solution quickly ...
Old 06-26-2016, 10:45 AM   #37
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Agreed. That's a more plausible explanation. Laughing at the idea that the tint guys just decided to install an improper tune on your car to do burn outs while you waited in the reception area.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
The Following User Says Thank You to Braces For This Useful Post:
Summerwolf (06-26-2016)
Old 06-26-2016, 10:50 AM   #38
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I never heard tinting the front windshield. Is it legal in U.S.?
Old 06-26-2016, 11:01 AM   #39
BRZnut
Drives: BRZ DGM Limited
Are you 100% sure the battery is ok? Does the key on the dash turn green when you get in the car and press the brake?
Old 06-26-2016, 11:48 AM   #40
FRSBRZGT86FAN
@steve99 can answer better than I can but this should explain it and should call him to the thread:
http://www.ft86club.com/forums/showthread.php?t=62332
Your ecus cal id should be something like ZA1JF something something something
If it were a 2015 calibration id it'd have something like ZA1JD something something something or the like, theres no real way to prove this without someone having an OFT or tactrix cable or a techstream laptop and cable to confirm what the dealer is saying.
I've used tech stream before values of zero only really appear when theres a power interruption or reflash, I think the tint shop pulled the battery just in case or alternatively the wiring harness is loose or came loose. If the dealership read the cal they have a stable canbus connection.
Edit: Looks like steve99 already answered
Old 06-26-2016, 11:57 AM   #41
FRSBRZGT86FAN
They don't have a way unless they truly owned one that was tuned for quite some time then you could tell a difference in sound or idle.
If it's a rom it's essentially hidden from view also our cars have no flash counter, and it's essentially at it's core just an edited stock tune file. To find it the ecu would have be sent to japan or the like to have a serious investigation and tear down of the code done. Techstream or the Subaru equivalent can't even begin to look into it.
If its an ecutek tune, the ecu is locked, and they wouldn't have been able to read jack shit including those 0 values or cal id.
You're not being very helpful in this thread, you may be out of your depth. If you even have a semblance of tuning knowledge you'd know a cobb accessport can't interface in any way with our ecus, it can only communicate currently with the WRX, WRX sti, GT-R, Volkwagen ECUs and ford ecoboost ecus and the like. It would simply show a vehicle not supported. Also COBB is literally only focusing on forced induction vehicles they have nothing and will have nothing for the FR-S
Old 06-26-2016, 12:56 PM   #42
Side
Side's Avatar
Drives: 2018 BRZ tS
I had my front windshield UV tinted. It's a clear tint purely for heat reduction. Not sure about OP though.
Side is offline   Reply With Quote
Subaru trying to deny my warranty please help! Jordan Silveira Issues | Warranty | Recalls / TSB 21 06-30-2016 09:30 PM
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Subaru gold plus ext. warranty MObrz5 Northern California 9 04-10-2014 04:08 PM
Subaru Warranty Question Sovran BRZ First-Gen (2012+) — General Topics 3 06-04-2012 11:59 AM
Scion Warranty +1yr vs Subaru.. MarkRacerX Scion FR-S / Toyota 86 GT86 General Forum 13 04-24-2012 10:01 AM
