Old 06-25-2016, 07:21 AM   #253
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by Gopherboy6956 View Post
Anyone having issues with their Serp. Belt walking 1 notch off the pulleys?
When i went to replace my squeaky belt (seems to be annually) it was 1 spline off (towards rear of car) so i put the new one on, got it all situated and checked it over the next few weeks - was good to go.
This last weekend i was racing, and was just checking around the SC (it get's spitty out the vent when on the road course) and i noticed the belt had walked back 1 notch again.
I figure there must be some slight alignment issue, but i dont know what on earth a guy can adjust to make this stop happening. Any ideas?
This only happens on the crank pulley and the water pump pulley.
(Photo shows new belt installed correctly for reference)
Hi and welcome to the club.
If you are completely sure everything is aligned, then and only then this apply.
At first I tough it was due to down shifting, but isn't. Is due to up shift and the rapid deceleration on engine and sc speed (the tensioner isn't desing to work both ways). So know you now what's going on, if need to know how to fix it, pm.
AJPG is offline   Reply With Quote
Old 06-25-2016, 10:11 PM   #254
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Ah, what?
And yes, i'd love to know how to fix it - can't you post it for all to see?
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 10-17-2016, 07:43 AM   #255
rak.yury
Drives: gt86
Size of intercooler
Guys, could some tell me size of kit intercooler, just bought used kit and no intercooler in box( So looking for some alternative mishimoto or greddy universal coolers. Thanks
rak.yury is offline   Reply With Quote
Old 10-17-2016, 09:31 AM   #256
DJCarbine
Thupercharged
DJCarbine's Avatar
While I've only had this issue once, I'm curious as to your fix
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-17-2016, 05:57 PM   #257
rak.yury
Drives: gt86
Vortech v3 with 3.125'' pulley
Hi guys,
I gonna setup v3 with 3.125'' pulley at 93, stock fuel system, tomei uel hearer, catted front pipe, mishimoto radiator, mishimoto oil cooler. How much whp can I get with this config?
Thanks.
Old 10-24-2016, 04:07 PM   #258
Cal3000
Drives: Panda FR-S
Originally Posted by rak.yury View Post
Hi guys,
Thanks.
Safely, I'd say 275-290whp
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-24-2016, 04:11 PM   #259
Gopherboy6956
Hi guys,
Thanks.
For Reference - I'm running stock pulley, Full Headerback exhaust and stock fuel system.
On 91 I maxed out at 275whp and 199tq.
I also have a smaller pulley (can't remember specifically, just one step smaller) but I ran out of octane on 91 to gain any more power.
Also - I did shred my stock clutch when i was running the stock Perrin tune with the SC, so prepare to replace that with an upgraded unit.
Old 10-24-2016, 08:30 PM   #260
DJCarbine
Thupercharged
DJCarbine's Avatar
How long did your clutch last? 25k on mine and still holding fine with the smaller pulley
2013 FRS
Vortech V3 11psi
Old 10-24-2016, 09:07 PM   #261
Gopherboy6956
I could feel it slipping on the Dyno when i got 275whp - i replaced it a few weeks later and it was just clutch dust city in the bell housing.
I had about 11k on it then. But, I have been AutoX'ing and Road Course-ing my car since day 1.
Old 11-16-2016, 12:41 PM   #262
Thehark1
Drives: '13 BRZ
Hey guys, looking at getting the vortech kit myself. I bought my car with the Perrin inlet hose already installed. Still has factory air box and everything. There was mention of the vortech kit needing to mate to the OEM inlet tube (I think this is the snorkel?)
Is this true, do I need to buy an OEM inlet hose, or will it mate up with the Perrin hose? The Perrin hose fits snugly over the connection to the stock air box if that is worth anything
Thehark1 is offline   Reply With Quote
Old 11-16-2016, 12:42 PM   #263
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Nothing is shared with the stock intake.
bee_are_zee is offline   Reply With Quote
Old 11-16-2016, 12:43 PM   #264
Gopherboy6956
No. The Vortech kit comes with it's own Air box and doesn't require any stock parts for the airbox.
[IMG][/IMG]
Old 11-16-2016, 12:51 PM   #265
Thehark1
Drives: '13 BRZ
[IMG][/IMG]
Thanks! Did you install yourself? I'm not very proficient at working on cars (haven't done anything beyond replacing rotors and pads). Would you recommend trying to install myself or getting a pro to do it?
Old 11-16-2016, 01:08 PM   #266
Gopherboy6956
Yep. Did it in my garage over a weekend. But, then again I also:
Replaced stock clutch
Replaced Radiator with bigger one
Replaced all radiator hoses
Installed an oil cooler
Installed catch cans
All at the same time, so it definitely took me longer that just the SC. I HIGHLY recommend an oil cooler if you do this.
But, overall It's really not much more than nuts and bolts. The hardest thing is routing all the plumbing for the Intercooler, just getting everything to sit in the correct place.
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
