Drives: Toyota GT86
Adjustable swaybars... what do you have set?
Though a package/preference thing, I am curious how you are running your adjustable anti-swaybars.
I have complete ST suspension. ST XTA coilovers (ST's "KW V2" version, not the more well known ST X) with 6.0 kg/mm front (336 lbs/in) and 5.0 kg/mm rear (280 lbs/in). The swaybars are solid 19 mm front and 17.5 mm rear, with a soft and hard setting. Tires AD08R 225/40R18 At the moment I have both front and rear in the soft setting. I am considering to set the rear in the hard setting, but I have limited track time to experiment at the moment and would rather focus on the driving when there. How do you have yours set? Perhaps we could follow the same basic format: Coilovers: ST XTA - (6 kg/5 kg front/rear, mention if not well know) Tires: AD08R 225/40R18 Swaybar(s): ST (19/17.5 mm, mention if not well know) Setting: Soft/soft
#2 |
What kind of event are you running?
#3 |
Drives: Many
What are you trying to fix?
#4 |
Drives: Toyota GT86
Thanks for your help!
Track days. I live quite close to Zolder circuit and went there twice so far. Both previous times was on Pirelli P Zero Nero GT, so I don't know what impact the AD08Rs may have on the handling. I am going there next week again and didn't plan to change the swaybars from the soft setting so far. I also live close to Nürburgring and might want to go there in the future (drove a few rounds on the Grand Prix circuit). I'm not sure, but my feeling on the road is that the car got more understeer with the AD08R. Would that make sense, or am I just imagining things? I don't know if video is any help in seeing how the car behaved on the Pirelli, but here is a link anyway (from 6:25, the first part is me spinning around and stuff, so you can skip that part ):
#5 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Shneegle (06-16-2016) |
#6 |
Drives: 2013 FRS, 2024 Trueno
Before buying a new rear bar change the front to stock bar and see how the car responds. Since you are getting understeer you want to stiffen the rear. If your gonna buy another sway then listen to CSG Mike above.
My current setup Fortune 500 Coilovers: 8kg/7kg 7 clicks front and 0 clicks rear Whiteline adjustable sways: 22mm/16mm Stiff/soft Tires: Was on Hankook RS3 V2's before this last track day which I was on hoosier A7's.
![]() Last edited by Shneegle; 06-17-2016 at 06:47 PM. |
#7 | |
Stiffening the front will improve initial response, but also cause the front to load even faster, amplifying the understeer. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Racecomp Engineering (06-17-2016) |
#8 |
Drives: '13 FRS - STX
To the OP, assuming everything else is set and sways really are the final tuning point of your setup (not alignment, damper settings, tire pressures, spring rates, etc.) I'd go back to the stock front given what you describe, softer front = more grip in a basic sense.
Unless of course the soft hole means your 19mm ST bar is softer than OE. |
#9 |
Drives: Toyota GT86
Thanks for the input.
The swaybars that I have are adjustable and at the moment both in soft. Alignment should be good: -2.5 front, -1.8 rear and toe in 0.02 inch front 0.04 rear. Tire pressure around 34-35 psi hot all round. Dampers (combined rebound/compression) set at 6/16 front and 7/16 rear. I will leave all as it is and go to the track day next week (3 x 1 hour track time with breaks in between). Maybe I am just confusing the enormous grip of the AD08R (compared to the 3 years old Pirelli). The rears just grip no matter what I do with the throttle. Where I felt push was in the following situation: Empty country road, tight hairpin and going early on the throttle (to provoke a slide). Previosly the rear would have come around, but the AD08R just grip and push the car over the front wheel for a split second, the they gripped too and the car just went around the hairpin. The road was pretty dirty, so maybe thats played a part too. I guess I need to drive it proper on track to get an real impression. Maybe I will play with the dampers and set the front softer and the rear stiffer. Do you think that would help? Or maybe set some toe out in the front?
#10 | |
The toe change is real but I never felt it behind the wheel. |
#11 | |
The Stig's German cousin
I would wait to properly evaluate the balance at a track where you can drive 100%. The rear is pretty easy to reach and adjust at the track, you don't even need to remove a wheel. In my opinion you have too large a rear bar compared to your front bar, but if you don't like the way it currently drives AND going stiffer in the rear makes you faster, more power to you.
#12 | |
Drives: Toyota GT86
I will leave the swaybars in soft and drive it on track and wait and see. I have 3 x 1 hour sessions, but I don't think I will change the them on site. I'd rather relax in between and focus on the driving. At most I will play with the dampers and maybe, as @strat61caster suggested, front camber. It should be easy too with the top mounts and I know center is -2.5 and most is -3.5. Can I expect them to adjust linear in between, so that e.g. halfway towards max is -3.0 deg? Thanks again.
#13 |
Indeed, thought he was talking about the issue of spinning. Lets say I was reading what i wanted to I guess.
#14 |
Drives: Toyota GT86
I had my trackday and got to try out the AD08Rs. I was a bit disappointed about the difference to the Pirelli Zero Nero GT. Maybe I was expecting too much, or the Pirelli are not that bad?
There was a noticeable difference in car behaviour though. Just like I felt on the street it initially seemed to push more in slow curves. I adjusted my dampers to 5 click front and 4 clicks rear (previously I had the other way around and a bit softer - 6 front 7 rear as far as I recall). And that seemed to do the trick! I don't know if it's just psychological, but the car seemed to rotate way better. So I will leave the swaybars as they are in their soft settings. ![]() Tire temperatures were somewhat in the ballpark. I guess it could use a bit more camber both front and rear, but I will leave it as it is since the car spends quite a bit time on the streets as well. I improved my best time from 2:08 to 2:03. I don't put that on the AD08R, as much as I would put it down to me getting more familiar with the track, braking later, driving the chicanes faster, finally starting to get more of a grip on trail braking and generally taking a better line. Here is my best lap (the speeds in the corners are very inaccurate due to using my Phones internal GPS): [ame]http://www.youtube.com/watch?v=H-0tS8JGzdU[/ame]
| Godspeed swaybars | venturaII | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 41 | 11-02-2016 04:55 PM |
| Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear | deedz | Brakes, Suspension, Chassis | 11 | 03-17-2015 03:29 AM |
| Swaybars for sale.. | timlewis82 | Brakes, Suspension, Chassis | 1 | 11-02-2013 05:59 PM |
| What Swaybars are you running? | Mark_Dorman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 10-22-2013 03:03 PM |
| What thickness are the TRD swaybars? | jehu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-06-2012 10:46 AM |
