Old 06-22-2016, 04:26 PM   #2619
Leland
Drives: BRZ JDL uel headers oft Perrin 2.5
Originally Posted by Summerwolf View Post
False.
If you live in a state where all they do is the OBD2 test you can pass pretty easily so long as your CEL is tuned off.
I guess that I don't want to fool someone into thinking it is okay, I actually want it to be okay. When I read the description of the catted speed factory headers I got the impression that this was the case. Apparently not.
Leland is offline
Old 06-22-2016, 04:27 PM   #2620
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
False.
Actually, if you turned off aka "Not Ready" your O2 sensor, some state will not pass the emission... EVEN they don't do visual checks.
ichitaka05 is offline
Old 06-22-2016, 06:53 PM   #2621
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
He is mostly talking about moving or replacing with a non factory cat. If you used a catted header and stock everything else you would have multiple cats. Still cleaner emissions than 90% of vehicles on the road and no CEL.
Eh, do some research. It does vary state by state but obd2 test states generally pass anything that doesn't have a CEL. There are certain parameters that will pass and not trigger even the state OBD2 scanner. You are allowed to have a certain number of systems as "not ready" and still pass. It is easy to pass a car when they do the obd 2 test only.
Summerwolf is offline
Old 06-22-2016, 07:16 PM   #2622
Leland
So it is accurate to say that only the factory cat is acceptable to the state no matter how it actually functions?
Leland is offline
Old 06-22-2016, 07:22 PM   #2623
Summerwolf
Panda Trueno
Summerwolf's Avatar
No. There are loads of exceptions.
Old 06-22-2016, 07:45 PM   #2624
ichitaka05
Site Moderator
ichitaka05's Avatar
So TLDR; get aftermarket header at your own risk. Read the state emission and law. Cuz where Summerwolf lives, he/she can get away not having a cat and tuning it out w simple plug in OBD2. Where I live, they do both OBD2 & visual. If they see "Not Ready" in any o2 sensors, they will not pass.
Old 06-24-2016, 08:46 AM   #2625
Leland
Are the speed factory catted UEL headers one of them?
Leland is offline
Old 06-24-2016, 09:39 AM   #2626
Summerwolf
Panda Trueno
Summerwolf's Avatar
You would have to check with NM emissions laws as to what they require to pass a car.
In my state I can run catless so long as no codes were thrown when they scanned through the OBD II port.
Old 08-11-2016, 05:37 AM   #2627
Varelco
Drives: '15 GT86 & '22 GR86
How many people are running this header with a complete exhaust system on the stock map? I currently have a Perrin 2.5" resonated catback mated to a Fujitsubo decatted dual resonated front pipe and have been thinking for a while about getting this header to go along side this set up. The thing is I want to avoid remapping for warranty reasons, last time I had my car on the dyno the AFR looked nice a healthy.
Another thing is noise, does the volume increase much with the header attached to aftermarket exhausts? I love the level of noise now, I wouldn't want it to get much louder.
Varelco is offline
Old 08-11-2016, 06:23 PM   #2628
Vash
Drives: Whiteout FR-S
I was happy with the sound level before getting mine too (axle back and catted front pipe), but after getting this header, it doesn't sound much louder on the inside of the car, but it definitely sounds louder on the outside, in a good way IMO. I'm very happy with it. I am using OFT though, but I doubt that changes the sound of the exhaust.
Vash is offline
The Following User Says Thank You to Vash For This Useful Post:
FT-86 SpeedFactory (08-15-2016)
Old 08-11-2016, 06:30 PM   #2629
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
If your modifying your car and worried about warranty. You're doing it all wrong. Even w/ a catted header. It will throw a CEL and your car will run like shit w/o a tune.
To answer your other question. I had this header with a full perrin exhaust and I loved it. It was deep and didn't sound raspy.
Chen is offline
The Following User Says Thank You to Chen For This Useful Post:
Old 08-16-2016, 08:07 AM   #2630
Varelco
Thanks for your input guys
Varelco is offline
Old 08-16-2016, 11:39 AM   #2631
novice
novice's Avatar
Drives: Fr-S 2.0 Release
Just ordered this along with the resonated catback for my 2.0. wish me luck
novice is offline
Old 08-29-2016, 03:48 PM   #2632
DieselxIndustry
Drives: 2013 Firestorm FR-S
I'm leaning towards getting the catted version with an AVO front pipe and my Perrin 2.5 overpipe and catback. Still need to get an OFT. Trying to avoid spending 1k on it though. hopefully another used one pops up on the FS section
DieselxIndustry is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
