Old 06-21-2016, 01:44 PM   #1
Amillionoh7
Amillionoh7's Avatar
Drives: 13' Raven FRS n 92 Camaro
color change carbon vinyl interior
picked up some vinyl and gave it a shot. never tried to wrap anything before. came out pretty good and was fairly easy
Amillionoh7 is offline   Reply With Quote
Old 06-21-2016, 04:19 PM   #2
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
It looks really good. Did you mean to switch the weave direction on the passenger side?
iamjacob is offline   Reply With Quote
The Following User Says Thank You to iamjacob For This Useful Post:
Amillionoh7 (06-22-2016)
Old 06-21-2016, 05:05 PM   #3
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Looks good. I'm looking to wrap mine as well to add a bit more color to the interior.
Letter from a Thief by Chevelle is a great song too
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
Old 06-21-2016, 05:09 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
where did you order the vinyl from?
Dr. BRZ is offline   Reply With Quote
Old 06-22-2016, 08:42 AM   #5
Amillionoh7
Thanks. yes i did switch pattern thinking it would show the color change better and it also makes triangles like the rest of the car is littered with. I bought it from amazon. Its VIVID was like 22$ for 5ft x 2ft
Old 06-22-2016, 08:52 AM   #6
Amillionoh7
tried to wrap my xbox controller last night. did not work. I could not keep the edges from wrinkling.
Old 06-22-2016, 10:32 AM   #7
Mazikowski
Drives: 2013 GBS BRZ Limited
Dragon Laminates has a few similar products:
http://www.dragonlaminates.com/drago...rbonfiberwrapz
Mazikowski is offline   Reply With Quote
Old 06-22-2016, 10:38 AM   #8
Amillionoh7
look by the heater vent in the corners you can see air bubbles and the vinyl is pulling away
Old 06-22-2016, 11:58 AM   #9
Mazikowski
Haha, I hadn't even noticed that. One of the downsides of wrapping interior complex curves. I'm sure there's some sort of adhesion promoter that could be used to fix that, though.
Which Color Vinyl Wrap on RS 1.0? iNcontroL Cosmetic Modification (Interior/Exterior/Lighting) 39 10-24-2014 09:55 AM
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
vinyl interior NYCsubaruBRZ NY / NJ / CT / PA 7 08-24-2013 03:24 AM
Decided to change up my vinyl today. Area86 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-28-2013 10:58 PM
