Old 06-18-2016, 10:13 PM   #43
dp1
driving smoother faster
Drives: Sold
Tried CSG settings this afternoon and like them better. JRZ USA recommendation was supposed to be a starting point and it's very good but not as good as the recommendation I got from @CSG Mike. Handling is now perfect, tested by me and by the NASANE instructor (twin owner) driving my car with me in it. Amazing balance with just a touch of oversteer exactly where it's appropriate. On almost worn and fast Nitto NT01 and camber/toe specs from my build page. Tomorrow morning Toyo RR racer take offs with 8 heat cycles are replacing nittos...will be a fun day.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (06-18-2016)
Old 06-18-2016, 10:56 PM   #44
CSG Mike
CSG Mike's Avatar
I read that initially as "[i]NaSANE" instructor.... :rofl:
dp1 (06-19-2016)
Old 06-21-2016, 04:27 PM   #45
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
hey dp1, post the video if you want. I want to see how it looks. (I'm the instructor driving)
subielife is offline   Reply With Quote
Old 06-21-2016, 07:28 PM   #46
dp1
Drives: Sold
Hi bud, I have it on video, will publish when I'm done editing
Old 07-23-2016, 09:26 PM   #47
dp1
Drives: Sold
Here it is:
[ame="https://www.youtube.com/watch?v=8MipiH1jO8g"]2016-06-18 NJMP Thunderbolt NASANE Instructor group [2014 Scion FR-S] - YouTube[/ame]
The Following 2 Users Say Thank You to dp1 For This Useful Post:
CSG Mike (07-24-2016), subielife (07-26-2016)
Old 07-24-2016, 12:43 AM   #48
86Tony
Drives: 2015 AOZORA EDITION
how do kw 3 way clubsports compare to these setup posted by OP?
86Tony is offline   Reply With Quote
Old 07-24-2016, 03:02 AM   #49
CSG Mike
CSG Mike's Avatar
They're not in the same league; @dp1's 2 way dampers cost more than the 3 way KW.
Old 07-31-2016, 12:26 AM   #50
.RYAN
AWOLBRZ
Drives: 2017 BRZ
How do the CSG spec Tein SRC compare to the JRZ RS Pro?
.RYAN is offline   Reply With Quote
Old 07-31-2016, 07:06 PM   #51
CSG Mike
CSG Mike's Avatar
Apples and oranges. One is a highly customized entry level race damper. The other is a very high end street damper. They both have their pros and cons, and it depends on your application.
Old 02-17-2017, 07:42 AM   #52
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
The src are an entry level race damper? Is that why it's harsh for daily driving?
SuperDave is offline   Reply With Quote
The Following User Says Thank You to SuperDave For This Useful Post:
byun (02-17-2017)
Old 02-17-2017, 09:54 AM   #53
CSG Mike
CSG Mike's Avatar
The damping profiles and nitrogen pressures are different, which is where the street ride quality differences primarily originate from.
SuperDave (02-17-2017)
Old 02-17-2017, 05:13 PM   #54
SuperDave
SuperDave's Avatar
How similar are the dampening profiles and nitrogen pressures in the csg tein src and jrz rs2?
Old 02-18-2017, 09:06 AM   #55
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Could someone help me understand the physics involved here that enable much quicker lap times by upgrading to a high end suspension setup. Is it as simple as keeping a consistent contact patch or is more involved.
I'm currently still running base level BC coils that I installed early on when the car was still an experiment that I wasn't sure would pan out. Now that I'm fully down the rabbit hole I'm reconsidering the suspension but I'd like to understand why the upgrade works so much better.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 02-19-2017, 08:03 AM   #56
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
It will be able to control firmly body movements while keeping a very good contact patch for the tires.
So precise control of sprung and unsprung masses at the same time.
It will be able to suck big bumps while doing the 2 previous things.
It will be able to do all that with very high spring rates.
It will be able to do all that while being reliable.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Double oil cooler kcam86 Tracking / Autocross / HPDE / Drifting 16 05-20-2016 09:46 PM
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
sorry double post LS13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-29-2012 02:42 PM
Double U T F...is this for real? Hawk77FT AUSTRALIA 20 07-14-2012 05:21 PM
