Old 06-20-2016, 02:48 PM   #1373
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Yes, I'm currently back on the CARB tune right now. I was running the DT tune for a while, and although it runs great at the track, the fuel economy is a bit lacking for daily driving. I've seen a 2 mpg difference (mostly city) between the two.
Also, @sales@delicioustuning.com can correct me if I'm wrong, but I believe the additional D-box is compatible with the CARB tune since its really just a "filter" to smooth out the MAP signal.
The D Box is compatible with all Edelbrock tunes, not just ours and the CARB tune.
-Zach
Old 06-20-2016, 03:28 PM   #1374
Colin86
Drives: 86
Is it still possible to bleed the clutch after the s/c install without removing the blower etc? Wondering if a remote bleeder is a must or a nice to have...
Colin86 is offline   Reply With Quote
Old 06-20-2016, 03:33 PM   #1375
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I've done it with the blower on, but with a lot of cursing and dropped wrenches (pro tip: stuff a bunch of rags down there before doing anything to both catch any fluid spills and tools that you WILL drop lol).
With that said, a remote bleeder isn't a must imho, but definitely a nice to have.
Old 06-20-2016, 03:41 PM   #1376
Colin86
Drives: 86
Anyone have links to recommended remote remote bleeders?
Am getting ready to pull the trigger, but am waffling on whether or not to try out the additional D box from DT...
Old 06-20-2016, 03:45 PM   #1377
trd87t
Drives: Supra, BRZ
x2
because... well... i just jumped off the deep end yelling *cannon ball*
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 06-20-2016, 04:16 PM   #1378
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
-Zach
Zach - sorry for my confusion, but does this D-box work without flex fuel, and is only one needed? the 'double D' and 'additional D box' implies that you need two.
so, for someone who is not running flex fuel with the E-force on the CARB tune, what do they need? one D-box?
shiumai is offline   Reply With Quote
Old 06-20-2016, 04:50 PM   #1379
Heist
Heist's Avatar
Drives: 10 Series
4) I've been also interested based on DT's recommendation. I've been experiencing jerky daily driving and have seen the weird MAP fluctuations on my logs, so it maybe beneficial to improve driveability, but I could not justify the price for the tiny bit of hp gain.
How do you figure not justifying the price? The supercharger is $4350/100hp, while the double d unit is $125/10hp. $43.50 per HP vs $12.50 per HP.
I had a tune done with mine so I can't compare with and without. It's been smooth since I broke in the new clutch. I don't think I'm experiencing any of the jerkiness you're seeing.
Sent from my Nexus 6P using Tapatalk
Heist is offline   Reply With Quote
Old 06-20-2016, 05:07 PM   #1380
BigFatFlip
BigFatFlip's Avatar
Originally Posted by trd87t View Post
x2
From earlier in this thread built by @Nitro22: http://www.ft86club.com/forums/showp...&postcount=200
It was more the circumstances at that time: I was very happy and content with the CARB tune. I later bought JDL headers and the DT tune to compensate, but found the headers too loud (couldn't hear what little SC whine we get). Now I was back to the stock header, stuck trying to sell off a very lightly used header at a loss and a tune I technically don't need anymore. Ultimately, I'm pretty happy with the DT tune, but having to spend a little bit more to iron out the remaining little problems didn't really sit well with me. Live n learn...
Edit: As mentioned a few posts back, I'm still considering it, so its not like I'm completely writing it off.
Old 06-20-2016, 05:12 PM   #1381
DeliciousTuning
The "D Box" and our Flex Fuel kit are two entirely independent products. Our D Box works with the CARB tune, our tune, and every other tune for the Edelbrock kit. The CARB tune is not Flex Fuel and does not have the capacity to be. Our D Box can work with or without our Flex Fuel kit and tune. Two entirely different products that do not rely on each other for proper functionality.
-Zach
Old 06-20-2016, 05:15 PM   #1382
Colin86
Drives: 86
Thanks again. Sent him a PM asking about parts etc, I'll post back if he replies.
After you swapped back to your stock header what other problems did you have to iron out with the DT tune?
Edit: And did you have hesitation problems with just the CARB tune?
Old 06-20-2016, 05:20 PM   #1383
Colin86
Drives: 86
Looking at the info from your product page for the Double D box (https://www.delicioustuning.com/node/536)... which tune was used for the dyno/logs?
Any changes whatsoever on the tune for with/without the d box?
Thanks!
Old 06-20-2016, 06:27 PM   #1384
DeliciousTuning
Thanks!
The tune used on our product page is our own. There were no changes made between the logs and pulls done with and without the box. The idea behind those graphs and logs was to show the difference that the hardware made with no tune change.
-Zach
Old 06-20-2016, 07:01 PM   #1385
Colin86
Drives: 86
Thanks, have you measured any benefit from the stock CARB tune provided by Edelbrock?
Old 06-20-2016, 07:21 PM   #1386
DeliciousTuning
The benefit will be nearly identical no matter which tune you are using.
-Zach
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
