Old 10-23-2012, 05:04 PM   #57
Celica00
Celica00's Avatar
Drives: 86
As has been said numerous times: it's because the boxer is naturally balanced (moreso than inline and vee engines) and doesn't use the pulley as a harmonic damper.
unfortunately it needs repeating because...
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
OrbitalEllipses (10-24-2012)
Old 10-25-2012, 01:25 AM   #58
bpracer
Drives: Asphalt FR-S
Every time a cylinder fires, the crank throw on that cylinder is twisted as it is accelerated, every compression stroke the opposite occurs. Each time this happens, harmonic vibration are induced in the crank, this has nothing to do with the boxer engine being naturally balanced or not.
Harmonic dampers are tuned for a particular rpm range via mass of the outer ring and/or the stiffness of the rubber ring. You may be able to get by without a damper on an engine depending on the rpm range in which it operates. If you happen to operate the engine at the cranks natural frequency for a long period of time, bad things "could" happen.
On a standard V-8 engine the damper is a very tight press-fit and keyed to the crank. If they are not tight, bad things happen.
The Subaru engine pulley does not seem to be a press fit and only uses a dowel pin for locating the damper/pulley. That would cause me to believe there isn't nearly as much force acting on damper/pulley from these harmonics.
Drag racing, short(er) track road racing it may not matter at all. Buzzing down the LONG front straight at Road America near red-line for a good while might be another story.
You make your choices, you take your chances...
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 10-19-2015, 09:07 AM   #59
mister.bond
Drives: BRZ Subaru
After 3 Years now
What is going on with using the Lightweight Pulleys ???
Any Long Term News ???
Any Engine Issues while using them ???
Hope i can start this discussion again
mister.bond is offline   Reply With Quote
Old 10-19-2015, 01:03 PM   #60
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
please let's not. If you are running huge boost and modding the carp out of the car stay stock. If you are staying NA and aren't beating the ever living shit out of the car it doesn't really matter.
why? is offline   Reply With Quote
The Following 2 Users Say Thank You to why? For This Useful Post:
J-W (10-19-2015), olsonpg (10-19-2015)
Old 06-20-2016, 09:48 AM   #61
Slade
Slade's Avatar
Drives: 14 Limited BRZ
I kind of have a blue theme under my hood, if I bought a pulley that was black, can I spray paint it blue, to match my theme? Or would the paint add weight to the pulley? Maybe a dumb question, but I never considered myself a genius.
Slade is offline   Reply With Quote
Old 06-20-2016, 11:08 AM   #62
Probably add about a 100th of an ounce. Make sure you clean it up really well before painting though.
Slade (06-20-2016)
Old 06-20-2016, 01:23 PM   #63
Slade
Slade's Avatar
Thanks for the response, and you did it without giving me a wise guy answer
Old 06-20-2016, 01:25 PM   #64
Happens sometimes!
Depends on how the question was asked more than anything.
justatroll (06-20-2016)
Old 06-20-2016, 02:05 PM   #65
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Happens sometimes!
Nice guy TCoat is nice.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-27-2016, 05:18 PM   #66
team3d
Drives: brz
guys, google crank pulley damage, you will find almost 0 complains on light weight pulley, and if you click on google photos, all the damage crank pulleys you will find are stock, damped pulley.
if you drive a 30-60 years old domestic v8 ? i will not suggest 1pc pulley. for a inline 4 or boxer engine, i have not witness any engine that's damaged due to the removal of stock crank pulley
as for the power gain, are you gonna run faster with heavy shoes or lighter shoes ? even for lebron james, he can still run very fast with heavy shoes, but with lighter shoes, he will benefit more & use less energy...
who can honestly tells me, running with 20lbs back pack or wearing a 2lbs combat boots will make you run faster ?
light weight wheels, brake rotors, pulley, flywheels, crankshaft, pistons & rod all can reduce engine's energy use...
team3d is offline   Reply With Quote
Old 10-28-2016, 06:01 AM   #67
swarb
http://www.evoxforums.com/forums/showthread.php?t=50463
maybe because ALL cars come with stock pulleys?
maybe because less than 1% of cars get light weight pulleys?
Have you worn Lebron's shoes? or even picked up a pair? They're heavy! They are built for strength.
Old 12-07-2016, 07:24 PM   #68
norcalpb
norcalpb's Avatar
Doesn't an evo have an inline 4? I'd never put a lightweight on an inline 4, inline 6, v6 or a v8.
Boxer motors are super balanced as it is...they've made airplane motors for decades now.
Old 12-07-2016, 07:27 PM   #69
wbradley
Sarcastic SOB
wbradley's Avatar
Engine spins up faster when in neutral. Difference when shifting into gear zero or indiscernible.
Looks good in engine bay.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
justatroll (12-07-2016), Ultramaroon (12-07-2016)
Old 12-07-2016, 07:52 PM   #70
Lantana frs
Drives: 13 frs red
I will never use one again. Thank God Toyota didnt refuse my warranty because of it. Made the car snappier in lower gears.
Lantana frs is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
