Old 06-18-2016, 11:20 AM   #57
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by nikitopo View Post
You get approximately 2-3whp from the underdriven alternator and 5-6whp from the light pulleys. Overall +8whp.
There is absolutely NO physical reason for the LWCP to provide ANY extra HP just because it is lighter.
Just saying it, does not make it "evidence".
Please explain WHY a lighter pulley should give extra HP.
I have never heard a single explanation (using physics) why a lighter rotating assembly should provide extra HP - Since HP can be measured at constant RPM.
There is "evidence" in the other post that the LWCP gives LESS HP:
http://www.motoiq.com/MagazineArticl...velopment.aspx
Do you just dismiss THAT evidence and believe your own?
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Cole (06-18-2016)
Old 06-18-2016, 12:14 PM   #58
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by G-awesome View Post
I'm gonna enjoy this thread.
Got a perrin lightweight crank pulley last fall but never rushed to install it and it's sitting gather dust. It suuure looks pretty in red though!
Tried to install it once but it was a PITA getting the oem off an auto since you have to hold it in place while taking off the crank bolt. Debating whether I should just sell it or attempt it again in the near future...
Yes auto transmissions need a special tool.
Hey again
It doesn't make extra HP, you just have less rotational inertia and thus less HP loss. Not in constant RPM, but as you accelerate. This is the most important thing. How much power you have under acceleration at full throttle. This is also what dyno's are measuring.
Maybe you heard about Subaru's attempt to break their own record in the Isle of Man. They used a specially tuned 550-hp WRX STI with many changes from Prodrive and STI. They transported the car in the island and made many test laps and attempts for several weeks. I was checking some screenshots and I found they were also using a lightweight pulley. It is the lowest pulley in the screenshot:
I believe it is clear that it is not the solid pulley with the rubber. Do you thing they would change it if there was a risk to broke the engine or if there were no gains?
Old 06-18-2016, 12:23 PM   #59
Cole
Not a troll
Cole's Avatar
Hey again
Using an example from Motorsport is not applicable here though. Show us concrete proof of gains, rather than anecdotes.
If you can show me a bunch of dyno runs showing consistent gains (outside the margin of error of dynos, of course) then I'll take a sip of the Kool-aid
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
FRSBRZGT86FAN (06-20-2016)
Old 06-18-2016, 12:37 PM   #60
justatroll
justatroll's Avatar
Hey again
It doesn't make extra HP, you just have less rotational inertia and thus less HP loss. Not in constant RPM, but as you accelerate. This is the most important thing. How much power you have under acceleration at full throttle. This is also what dyno's are measuring. ?
What you just said is gibberish. You cannot have LESS HP loss, but not MAKE more HP. That statement negates itself.
And "what a dyno is measuring" is Horsepower.
The definition of HP is Torque (at a specific RPM) Times the RPM.
A plot of HP is a series of discrete measurements made at a discrete points in time.
HP in no way cares about how long it took to get from one RPM to a different RPM.
P(hp) = (Torque (ftxlb) X N (RPM))/5252
Please point out where in that equation is Time, or seconds.
Even the RPM term 'N' is a STATIC RPM.
On dyno run sheets does it say anywhere how long the pull took?
No? that is because it does not matter.
This has also been addressed many times.
If you are building a race car from the ground up, and have already reduced mass in other more relevant areas like Flywheel, Crank, Rods, Pistons, wheels, tires, etc, then by all means continue the weight reduction trend and reduce weight wherever you can as it does all add up and make a difference.
But - On an otherwise stock vehicle reducing the weight of the crank pulley by a couple of pounds will result in no noticeable difference in the acceleration of the vehicle.
And when building an engine with a likely unlimited budget while attempting to set a world record, I am certain that they care absolutely ZERO about the longevity of the main bearings.
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Cole (06-18-2016), humfrz (06-18-2016)
Old 06-18-2016, 01:50 PM   #61
I'd suggest you use it as a centerpiece for your coffee table ..... as a conversation piece .......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (06-18-2016), FRSBRZGT86FAN (06-20-2016), G-awesome (06-18-2016)
Old 06-18-2016, 02:01 PM   #62
G-awesome
Drives: 2015 Firestorm Scion FRS
Brilliant idea again humfrz!
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
humfrz (06-18-2016)
Old 06-18-2016, 04:05 PM   #63
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Sorry guys, I won't continue this. Have a nice day!
Old 06-18-2016, 04:46 PM   #64
justatroll
justatroll's Avatar
So one of my statements above offended you in some way?
The Following 3 Users Say Thank You to justatroll For This Useful Post:
cdrazic93 (06-18-2016), Cole (06-18-2016), FRSBRZGT86FAN (06-20-2016)
Old 06-18-2016, 07:23 PM   #65
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
this gave me a fantastic laugh before work.
The Following User Says Thank You to cdrazic93 For This Useful Post:
justatroll (06-18-2016)
Old 06-19-2016, 10:35 AM   #66
ysu
Drives: Toyota 86 GTS Auto
Hey justatroll. I am not a scientist but i have found your missing seconds fairly easily. The measurement of rpm is 1/s. ( or 1/m)
ysu is offline   Reply With Quote
Old 06-19-2016, 11:12 AM   #67
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You don't even need time, but he is a justatroll and he'll not stop arguing. I just don't want to explain him anymore.
Whoever wants he can install a light pulley and check for himself if he likes it or not. Oil analysis, which is also a good thing to do in a non-factory car, can provide signs of any bearing wear. He won't find anything, but if this makes someone to feel better then it is an option. Otherwise, just keep the car stock and enjoy the life. This is my last advice guys and have fun!
The Following User Says Thank You to nikitopo For This Useful Post:
ysu (06-19-2016)
Old 06-19-2016, 04:28 PM   #68
steve99
Drives: FT86
The Following 2 Users Say Thank You to steve99 For This Useful Post:
JustAnEngineer (08-17-2016), ysu (06-19-2016)
Old 06-19-2016, 05:12 PM   #69
justatroll
justatroll's Avatar
True but to perform the calculation for HP, you use a static value for RPM.
The calculations for HP do not care how long it takes to transition from one RPM value to another.
You can do a very fast dyno pull, or a very slow one, the data will be nearly the same.
The slower the pull the more accurate the data.
I asked above, but never received an answer to: "On dyno run sheets does it say anywhere how long the pull took?"
On a pure Inertia Dyno (old school) you DO use the time rate of change of RPM to determine HP.
This was because all you needed was a known inertial mass flywheel and a stopwatch.
Newer technology uses high speed data gathering and controlled sweep loads to perform the measurements at a series of discrete points in time.
People that want to exaggerate their dyno values will try to run the sweep test as quickly as possible to maximize the rotating mass error and give inflated HP values.
Using Steady State testing eliminates the rotating inertial mass error of a sweep test, as there is no acceleration during this type of test.
First: You have not "explained" anything.
You "make statements" with no real world data to back them up.
So now presenting facts (backed up with MATH and PHYSICS) is arguing?
People post things like "you just have less rotational inertia and thus less HP loss" but present no facts to back up the statement.
Just explain where my statements are incorrect using facts.
I am all ears.
Start with this one:
Axiom 1 "HP can be measured at constant angular velocity"
Axiom 2 "rotational inertia is not a factor in systems rotating at constant angular velocity"
Inference "Rotational inertia is not a factor in HP measurements at constant angular velocity."
Where am I wrong?
I DO know the answer to "how does inertia of the rotating assembly in a car's drivetrain affect acceleration of a vehicle?"
But that is a different question from "Does a lightweight crank pulley make more horsepower?".
The answer to the second question is 'no'.
One thing I have learned is that many people just repeat things they have heard as facts.
When confronted with challenges to assertions like "Why?" people who dont have an answer interpret the question as an attack and get defensive.
MOST people are incapable of saying "I dont know".
Professional engineers have learned to say "I dont know, but I will go and try to get that answer" or they will not last long as an engineer.
I dont know everything, but there are very few concepts that I cannot understand after doing some research.
I am also perfectly capable of admitting I am wrong when someone presents me with answers that prove I am wrong.
The Following 4 Users Say Thank You to justatroll For This Useful Post:
Cole (06-19-2016), nova.86 (06-19-2016), steve99 (06-19-2016), Tcoat (06-20-2016)
Old 06-19-2016, 05:18 PM   #70
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
I'm excited for Mechanics in the Fall, it's gonna be fun when we take everything we learn halfway in the semester and then rotate it lol. Centripetal forces, torque, all that good stuff.
nova.86 is offline   Reply With Quote
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
FS:PERRIN Light weight pulley NEW $85 Shipped Amalgamo Engine, Exhaust, Bolt-Ons 1 05-01-2013 11:10 AM
FS: BNIB Perrin Light Weight Crank Pulley jflogerzi Engine, Exhaust, Bolt-Ons 3 03-31-2013 01:06 AM
