#1345 |
e85!
Drives: 2013 Scion FR-S M/T
Yeah it sits right under the supercharger housing. It's tough to see, but its there in the picture I posted and its right next to the intake manifold runner. Yes, it's an edelbrock part
Scion FR-S M/T | HRI Tuned - AMS Catted Header - DW 700cc injectors - DW 265lph Fuel Pump - MotoEast Flex Fuel Kit - Greddy Evolution GT Catback Exhaust - Exedy Stage 2 Clutch - Edelbrock Supercharger
#1346 |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Recently purchased an edelbrock CARB kit. Absolutely love it, but I'm ready to take it a bit further. I'm looking to achieve the maximum WHP I can before having to rebuild/upgrade internals. From what I've read the magic number appears to be 300 WHP. What would be the safest, way to achieve that number. Smaller pulley, tomei header, op, fp, 60s and a delicious tune is what I'm currently considering.
Thoughts, advice ? Thanks! Sent from my SAMSUNG-SM-G890A using Tapatalk |
#1347 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#1348 | |
Sent from my SAMSUNG-SM-G890A using Tapatalk Last edited by Silverfox; 06-11-2016 at 10:30 PM. |
#1349 |
Fish out of water
Drives: 2016 86 GT White
Anyone know when the tune for 2016 models will be available? 2015 will not work?
Let's be honest, I have no idea what I'm doing.
#1350 |
Drives: 2013 Black BRZ Limited
manifold gaskets were cleaned off and liberally lubricated with silicone grease.
injectors cleaned up and remounted. amazing how fast things go back together a second time after you've already done it once. I think most of the labor in the install is still attributed to getting the lower ECU mounting bolt put back in place. I had accidentally cross threaded it last time, so ended up chasing the bolt and threads through tap and die to clean things up. managed to blow a fuse on the fusible link block attached to the positive terminal. noob mistake, forgot to disconnect the negative terminal before working in the engine bay. I had it hooked up to a battery minder while I was out of town to keep the battery from going flat. ratchet from manifold bolt bounced off the positive terminal and blew the 80A fuse side of the block. doh. it's a special order part so I need to call a dealership tomorrow. what's another week of having the car in the driveway?
#1351 |
#1352 | |
You'll also need injectors and a fuel pump, and possibly a clutch. PM to order. |
#1353 |
Fish out of water
great, does that work for my Japanese 86? i was talking to whoever runs the FB page and they said the 2016 tune wasnt ready yet, with no ETA...
#1354 |
#1355 |
would it be worth it to ditch sprintex for an edelbrock? I've heard it's pretty similar in power delivery and peaking at like the same numbers.
#1356 |
#1357 | |
Also, one is up for sale on the SoCal FB page right now with only 11k miles on it. Sent from my SAMSUNG-SM-G890A using Tapatalk |
#1358 | |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
