Old 06-06-2016, 12:47 AM   #1345
EJ.
e85!
EJ.'s Avatar
Drives: 2013 Scion FR-S M/T
Originally Posted by taiguy View Post
Is this actuator part of the supercharger housing? So an edelbrock part?
Yeah it sits right under the supercharger housing. It's tough to see, but its there in the picture I posted and its right next to the intake manifold runner. Yes, it's an edelbrock part
Scion FR-S M/T | HRI Tuned - AMS Catted Header - DW 700cc injectors - DW 265lph Fuel Pump - MotoEast Flex Fuel Kit - Greddy Evolution GT Catback Exhaust - Exedy Stage 2 Clutch - Edelbrock Supercharger
EJ. is offline   Reply With Quote
The Following User Says Thank You to EJ. For This Useful Post:
taiguy (06-06-2016)
Old 06-11-2016, 03:01 AM   #1346
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Recently purchased an edelbrock CARB kit. Absolutely love it, but I'm ready to take it a bit further. I'm looking to achieve the maximum WHP I can before having to rebuild/upgrade internals. From what I've read the magic number appears to be 300 WHP. What would be the safest, way to achieve that number. Smaller pulley, tomei header, op, fp, 60s and a delicious tune is what I'm currently considering.
Thoughts, advice ?
Thanks!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Silverfox is offline   Reply With Quote
Old 06-11-2016, 03:10 AM   #1347
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Thoughts, advice ?
Thanks!
I would try for E85/flex fuel first before the others you listed. Also, have seen better gains with the ace headers compared to the tomei.
The Following User Says Thank You to BigFatFlip For This Useful Post:
why? (06-12-2016)
Old 06-11-2016, 03:15 AM   #1348
Silverfox
Silverfox's Avatar
I've considered E-85 but it won't work for me for location, as well as I'm not sold on its reliability yet.
Old 06-12-2016, 07:22 AM   #1349
japes
Fish out of water
japes's Avatar
Drives: 2016 86 GT White
Anyone know when the tune for 2016 models will be available? 2015 will not work?
Let's be honest, I have no idea what I'm doing.
japes is offline   Reply With Quote
Old 06-12-2016, 04:31 PM   #1350
taiguy
Drives: 2013 Black BRZ Limited
manifold gaskets were cleaned off and liberally lubricated with silicone grease.
injectors cleaned up and remounted.
amazing how fast things go back together a second time after you've already done it once. I think most of the labor in the install is still attributed to getting the lower ECU mounting bolt put back in place. I had accidentally cross threaded it last time, so ended up chasing the bolt and threads through tap and die to clean things up.
managed to blow a fuse on the fusible link block attached to the positive terminal. noob mistake, forgot to disconnect the negative terminal before working in the engine bay. I had it hooked up to a battery minder while I was out of town to keep the battery from going flat. ratchet from manifold bolt bounced off the positive terminal and blew the 80A fuse side of the block. doh. it's a special order part so I need to call a dealership tomorrow. what's another week of having the car in the driveway?
taiguy is offline   Reply With Quote
The Following 4 Users Say Thank You to taiguy For This Useful Post:
BigFatFlip (06-12-2016), CSG Mike (06-13-2016), Edelbrock LLC (06-13-2016), itsibarra (06-13-2016)
Old 06-13-2016, 01:28 PM   #1351
Edelbrock LLC
Edelbrock LLC's Avatar
We already have a calibration built for 2016 BRZ/FRS vehicles.
Edelbrock LLC is offline   Reply With Quote
Old 06-13-2016, 03:32 PM   #1352
CSG Mike
CSG Mike's Avatar
Thoughts, advice ?
Thanks!
Ethanol and Flex Fuel.
You'll also need injectors and a fuel pump, and possibly a clutch. PM to order.
Silverfox (06-13-2016)
Old 06-14-2016, 06:39 AM   #1353
japes
Fish out of water
japes's Avatar
great, does that work for my Japanese 86? i was talking to whoever runs the FB page and they said the 2016 tune wasnt ready yet, with no ETA...
Old 06-14-2016, 02:30 PM   #1354
CSG Mike
CSG Mike's Avatar
There is no reason it shouldn't
Old 06-14-2016, 03:17 PM   #1355
azynneo
would it be worth it to ditch sprintex for an edelbrock? I've heard it's pretty similar in power delivery and peaking at like the same numbers.
azynneo is offline   Reply With Quote
Old 06-14-2016, 03:43 PM   #1356
CSG Mike
CSG Mike's Avatar
Absolutely; the Edelbrock makes WAY more power, even on 91.
Old 06-14-2016, 04:06 PM   #1357
Silverfox
Silverfox's Avatar
Yes.
Also, one is up for sale on the SoCal FB page right now with only 11k miles on it.
Old 06-14-2016, 04:10 PM   #1358
CSG Mike
CSG Mike's Avatar
http://www.ft86club.com/forums/showthread.php?t=107073
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
