Old 06-14-2016, 10:13 AM   #617
Reamer
Drives: 2015 FRS
Originally Posted by Calum View Post
I've been considering the JDL front pipe. How loud would you say the ACE and JDL combination is over stock?
Any reason to not just stick with the stock catback?
Thanks
It is noticeably louder but far from overwhelming. If you're not in the throttle then it is basically a stock sound and it has some tone to it when you do light accelerations. When you open it up it sounds great and has a similar tone to stock, just louder and deeper. Cold starts are definitely louder.
I think catbacks are solely for sound if you're not FI, but it is something I'm wanting to test since I have the headers/op + fp and a dyno tune. If a catback is going to make a difference in power, this would be it without going with a stroker kit or cams.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
The Following User Says Thank You to Reamer For This Useful Post:
Calum (06-14-2016)
Old 06-14-2016, 10:16 AM   #618
Reamer
Drives: 2015 FRS
Originally Posted by Hicklinc View Post
Someone posted a video of an ace header with stock catback and ive never heard anything that bad its in this thread somewhere
Sent from my SM-N910T using Tapatalk
That was with the ACE front pipe too. That combination is awful on stock catback. I thought about getting aftermarket catback to test, but I was concerned it would still be raspy so I changed the front pipe instead. I am holding onto the ACE FP for the time being in case I want to do some mix and match in the future to see what it is like on a different exhaust.
The Following 2 Users Say Thank You to Reamer For This Useful Post:
Calum (06-14-2016), CSG Mike (06-14-2016)
Old 06-14-2016, 10:25 AM   #619
Hicklinc
Drives: N/a
He also did the video with an invidia cated front pipe it was better but i still think it sounded bad their is a video on you tube search q300 ace it sounds pretty good
Hicklinc is offline   Reply With Quote
Old 06-14-2016, 10:30 AM   #620
Reamer
Drives: 2015 FRS
I think the resonator has more effect on eliminating rasp and the cat just makes it a little quieter. The JDL ultra quiet has both, like the stock front pipe, but is less restrictive.
I'm not sure why the q300 is such a popular choice. If I remember correctly from a thread on here that shows the weights of different exhausts, the q300 is heavier than stock.
Old 06-14-2016, 10:32 AM   #621
Hicklinc
Drives: N/a
You are correct its pretty much the same weight your not going to go lighter and stay quiet
Old 06-14-2016, 12:15 PM   #622
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
That would be my video. Yes, with the ACE Front Pipe (any catless front pipe for that matter) the sound was quite obnoxious with exception of being above 5000rpms. Above 5k it sounds quite good. But the intention of using a catless FP is for track use, when performance trumps all (usually). But I am picky about my noise and went with the HFC invidia FP. It is much better on noise, but then my stock CBE started to have baffles wear out and make all kinds of racket. I now run the ACE Header, invidia FP and Q300. The car sounds great. But I will say, even if the ACE header did make too much racket (which i dont think so) the performance gain is just plain worth it. ACE header really is that good. I have never felt a header make that kind of a difference on a 4cyl in my life.
I mean its not like adding FI, but it is impressive none the less.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 3 Users Say Thank You to brzaapi For This Useful Post:
CSG Mike (06-14-2016), Hicklinc (06-14-2016), Silverfox (06-14-2016)
Old 06-14-2016, 02:27 PM   #623
CSG Mike
CSG Mike's Avatar
The Ace headers are finally out of backorder...
Old 06-14-2016, 02:29 PM   #624
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Just ordered my cs400 👌 stoked
Sent from my SAMSUNG-SM-G890A using Tapatalk
Silverfox is offline   Reply With Quote
The Following User Says Thank You to Silverfox For This Useful Post:
Old 06-14-2016, 02:32 PM   #625
CSG Mike
CSG Mike's Avatar
Originally Posted by DHitHim View Post
I heard your car at buttonwillow last weekend and it was really loud. I just picked up a Tommy Kaira exhaust and so far it's pretty quiet with the tomei front pipe. Can't wait to order an ace header. Hoping it's not too loud so it's within sound compliance.
I had my WRX at buttonwillow...
Old 06-14-2016, 02:35 PM   #626
Pat
Pat's Avatar
Drives: 2023 BRZ
I'll take 11.
Old 06-14-2016, 02:35 PM   #627
CSG Mike
CSG Mike's Avatar
It's because it's one of the quietest aftermarket catbacks.
Old 06-14-2016, 02:54 PM   #628
DHitHim
Drives: 2015 CWP Limited BRZ
OOPS, I thought you were the white BRZ with the Trackspec louvers. LOL, this is awkward, I'm gonna go hide under a rock now because I just derp'd so hard.
edit: unless that's the other mike. LOL
DHitHim is offline   Reply With Quote
Old 06-14-2016, 02:59 PM   #629
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Is my header included in that batch?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 06-14-2016, 03:01 PM   #630
DAEMANO
Time Traveller
Thanks. If you ever get around to dyno'ing your new setup, please post results.
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
