Old 06-14-2016, 09:42 AM   #1
Tvars
Tvars's Avatar
Drives: Firestorm
Kensun HID light?
When I purchased my FRS it already had a Kensun HID lights installed. Name:  IMG_20160613_180935_01.jpg
The passenger side light has died and needs to be replaced. Is their any way of telling the Kelvins of the bulb? Where is the best place to purchase replacements? I have seen them on Walmart's website.
This is the spec that I have found that best fits what I think I need as a replacement part:
Kensun UN-K-55W Bulbs-H11-5K HID Xenon 5000K 55W AC Bulbs, Pure White
found on the Walmart wesbite.
Tvars is offline   Reply With Quote
Old 06-14-2016, 10:26 AM   #2
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Quoting from Kensun's site:
It is hard to describe HID colors accurately since many variables such as voltage, type of ballast and the environment can affect color output. Also, color perception is subjective. That said, here is a rough guide to Color Temperatures for HID bulbs:
3000k= Yellow, 4300k= Bright White with a hint of yellow, 6000k= Pure white light (some people detect a slight blue), 8000k= White light with a blue tinge, 10000k= Light blue, 12000k= Deeper Blue, 30000k= Violet/Purple.
http://kensun.com/H11/index.html
Side comment: I'd say ditch that and go with Diode Dynamics, The Retrofit Source, and a 3rd vendor on here that I can't recall off the top of my head.
The Twins make me smile
Old 06-14-2016, 11:00 AM   #3
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
DDMtuning.com 15.00 a set of bulbs. I've been using them for all my HID needs for 10 years.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Respect BRZ is offline   Reply With Quote
Old 06-14-2016, 11:18 AM   #4
Tvars
Tvars's Avatar
Drives: Firestorm
@Respect BRZ great! and these would be compatible with Kensun HID kit?
@soulreapersteve I probably will eventually but i have recently moved and need to be able to quickly register the car and pass inspection so i need the headlights to both be working.
The Following User Says Thank You to Tvars For This Useful Post:
soulreapersteve (06-15-2016)
Old 06-14-2016, 07:03 PM   #5
Respect BRZ
Old Mechanic
If it's an H11 then pick out H11, should be just fine.
The Following User Says Thank You to Respect BRZ For This Useful Post:
Tvars (06-15-2016)
Old 06-16-2016, 11:55 AM   #6
Respect BRZ
Old Mechanic
Sure hope you swapped bulbs to make sure it's the bulb out and not a ballast.
h11 bulb, kensun
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 11:25 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 07:32 AM
$50 Kensun HID KITS FRSBRZGT86FAN Cosmetic Modification (Interior/Exterior/Lighting) 23 05-29-2015 01:16 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
