Old 06-13-2016, 05:33 PM   #12713
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Normal way of doing Heel & Toe = Heel - Gas, Toe - Brake.
Senna way of doing Heel & Toe = Big toe - Brake, Rest of the toe - Gas
& just found other way of doing Heel & Toe = Heel - Brake, Toe - Gas.
Now.. I cannot really comprehend how that's possible. If you're properly sitting, I'm not sure how your feet can move to that position.
ichitaka05 is offline
Old 06-13-2016, 05:35 PM   #12714
Ashikabi
Ashikabi's Avatar
I can't get my leg to turn inwards to have the heel on the gas and you're on the brake
Ashikabi is offline
Old 06-13-2016, 05:36 PM   #12715
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Ok I know I should let this ridiculous bickering burn out, but this I feel like commenting.
How about you get car A with bicycle brakes and I get car B SAME CAR except it has truck brakes and we will see who stops in a shorter distance...
Introducing: Car C with OEM brakes. That's the one that will stop in the shortest distance.
Car A doesn't have enough friction to lock the wheels and is obviously the slowest to stop.
Car B has unnecessarily massive rotors, callipers, pads and less responsive force transfer (compressed air), needs longer time to engage fully and will need longer distance to stop than car C.
Car C with the OEM braking system will win this comparison unless your tires have so much traction that the OEM system fails to lock the wheels and engage the ABS. On a BRZ that will take some truly amazing tires.
@Tcoat has got it spot on right.
Sarlacc is offline
Old 06-13-2016, 05:37 PM   #12716
ichitaka05
Site Moderator
ichitaka05's Avatar
Those time, you just do Senna's Heel & Toe.
When you sit in full racing position, I'm not sure you're able to put your heel inward.
Old 06-13-2016, 05:45 PM   #12717
Teseo
Drives: frs
With cusco gas pedal is more easy to use senna method
Teseo is offline
Old 06-13-2016, 05:46 PM   #12718
gramicci101
Off Topic
I think it's a foot size thing. I have size 12.5 feet, so I can't even do toe-brake / heel-gas. I have to do left toe-brake / right toe-gas.
Oh, and for the other discussion, you can only brake as hard as your tires can hold onto the ground. No matter what else you change in the system (pads, calipers, rotor size, etc...), that will dictate your braking speed, whether you have OEM brakes or massive 16 inch rotors and 8 piston calipers. If you improve your traction (better tires, wider tires), then you will be able to brake harder and stop shorter. If you improve your traction so much that the OEM brakes can no longer engage ABS, then yes, a BBK would help you reach the performance limit of your new tires.
gramicci101 is offline
Old 06-13-2016, 05:47 PM   #12719
Ashikabi
Ashikabi's Avatar
I dunno about you but if my knees are bent, my foot won't turn past parallel to the long axis of the car. But it'll turn 45 degree towards the passenger
Ashikabi is offline
Old 06-13-2016, 05:55 PM   #12720
ichitaka05
Site Moderator
ichitaka05's Avatar
Or GSpeed's Gas pedal mover... or maybe both
So you do Senna's way.
Just making sure we're in the same boat, you do normal heel & toe (heel gas, toe brake) or other... let's call it reverse heel & toe (heel brake, toe gas).
Old 06-13-2016, 05:56 PM   #12721
p1l0t
p1l0t's Avatar
Well when car and driver tested out the kits the Brembos beat stock by like 25ft... even on the first stop let alone the subsequent ones. but you know actual expermentation versus your guys circular arguments is no comparison.
http://www.caranddriver.com/features...toptech-page-3
p1l0t is offline
Old 06-13-2016, 06:12 PM   #12722
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
No one here said that bigger brakes aren't good for reducing overheating and brake fade. On the contrary, that's what bigger brakes are good for.
Brake fade can be a serious issue on the race track, but not when coming to a full stop from highway cruise speed.
Sarlacc is offline
Old 06-13-2016, 06:13 PM   #12723
p1l0t
p1l0t's Avatar
25ft shorter. On the first stop. Maybe you missed you that part.
p1l0t is offline
Old 06-13-2016, 06:21 PM   #12724
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Let me quote from the article you linked:
Think of it this way: All brake systems, stock and aftermarket, are able to activate the ABS, so how could a stronger brake shorten a stop? Eric Dahl, a brake engineer from Brembo, put it this way: "Don't expect the brake kits to stop you sooner, but expect the 20th lap to feel like the first."
Maybe you missed that part?
Sarlacc is offline
Old 06-13-2016, 06:47 PM   #12725
"Think of it this way: All brake systems, stock and aftermarket, are able to activate the ABS, so how could a stronger brake shorten a stop? Eric Dahl, a brake engineer from Brembo, put it this way: "Don't expect the brake kits to stop you sooner, but expect the 20th lap to feel like the first."
And I end my debate with the undisputed expert on the subject that said exactly the same thing that I did from the very start.
Gotta love it when your debate opponent hands you the closing remark on a platter.
Tcoat is offline
Old 06-13-2016, 06:47 PM   #12726
p1l0t
p1l0t's Avatar
Yeah 25ft is like 10% shorter.. still 25ft is 25ft. That's 2 car lengths.
p1l0t is offline
