Old 06-11-2016, 09:00 PM   #253
benlaz88
Drives: 2013 Asphalt FRS
sorry for bring back this old thread up, is it necessary to put back the boot linkage? I tear my up.
benlaz88 is offline   Reply With Quote
Old 06-11-2016, 10:48 PM   #254
Lord09
Drives: 2015 BRZ
Id say yes since it protects from the elements.
Lord09 is offline   Reply With Quote
Old 06-15-2016, 08:57 PM   #255
j_motion
Drives: 14 BRZ Red premium
Originally Posted by coolaron View Post
Those of you who installed Kartboy short shifter kit, are you guys having same concern like I do?
The reverse is pretty tough to put in than stock. The lock-out itself feels like it it uses much stronger spring..
The Green Grease is also a lot thicker and sticker than the stock one ..
In cold day it will definite be harder to pull the reverse lock up and since is used on the ball joint it will make it a bit sticky too.
do keep that in mind
j_motion is offline   Reply With Quote
Old 06-15-2016, 08:58 PM   #256
j_motion
Originally Posted by Cridland View Post
for people with the kartboy installed, can you put a reverse lockout on the kartboy ss?
No you can't ..its a one peice design all the way down to where it contact the lock out plate
The Following User Says Thank You to j_motion For This Useful Post:
Cridland (06-15-2016)
Old 06-17-2016, 03:38 PM   #257
benlaz88
Do anyone of you know what the 2 oring is for? I couldn't figure it by searching her. @tom@kartboy
Old 06-17-2016, 07:24 PM   #258
j_motion
I put the on the linkage bolt between the shifter rod and the base of the shifter.
I think is there to minimize left and right play. But i could only put 1 of the oring on. I try to put 2 but have no success of putting the locking pin back on to the linkage bolt with 2.
Old 06-17-2016, 11:23 PM   #259
benlaz88
Thank you! I will give a try.
Old 06-18-2016, 07:11 AM   #260
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I just installed mine last night and I have the rattle about 4k on WOT. Doesnt bother me cause its not my daily... cause racecar i guess
tofurun is offline   Reply With Quote
Old 06-18-2016, 01:15 PM   #261
benlaz88
i don't mind rattle, i just like to install everything what they come with.
Old 06-18-2016, 07:31 PM   #262
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I thought it was to help with le rattle? I totally forgot to install mine :/ Can't hear the rattle over the exhaust anyway.
I've been running my Kartboy since about the start of the year and absolutely love it! Could be a little higher but other than that, it's perfectooooo. No slop, little rattle but racecarlyfe, shifts perfectly.
COO86L is offline   Reply With Quote
Old 06-19-2016, 12:15 AM   #263
benlaz88
I just installed my last week. I just need to break it in a little more. I prob will put those o ring on tomorrow and see the different. Other than that, i like it so far.
Old 06-21-2016, 12:43 PM   #264
MechOps
Drives: 2013 BRZ Limited
Just installed the Kartboy yesterday. The 2 O-rings are there to help with the rattle, but I can only put one. Couldn't get the locking pin/clip back on when I put both on. So far, no rattles.
As for the shifter itself, I love it.
MechOps is offline   Reply With Quote
Old 06-22-2016, 09:15 PM   #265
j_motion
I think the o ring wil help with the rattle and side to side play of the shifter.
Ya i try to put the 2nd one in after i install it for 5 month, and there is just not enough space. Unless some one was able to compress it and put the pin back on. ( maybe from the bottom of the car)
MechOps (06-22-2016)
Old 06-22-2016, 10:57 PM   #266
tofurun
tofurun's Avatar
meh the first few miles it was a rattle monster for me, but it went away after a few miles. Still rattles mildly now but thats ok cause racecar. I didnt install either or the 2 rubber o rings
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 08:19 PM
Kartboy Short Throw Shifter!! RallySport Direct Transmission and Driveline 16 04-18-2013 01:18 PM
Kartboy Short Throw Shifter!! RallySport Direct Announcements, Contests, Giveaways 34 03-18-2013 02:18 PM
