Old 06-11-2016, 06:04 PM   #2227
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Oh! Okay I'll go feel around, paying no heed to what others may think I'm doing to my car.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Old 06-11-2016, 06:05 PM   #2228
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Haha! tbh there is no way to not look weird while doing this install. Its awkward AF.
kuczynskika is offline   Reply With Quote
Old 06-11-2016, 06:26 PM   #2229
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Thank you so much! I've been putting that off for years! And now I have all the STI emblems I've purchased finally on the car: front bumper emblem, trunk badge, door stickers, front lip and side skirt emblems. The front bumper wasn't actually that hard, which I'm glad.
If anyone else is within an hour or two of Mahwah in North New Jersey, I'd be glad to help you install the front emblem!
The Following 5 Users Say Thank You to chanomatik For This Useful Post:
Hyper4mance2k (06-15-2016), Iceman (06-13-2016), krayzie (06-11-2016), kuczynskika (06-11-2016), sprintertrueno86 (06-12-2016)
Old 06-11-2016, 10:07 PM   #2230
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I guess I'm at the stage where I can start to work on cosmetic parts.
Did you have to remove the front bumper to install the front emblem properly? Wouldn't an L shape screwdriver key work (like from my bicycle multi-tool)? Did you get both screws on there?
When I put my hand into that area, it seems like I can push the styrofoam piece away towards the back for more room (I have fat hands)?
Dam I'm still trying to find this front STI emblem part on Japanparts.
krayzie is offline   Reply With Quote
Old 06-11-2016, 10:27 PM   #2231
kuczynskika
You won't did it listed under STI. Search under Subaru. It's classified as a Subaru part for some reason.
The Following User Says Thank You to kuczynskika For This Useful Post:
krayzie (06-12-2016)
Old 06-11-2016, 10:45 PM   #2232
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
No I did not. I placed the bracket first, pushed the Styrofoam piece over and lined up the bracket with the screw points. It sits right in them. Then I put the screws in, but they don't screw all the way down. Then the STI emblem clicks right in place.
The Following User Says Thank You to chanomatik For This Useful Post:
Old 06-13-2016, 03:18 AM   #2233
kuczynskika
Originally Posted by Trap63 View Post
a speedy DIY as these parts are not on sale....
Genuine Chrome Trim Subaru and Grimmspeed Cherry STI spray paint, flexo clear coat for PPE bumper and 3M adhesive foam (9mm x 0,9 mm) on back.
Need primer for PPE or Fiberglass then 3M 2000, 800. Grimmspeed paint and Lechler clear coat (max 60° about 30 mins)
Just bought the chrome trim; shipping it from Germany! @Trap63, any more tips or tricks for preparing and painting the trim? Exactly what kind of clear coat did you use? Part numbers? Thanks for being the trailblazer!
Trap63 (06-14-2016)
Old 06-14-2016, 06:35 AM   #2234
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Hi kuczynskika , I don't know the right part no.
Bodywork repairs often use clearcoat for bumper adding flex additive, mostly sold by PPG and 3M and Sikkens or DuPont. Basically this clear coat has more resins than the one you can spray all over metal body. Ask @ your local bodywork, they know that.
Trap63 is offline   Reply With Quote
Old 06-14-2016, 02:19 PM   #2235
kuczynskika
Thanks @Trap63 Seems like that stuff is easily obtainable. What ratio of gloss and flat did you use in the clear coat to achieve the finish?
Old 06-15-2016, 04:58 PM   #2236
Trap63
Trap63's Avatar
About flex increase ratio, twice than usual on metal or 30%+ for PPU coating, about glossy not exceed 0,20 - 0,35 micron as shape of trim is flat instead of curved when applied. Be gently in application in a warm day.
I replaced back adhesive (3M 0,8 mm foam, adhesive), when removing you'll see alu base of trim, don't worry about scratches as pink paint will cover any background of trim.
Old 06-15-2016, 05:04 PM   #2237
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Just get it from FT86SF??
hypebrz is offline   Reply With Quote
Old 06-15-2016, 05:06 PM   #2238
kuczynskika
Right now that's the best way since the conversion from USD to yen sucks. Cheaper to buy JDM that's already been imported than buying from Japanparts unfortunately.
Old 06-15-2016, 05:09 PM   #2239
kuczynskika
So an added 30% of flex material in the total mix? I don't understand what you mean by microns either.
Old 06-15-2016, 05:28 PM   #2240
Trap63
Trap63's Avatar
About microns the total amount of clear coat over pink coat. If you exceed near sides on bottom paint might break.
Inviato dal mio SM-G935F utilizzando Tapatalk
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
