Old 06-09-2016, 02:32 AM   #7267
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Blew the seal on the front of the blower crank. Whole blower's been acting wonky since. Contacted Sprintex, and they sent me out a new blower without hesitation! Can't beat the customer service. Will be putting it on Sunday.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following 2 Users Say Thank You to Rifle For This Useful Post:
continuecrushing (06-09-2016), riboyster (06-10-2016)
Old 06-09-2016, 03:37 PM   #7268
sterny331
Drives: 2013 brz limited
Originally Posted by Dream20b View Post
I hate to be the pot calling the kettle black, but I wouldn't buy a modified car from someone else, especially not a dealership.
i somewhat agree with you... but on the other hand im not going to spend 20k on a car then stick anyother 6k into it just to acheive 250whp. for that price i could get a newish sti or a c6 corvette haha. i do miss my brz though. but even with boltons and e85 it just wasnt enough for me.
sterny331 is offline   Reply With Quote
Old 06-09-2016, 05:22 PM   #7269
Dream20b
Y u do dis?
Buy the corvette, be happy.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-09-2016, 06:19 PM   #7270
sterny331
haha. always been a subaru guy. ive owned 10 different wrx and sti and had a brz last year. i wish i could drive a supercharged one. but here in wisconsin there are probably only like 2 other people with this kit. and i dont know of any in my area
Old 06-10-2016, 02:36 PM   #7271
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
If you're ever in Australia, you're welcome to drive mine ;D
On another point, does anyone know the OEM crank pulley diameter? I'm thinking of doing something silly for shits and giggles and putting an even smaller pulley on and lowering the redline RPM.
Also, my supercharger seems to be weeping a smidge of oil around where it bolts down to the manifold. Anyone had this issue? I'm considering removing and replacing those screws/bolts (seen a few people have done this as the stock ones aren't strong) and resealing.
Oh, oh andddd when checking oil in s/c, do you jack the back up or check it on level ground (which puts s/c at slight angle)
THANKS PEEPS!! ilylongtiem
COO86L is offline   Reply With Quote
Old 06-10-2016, 04:01 PM   #7272
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Cool86
If you're weeping oil there, you may want to consider an oil catch can. I'm pretty sure the original pulley diameter is 73mm.
People will tell you to Jack up the back of the car for oil check, but I do it on level ground. If you can see oil through the little window, you're probably fine
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 06-10-2016, 04:03 PM   #7273
COO86L
COO86L's Avatar
Would an oil catch can stop this? I wasn't sure if it was blow by leak or the actual supercharger system leak.
So the actual crank pulley itself is 73mm? (not the supercharger pulley)
Old 06-10-2016, 05:41 PM   #7274
Dream20b
Y u do dis?
Where in Wisconsin are you?
Dat Hot Lava Doe
Old 06-10-2016, 07:54 PM   #7275
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by riboyster View Post
Cool86
Not everyone has a little window. I ran it for a while when I checked it on level ground, but I jacked it up and noticed it was really low, so my advice is make sure the charger is level by jacking the rear up to avoid a false positive.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Chad86 (06-10-2016), riboyster (06-11-2016)
Old 06-11-2016, 12:23 AM   #7276
riboyster
riboyster's Avatar
Oh, supercharger pulley is 73. Not sure on crank. I wouldn't think there'd be enough oil in the supercharger to make it weep. My bet is on blowby oil from crankcase.
Old 06-11-2016, 01:10 AM   #7277
Rifle
Rifle's Avatar
Stock blower pulley is 75mm. 72.5mm/70mm avail from raceseng. 69mm available from DeliciousTuning.
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
Old 06-11-2016, 02:09 AM   #7278
riboyster
riboyster's Avatar
There you have it
Old 06-11-2016, 11:39 PM   #7279
Rifle
Rifle's Avatar
In a nut shell, somehow my blower crank seal went. Kevin from @SprintexUSA and his team have probably one the best support teams available. I want to thank all of them for what they do, can't wait to finally swap the blowers and be good to go again!
Sweet little tid-bit.. my 210 now has a 'Sprintex' logo on it!!
295WHP/220TQ
The Following 3 Users Say Thank You to Rifle For This Useful Post:
brybot (08-15-2016), COO86L (06-12-2016), Dream20b (06-12-2016)
Old 06-12-2016, 07:45 AM   #7280
COO86L
COO86L's Avatar
I actually got a 69mm supplied by Sprintex. And the SPS system is ceramic coated etc and some other goodness involved appaz.
Thinking of putting something like a 66mm pulley on and reducing the redline. Just for lulz
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
