Old 06-09-2016, 11:24 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Understanding Oil
Well... This is about as basic as it gets. I have been reading exactly "what" oil means and what the numbers mean. I tend to agree with what a lot of the descriptions say about people really not fully understanding what the numbers are on oil. . Mostly because I had no idea myself (the book says use this so i use it). There I said it I DONT KNOW. well I did my research and am trying to fully understand all of it.
I know people are running different oil weights for things like oil coolers and turbos. BUT WHY. why do this. Turbos get oil hotter? Ok so use a thicker oil? well what about the engine specs from Toyota/Subaru? They say run 0w-20. now we have a oil cooler/turbo and we are running 0w-30. So we are increasing the Hot viscosity of the oil. Idk maybe I have been reading this explanations wrong. Heck I may be making it way more complicated than it really is. I am not asking what I should be running (yet). I am trying to understand the entire thing.
It may just be me but i think this would be a great write up for this section of the forum as a Sticky. Not trying to get flamed just trying to fully understand it.
tofurun is offline   Reply With Quote
Old 06-09-2016, 11:28 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Your Google-fu is weak. Go learn young grasshopper.
Old 06-09-2016, 11:29 PM   #3
tofurun
tofurun's Avatar
Must. Try. Harder. To. Understand!!!!! AGHHHH
lol im still googling on like my 5th article at this point
EDIT: Wait wait wait. I just figured out the turbo deal becoming more lubricated cause the oil stays thicker. But that still doesnt account for it running in your engine. Good for turbo yes good for engine.... No?? So honestly if you are where im at when its Hot year round and freezes 2/365 days then the first number can be all the way to a 10w-20 because you never have cold starts like that. UGHHHH
Everything is telling me what. Its not telling me Why or circumstance like temperatures change and how that affects the specified oil to use.
Old 06-09-2016, 11:45 PM   #4
tofurun
tofurun's Avatar
can i ask you this. What oil are you running in your car?
Old 06-10-2016, 12:50 AM   #5
Well, now, @tofurun ....... first off, your research is NOT complete, if you don't understand it. Most all the answers to your questions, can be found in the literature.
Yep, IMHO, you're making this oil thing waaay to complicated, for a basic understanding necessary, to drive your average FR-S in Georgia.
Oil, and more recently synthetic oil, has been used to lubricate internal combustion engines for years now ....... this is not a new science.
Back-in-the-day, () it was pretty simple ..... use 20 weight in the winter and 30 weight in the summer. Why? Because it was better to have the "lighter" oil in the crankcase in the winter so as the poor old 6V battery could turn over the old 200-400 cu. in. big iron engines. The 30 weight in the summer held up better under the higher heat.
To thoroughly understand oil and it relationship to the "physics" of the engine, one has to understand the "chemistry" of oil (including synthetics).
So, for you to have a through understanding of this concept ...... you have a lot of research ahead of you.
OR
...... you may take the humfrz approach and just read and follow the owners manual.......
humfrz is online now   Reply With Quote
Old 06-10-2016, 12:50 AM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you have done the reading, the next step is to ask questions about the parts of the reading you don't understand. It would help to make the questions relatively tight and to the point. Or you could just do as Humfrz suggests and do what the owners manual tells you.
If you choose the former, beware. Re-read Dante's description of the words on the gate to Hell.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
humfrz (06-10-2016)
Old 06-10-2016, 01:09 AM   #7
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
On my BRZ 0-20 Mobile 1
My MR2 Trubo 10-30. Mobile 1
My MR2 Supercharge 10-30 conventional
Odd thing the supercharge did a lot better on regular oil than mobile 1. My butt dyno said so.
Pretty much what the manual recommends.
If on the silly idea I slap a turbo or supercharged to the BRZ I'll still use the same 0-20. With a lot of cooling.
Old 06-10-2016, 04:23 AM   #8
steve99
Drives: FT86
Have a look here for basic info on oil
http://www.pqiamerica.com/apiserviceclass.htm
have a read of this link , towards the end their some links on oil pressure vs temp .
http://www.ft86club.com/forums/showthread.php?t=81493
very rough giude
If your car is fairly stock and you just drive on the street in a cold to mild climate then just stick with the 0W20 synthetic as per manufactures recommendations for car.
If you drive the car hard or track car in warm to hot climates (ambient well over 30C and never gets below 0C) then probably a 5W30 or even 10W30 is better suited especially if you not running any form of oil cooler.
If you run an oil cooler and your keeping your oil temps below 115 C at all times then you can probably go back to 0W20, if your seeing greater than 120 C then either get a bigger/better oil cooler or run a slightly thicker oil like 5W30.
Its always better to keep the oil temps under control than to run really thick oils
modern synthetic oils dont break down till over 150C, its not generally the oil breaking down you need to worry about its the oil pressure dropping due oil thinning at high temps.
You rearly need to monitor your oil temps to determine the most suitable oil for your conditions and driving
Old 06-10-2016, 04:45 AM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I don't know much but basically it depends on your application.
The reason to go to heavier weigh oil is just to keep the oil pressure the same under higher constant engine load/temp.
So if you track alot then it's normal to use higher weight oil even if it's N/A, there is a reason OEM TRD Japan oil is 0w-30. Some are even more extreme, like the RESPO 86 that's being sold in most AREA 86 http://www.respo.net/egn/respo86.html ("they said" It's a special blend of 5W-40 Design for our boxer engine on track.)
*then again I beat the crap out of my car with 0w-20s all 40k mile.....so ya..... your mileage may vary. >.>
Old 06-10-2016, 05:52 AM   #10
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Motul 0w40 X-Max FTW
-JvV-
jarnojvv is offline   Reply With Quote
Old 06-10-2016, 10:42 AM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Oil loses viscosity with increased temperature. Some oils maintain viscosity at higher temps but usually have a higher viscosity when cold.
There is a compromise using higher viscosity than OEM in that the can will not be as fuel efficient for daily driving but a forced induction or otherwise hyped up engine will reach higher peak temps, those temps will reduce oil viscosity which will in turn result in reduced oil pressure. This is risky for the engine's moving parts that rely on a certain pressure to keep things slick. For example on the HKS GT supercharger it is recommended to use 0W40 oil.
I would never recommend using that viscosity in a cold climate. It will not damage the engine to increase viscosity.
Old 06-10-2016, 11:58 AM   #12
Rameus
Drives: 2015 FR-S
Some of the science behind oil lubcication that is common in engines can be read here: https://en.wikipedia.org/wiki/Fluid_bearing
Note though, that not all engine components are necessarily lubricated hydrodynamically.
I'm sure you've seen some links to this already, but if you haven't, this site/forum has a wealth of oil info: http://www.bobistheoilguy.com/motor-oil-101/
Rameus is offline   Reply With Quote
Old 06-10-2016, 02:46 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.upmpg.com/tech_articles/motoroil_viscosity/
This is the first link that showed up when I Googled "oil weights explained"
You can get different/better results by playing around with keywords.
-alex
Old 06-10-2016, 03:06 PM   #14
tofurun
tofurun's Avatar
very rough giude
Good reads. Thanks man. I knew i remembered seeing that video about the oil pressure in a thread somewhere.
-alex
This was the article that did it for me. Thank you!
Understanding Knock and Preignition: The Combustion Perspective arghx7 Software Tuning 13 08-09-2019 06:32 PM
18x8 vs 18x8.5? Need Help Understanding Ammunition Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-02-2015 01:36 AM
Understanding/clarifying vendor qualifications mav1178 Site Announcements / Questions / Issues 21 03-18-2014 02:25 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 07:08 PM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 10:58 PM
