#7267 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Blew the seal on the front of the blower crank. Whole blower's been acting wonky since. Contacted Sprintex, and they sent me out a new blower without hesitation! Can't beat the customer service. Will be putting it on Sunday.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
| The Following 2 Users Say Thank You to Rifle For This Useful Post: | continuecrushing (06-09-2016), riboyster (06-10-2016) |
#7268 |
Drives: 2013 brz limited
i somewhat agree with you... but on the other hand im not going to spend 20k on a car then stick anyother 6k into it just to acheive 250whp. for that price i could get a newish sti or a c6 corvette haha. i do miss my brz though. but even with boltons and e85 it just wasnt enough for me.
#7269 | |
Y u do dis?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#7270 |
haha. always been a subaru guy. ive owned 10 different wrx and sti and had a brz last year. i wish i could drive a supercharged one. but here in wisconsin there are probably only like 2 other people with this kit. and i dont know of any in my area
#7271 | |
Drives: 2015 86 GTS + Mitsi Lancer GSR
On another point, does anyone know the OEM crank pulley diameter? I'm thinking of doing something silly for shits and giggles and putting an even smaller pulley on and lowering the redline RPM. Also, my supercharger seems to be weeping a smidge of oil around where it bolts down to the manifold. Anyone had this issue? I'm considering removing and replacing those screws/bolts (seen a few people have done this as the stock ones aren't strong) and resealing. Oh, oh andddd when checking oil in s/c, do you jack the back up or check it on level ground (which puts s/c at slight angle) THANKS PEEPS!! ilylongtiem
#7272 |
Drives: 2013 Scion FRS
Cool86
If you're weeping oil there, you may want to consider an oil catch can. I'm pretty sure the original pulley diameter is 73mm. People will tell you to Jack up the back of the car for oil check, but I do it on level ground. If you can see oil through the little window, you're probably fine
ScreamingElectron - SnakeShit |
#7273 |
Would an oil catch can stop this? I wasn't sure if it was blow by leak or the actual supercharger system leak.
So the actual crank pulley itself is 73mm? (not the supercharger pulley) |
#7274 |
Y u do dis?
Where in Wisconsin are you?
Dat Hot Lava Doe
#7275 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#7276 |
Oh, supercharger pulley is 73. Not sure on crank. I wouldn't think there'd be enough oil in the supercharger to make it weep. My bet is on blowby oil from crankcase.
#7277 |
Stock blower pulley is 75mm. 72.5mm/70mm avail from raceseng. 69mm available from DeliciousTuning.
295WHP/220TQ |
| The Following User Says Thank You to Rifle For This Useful Post: | riboyster (06-11-2016) |
#7278 |
There you have it
#7279 |
In a nut shell, somehow my blower crank seal went. Kevin from @SprintexUSA and his team have probably one the best support teams available. I want to thank all of them for what they do, can't wait to finally swap the blowers and be good to go again!
Sweet little tid-bit.. my 210 now has a 'Sprintex' logo on it!! ![]()
295WHP/220TQ |
#7280 | |
Thinking of putting something like a 66mm pulley on and reducing the redline. Just for lulz |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
