Old 06-09-2016, 07:53 PM   #239
VitViper
Drives: '15 FRS
Originally Posted by johan View Post
Yo dogg, this proves your dyno reads high #poser #internettroll #fake
:rotfldying:
VitViper is offline   Reply With Quote
Old 06-09-2016, 08:02 PM   #240
VitViper
Drives: '15 FRS
The Following 2 Users Say Thank You to VitViper For This Useful Post:
raven1231 (06-15-2016), themadscientist (06-09-2016)
Old 06-09-2016, 08:03 PM   #241
johan
Drives: '14 981CS, '99 NB1
Originally Posted by VitViper View Post
:rotfldying:
Just saying.... MoTeC = God. If God says your dyno reads high, it must read high.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
Decay107 (06-09-2016), Ultramaroon (06-10-2016)
Old 06-09-2016, 08:03 PM   #242
VitViper
Drives: '15 FRS
What if I told you... that datalog graph is only 14psi in 3rd gear?
Old 06-09-2016, 08:03 PM   #243
johan
Never mind the fact that you put the code into the MoTeC in the first place...
Old 06-09-2016, 08:04 PM   #244
johan
THEN I'D SAY IT'S GARBAGE.
Old 06-09-2016, 08:31 PM   #245
FRS Justin
Drives: 2013 Asphalt FRS
I added some factoring to give you a more smoothed out view today. As the instantaneous calculations have lots of spikes (for obvious reasons). How much to factor is set by the user (and obviously factoring too much can "lower" the power estimate -- but hey, it's just an estimate!)
It just has to be repeatable the actual accuracy isn't important as long as the repeatable data is consistent.
Talk about a easy way to tune with out a dyno. Talk about using the data to setup traction control or other mapping features. This is extremely promising
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-09-2016, 08:37 PM   #246
VitViper
Drives: '15 FRS
I actually dial the TC in using the accel data from my IMU. Same with launching.
However this logic is super repeatable -- stick to the same road, same direction, etc. and it'll be the same results every hit (baring conditions stay the same). Once you start to hit wheel spin (or just too much slip) then the "effective power" will flat line and/or just drop off (as you're not longer putting it to use in accelerating the vehicle), so for fine tuning and some road tuning on the road -- absolutely useful.
If something's fishy with your motor/setup (boost leak, etc) the power output will drop too, so it'll show up as well. Once you have the TC dialed in and actually get on the TC it'll obviously hold the vehicle at a specific power output (as more spins the tire).
The Following User Says Thank You to VitViper For This Useful Post:
FRS Justin (06-09-2016)
Old 06-09-2016, 10:54 PM   #247
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
We haven't setup my traction control yet but I'm really excited to do it eventually. Rolling launch as well. Going to make a few hits down the track without it first to collect some data.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-09-2016, 11:08 PM   #248
VitViper
Drives: '15 FRS
You should get on it, it works amazing
The package motec sells doesn't include any rolling launch logic. It's got a generic Anti Lag class, but it doesn't even come close to how my rolling launch works
Old 06-09-2016, 11:16 PM   #249
spitfire481
Drives: 2JZ FRS
Yeah my buddy built the package on mine. Actually waiting for the final license to get back from motec so I can flash my actual ecu and stop using the m1 developer ecu. He's a motec nut, Obsidian Motorsport
MoTeC
Build Thread
@spitfire481
Old 06-09-2016, 11:22 PM   #250
VitViper
Drives: '15 FRS
Awesome!
Old 06-09-2016, 11:50 PM   #251
FRS Justin
VitViper,
The logic behind this is solid, I am super stoked to see where this goes. NOW if you could just do the same with ECUTEK......lol
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (06-21-2016)
Old 06-10-2016, 12:53 AM   #252
VitViper
Drives: '15 FRS
VitViper,
You can... the logic is similar to the torque graphing "eDYno" software I wrote (much better than Virtual Dyno as I don't use their graph smoothing algorithm lol)... the limitation with the software dynos is they go off acceleration measured off driven wheel speeds (engine rpm)... which is susceptible to a lot of fluctuation with wheel slip (once you make enough power) and I've found the "faster" your car is the harder it is to get a clean graph (IE, 700whp+ cars accelerate so fast the sample rate of most datalogers suck and driven speed usually has a lot of slip).
Currently I have the ECU sampling and calculating at 50hz, which should be more than plenty... but if not I can certainly run it faster
Obviously you can skew the results if you want to though.. grab some gears down a big down hill grade... lol
CSG Mike (06-10-2016), FRS Justin (06-10-2016)
2013 White Turbo FR-S (450whp) (Update) (For Sale Again) Synack Cars for Sale/Trade 40 02-27-2016 12:55 AM
2006 STi 450whp $25000 JoeShmoe Cars for Sale/Trade 0 08-28-2014 04:46 PM
450whp Turbo FRS - TR3 Performance JPxM0Dz FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-19-2014 12:40 PM
Auto-Craft Japan Turbo FT86 BPAuto Forced Induction 5 05-21-2013 10:57 AM
ft86 turbo RWD or AWD? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 31 01-18-2010 04:11 AM
