#253 |
Drives: UK GT86
And then you lose the reason the PIs are used.... to help keep the valves clean and to help get a better mixture. It's a nice feature that ECUtek have got which means you can log the end of DI to spark timing, but only really is useful for boosted applications when you might have enough fuel to get close to the spark timing.
.: Stealth 86 :.
#254 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Oh, the PI is still being used all right. I can hardly shut it off
If I say yes, will that make you think I understand?
#255 |
Datalogs of what should be 20% PI
This should be 20% PI. It not only isn't, it's all over the place. There is obviously something else affecting PI. I don't think it's just being used for tip-in. I think there are more thresholds or something.
http://datazap.me/u/koolbrz/log-1458...g=0&data=12-13 http://datazap.me/u/koolbrz/log-1458...0&data=1-12-13
#256 | |
Drives: UK GT86
You're logging injector open time for PI and DI, just because the PI IPW is longer than the DI does not mean that it's providing more fuel. There are min/max DI and PI IPW tables, are these still untouched?
.: Stealth 86 :.
#257 | |
(edit) Could the PI pulse width have been magnified by the manifold pressure? Since I have the Phantom SC with the Procede controller it was on and boosting when the PI was jumping around. Could the PI have been using more PW to compensate for pressure in the manifold?
![]() Last edited by KoolBRZ; 03-17-2016 at 10:24 AM. Reason: ? |
#258 |
Drives: UK GT86
I have run with 0% PI and it works as it should. I would suggest something not being set right. If the PI ratio table is set to 0 then no PI will be used unless under certain idle or you exceed the max DI fuel volume parameters.
.: Stealth 86 :.
#259 |
0% PI works better than fine. I hate PI now.
0% PI tables work fine showing Pi only at idle, sometimes, 100% DI cures every single problem I have ever had with fueling. Problems I have tried to fix with AVCS tuning. I hate PI now. It's louder, less economical, and accelerates worse than DI. I'm trying to work with AVCS timing now to get the Intake Late/Exhaust Late internal EGR working correctly. I'm not sure if I can do it with DI alone, or if I need PI to get it to work correctly. I'm just concentrating on the area from .3-.5 load, and from 1200-2000 rpms. That should boost my highway mileage.
#260 |
Drives: UK GT86
1st you thought PI was beneficial, now you want to run 100% DI.....
There's a reason the OEM engineers chose what they did. You could run more DI if you like at lower load, but I wouldn't eliminate the PI completely for cruising or you'll end up with all the horrible deposits that the PI is there to help with. And as stated, the PI will help mixture formulation in the cylinder under some circumstances. EGR is not necessarily beneficial to efficiency, it is more to do with emissions, but that's for a different thread. However, you don't really want the DIs to be injecting when there's hot exhaust gasses in the cylinder IMO.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Wayno (03-18-2016) |
#261 | |
Drives: 2013 FRS
For MPG at lower rpm go to about 10-12 on the intake and 8-10 on the exhaust... That should still produce good cruising power and good MPG.... Changing the DI / PI percentage will also change your F/A ratio, I think you van run more fuel with port injection... |
#262 | |
Drives: GT86
Had to decrease the value slightly for my car. |
#263 |
Resurrecting an old thread, but for a good reason
I've been comparing DI to PI with DI and found that DI alone doesn't have as much power or acceleration. That is over-simplification, since there are firing times and angles to consider with DI as well, but I happened on a good thing because of it. From working with it in the past, I know that straight DI can handle more spark advance than PI, so I wanted to use the majority of the PI in low load areas. After several phenomenally bland and boring failures, I tried out this table, changing the PI Ratio Threshold to 15% to enable 20% PI. I was surprised to find I liked it. Knowing most people don't have access to the PI Ratio Thresholds, I tried the same design table, with the 20% ranges boosted to 35%, so the normally hidden thresholds wouldn't apply. I didn't like it as much, but it wasn't too bad. Take a look, try it out, and tell me what you think.
#264 | |
Drives:
#265 |
Drives: 2019 Subaru BRZ
U01A safe tables include a cutout for the VVT resonance area around 5000 rpm
For those who are still studying 86 VVT, here's an update from the distant future of gen1.5 red intake ROMs: the intake tables are 3 rows taller, having been tuned specifically to reduce intake advance at load 0.0-1.0 x rpm 4700-5200. This is right about where we all hear that tinny VVT resonance on K-series tunes, and it doesn't silence that resonance - but it does limit how loud it gets compared to K tunes, and I figure if they went through the effort of resizing the table to put this in, there must be something worth considering in that. So, duly noted.
EDIT: Also! Some injection-specific changes in S10C/U01A that y'all may be interested in (the S10C XML and BIN elsewhere in the forum can be used to see these in RomRaider): One value for Direct Injection Quantity Maximum has changed: RPM 2000, from 90 => 120 (increased by 30mL). The GDI Pressure A/B tables have had nearly every value tweaked. The Intake/Exhaust Duty Correction A/B/C/D tables have had most values tweaked. The GDI Flow Rate (correction) table has had most values tweaked, with many cells being set to 1.000 (no correction). Last edited by callisto; 04-06-2023 at 10:42 PM. Reason: Add other injection changes I've seen |
| The Following User Says Thank You to callisto For This Useful Post: | DocWalt (04-06-2023) |
#266 |
U01A port injection (warm) ratio table
Alongside the VVT in/ex table above, here's the ZA1JU01A port injection ratio table. It's been expanded since K-series as well, to make room for the notched series on the right, but you can compress this back down to K-series to fit without losing any fidelity by renumbering the RPM axis to (600, 1600, 2000, 2400, 2800, 3200, 4800, 5200, 6400, 6800) and copying only those rows from U01A below (or S10C, which has a romraider XML elsewhere on the forum).
This is also accompanied by a change to the PI ratio values for RPM and Load from K-series, so make sure to consider those: PI Ratio Thresholds RPM = 3200; PI Ratio Thresholds Load = 0.6. (The table PI Ratio Thresholds is unchanged.) |
| FR-S Gear Ratio Comparison | SpeedR | Engine, Exhaust, Transmission | 36 | 02-25-2016 10:34 AM |
| Best pistons to use and Comp ratio? | Fabron757 | Forced Induction | 36 | 02-05-2014 04:21 PM |
| Rear End Ratio | White64Goat | Engine, Exhaust, Transmission | 6 | 07-08-2012 12:37 AM |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 03:23 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
