Old 04-12-2016, 03:06 PM   #15
Originally Posted by MrDinkleman View Post
Wow! That must be way, way, way back in the day. I have never seen a car without an oil filter...
Yep, I don't count a piece of screen over the oil pump, as a "oil filter" .......
Old 04-12-2016, 08:33 PM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by lupindub View Post
For the people who do there own oil changes - do you pre-fill the oil filter before putting in a new one?
I dare you to try pre-refilling ours without spilling oil all over the engine bay. Also I'm pretty sure our cars have a check valve, the filter is only really filled while the engine is like a percolator, hence why when you take it off there isn't oil everything stored in there.
Old 04-12-2016, 09:39 PM   #17
tomaszjanczak
Drives: Silver Subaru BRZ
I pre fill the filter every single time and it doesn't spill anywhere
tomaszjanczak is offline   Reply With Quote
Old 04-12-2016, 11:22 PM   #18
DANG! ...... you must be quick ....... or ol @FRSBRZGT86FAN is just slow ......
Old 04-12-2016, 11:56 PM   #19
FRSBRZGT86FAN
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (04-13-2016)
Old 04-13-2016, 12:29 AM   #20
Originally Posted by MTpockets View Post
I just wish the dipstick tube was a little larger diameter so that the funnel would fit better.
Get cha one of these ...... just fill the bag and walk away.
It also serves double duty .......
Cole (05-10-2016), MTpockets (04-13-2016)
Old 04-17-2016, 08:24 AM   #21
lupindub
Drives: Scion FR-S
It also serves double doody .......
fixed
lupindub is offline   Reply With Quote
The Following User Says Thank You to lupindub For This Useful Post:
humfrz (04-17-2016)
Old 05-09-2016, 04:20 PM   #22
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Some good filters have a reverse anti-spill. If you fill it up and let the oil soak in, the oil will not come out if you put it upside down for couple of seconds. I prefill mine and don't make a mess.
Kayysonie is offline   Reply With Quote
Old 05-09-2016, 07:28 PM   #23
hmmmm.........interesting.
I'd be my luck that I'd get one that was messed up and NEVER let the oil out .......
Old 05-09-2016, 07:35 PM   #24
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Not pre fill, but do just add a spoonful of oil for early lubrication. I eyeball measurement. Then, I wet the ring gasket and such. When turning on car, I give it about 5sec each key section though. Works like a charm!
Old 06-07-2016, 01:15 PM   #25
Astroboy
Astroboy's Avatar
Drives: None
Ok, has anybody here ever mistakenly forgotten to properly tighten an oil filter resulting in oil spilling everywhere? Oil passes through the oil filter location pretty fast! I wouldn't worry about filling up the oil filter. Besides, its a small oil filter, so the the oil pump will fill it up quickly.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-07-2016, 03:27 PM   #26
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Just out of curiousity, for the "gotta pre-fill the filter" crowd... what do you think happens to the oil in our upside-down filters once the car's been sitting for a few hours? Should we pre-fill it every time we start the car?
There are some cars where the manual highly advises prefilling the spin-on filters, not only to aid in getting the oil to all parts of the engine faster upon startup but also because, in some engine designs, there's a chance the oil pump would fail to prime w/ an empty filter. The shop manual warned about that in my old Range Rover. It's not a concern with the twins. Lube the o-ring, put on the filter, and be happy.
Barry
MuseChaser is offline   Reply With Quote
Old 06-07-2016, 03:54 PM   #27
OkieSnuffBox
Drives: '23 BRZ Limited
And what, exactly, do you think you're accomplishing with this?
Heating up the glow plugs on your diesel?
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
XanRules (06-14-2016)
Old 06-07-2016, 03:58 PM   #28
Packofcrows
Waiting for my Vtec to kick in yo
ps not necessary. Maybe useless. A practice I will continue to follow. To me it's like washing hands twice. May be useless. I do it. Don't harm me.
The Following User Says Thank You to Packofcrows For This Useful Post:
OkieSnuffBox (06-07-2016)
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 01:14 AM
How often u guys fill the tires air? clfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 10-10-2014 01:42 PM
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Fill and paint? or PDR... rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-12-2014 09:36 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 05:46 PM
