Old 06-06-2016, 08:36 PM   #3515
CSG Mike
CSG Mike's Avatar
Originally Posted by Sleepless View Post
Since I already have the JR oil cooler, what are my radiator choices and will they get temps down to 210F? 220F?
I can't say conclusively if your temps will drop, as I have no other data to work with from you. Either you have enough cooling or you don't; there's no "in between".
The Koyo would be the route I'd go for cost effectiveness. If you want something with more clearance, a custom radiator (that maximizes clearance, and also has a shroud built-in for aftermarket fans) or just the core portion of the JR Dual cooler are options.
The extra noise from fans is subjective; I don't mind it at all since you barely hear them with the windows up, and not at all at highway speeds or with the radio on.
Jmonty (06-06-2016), Sleepless (06-06-2016)
Old 06-07-2016, 12:56 PM   #3516
cgjeff
Drives: 2015 Scion FRS
First dyno runs
Dyno results from last Friday. 2015 FRS, JRSC-C30 Kit, Delicious Flash N Go Tune, Ace 350 Header, and full exhaust. Running Clear (non-ethanol) 92 Octane fuel. Learned a lot regarding dyno's, fuel, and future upgrades. Ambient temps were 90+, so took some time to cool the car down before the 3rd... and best pull. Glad to have some numbers on paper to see where things go!!
cgjeff is offline   Reply With Quote
The Following 3 Users Say Thank You to cgjeff For This Useful Post:
CSG Mike (06-07-2016), CxG (06-24-2016), Xuningshen (06-07-2016)
Old 06-08-2016, 10:42 PM   #3517
twag4
Drives: frs
So my power problems were a bad catalytic converter. It came loose from the shell then got compressed into the conical section of the exit of the cat. It compressed the core into a cone shape then started peeling the outer layers away. It was a high flow metallic core cat. Anyway, problem solved.
twag4 is offline   Reply With Quote
The Following 3 Users Say Thank You to twag4 For This Useful Post:
cgjeff (06-09-2016), CSG Mike (06-08-2016), Hicklinc (06-10-2016)
Old 06-10-2016, 03:11 AM   #3518
Irace86
Drives: BRZ + Ducati M796
Anyone have a picture of the EO# badge, engraving, certificate, whatever it gets for the CARB legal tune?
Irace86 is offline   Reply With Quote
Old 06-10-2016, 08:00 AM   #3519
Hicklinc
Drives: N/a
Is it me or is this low for having a full exhaust
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 06-10-2016, 09:57 AM   #3520
dp1
driving smoother faster
Drives: Sold
Location of the cat? Brand of header or front pipe it was on? Was this on hw you bought new or was used by someone else before?
dp1 is offline   Reply With Quote
Old 06-10-2016, 12:31 PM   #3521
cgjeff
After talking with Mike at CSG and Zach at Delicious, we have some theories on the low dyno results. Conservative Dyno, Traction Control not fully turned off, Poor fuel choice, Heat soaked system. First time experience for me, so will be better prepared next time. Data logs have been reviewed by Zach and the dyno numbers do not best represent how the car is actually running.
Ass in the seat says much more... lol.
Old 06-10-2016, 02:02 PM   #3522
CSG Mike
CSG Mike's Avatar
If you've purchased a CARB tune, you should have a CARB sticker.
Old 06-10-2016, 02:23 PM   #3523
Hicklinc
Drives: N/a
Interesting i was expecting at least 25 more hp at the wheels on a dynojet and with 92 but those guys know what they are talking about did you happen to get a baseline before the kit i would be interested to see it
Old 06-10-2016, 02:35 PM   #3524
CSG Mike
CSG Mike's Avatar
Quoting an e-mail sent to @cgjeff:
Based on a gasoline run and a 160 baseline, 236whp is about right; this extrapolates to 295 crank horsepower.
That dyno reportedly reads about 160whp on a 200hp stock car.
200 / 160 * 236 = 295
Crude, but somewhat accurate.
cgjeff (06-10-2016), Hicklinc (06-10-2016)
Old 06-10-2016, 02:36 PM   #3525
cgjeff
No baseline on my car, but they do have two others that dyno'd at 160 & 161 whp.
The Following User Says Thank You to cgjeff For This Useful Post:
Old 06-10-2016, 02:53 PM   #3526
Irace86
Im hoping to get the Harrop kit once it gets CARB approved but considering the Edlebrock kit is advertised as a CARB kit even though it is CARB pending I got curious if anyone actually received a CARB sticker from either the JRSC kit or Works kit (only approved kits I'm aware of).
Old 06-10-2016, 03:26 PM   #3527
CSG Mike
CSG Mike's Avatar
CARB stickers are included with the purchase of a CARB tune, for the Jackson Racing kit.
Off topic, but Edelbrock will be mailing out CARB stickers to owners shortly.
Also off topic, but the Harrop kit is also pending.
Irace86 (06-10-2016), kuczynskika (06-10-2016)
Old 06-10-2016, 04:07 PM   #3528
Irace86
As you know, 'it's common knowledge that the kit is CARB approved' type of conversation doesnt work with the popo.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
