Old 06-06-2016, 09:12 AM   #71
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Good point about also checking the windshield washer fluid level .....
Do you guys really do it? I just use it until there is none left, and then I put new fluid in.
Actually. I just realized I do not check any of these fluids. I have people check it for me when I bring the car in for oil change/tire rotation, and that's it.
I did check oil in the beginning a few times, but once I figured my engine does not consume much of it, I stopped. (but I don't drive a twin, maybe twins need more care).
I regularly check the level of one fluid only, that was not mentioned in any answer to Question 10, that is FUEL!
mdm is offline   Reply With Quote
Old 06-06-2016, 07:49 PM   #72
JFunk
JFunk's Avatar
Drives: 2013 Scion Frs
I've come to the conclusion that this wire is for an amp the previous owner had but I'm not sure and if so can I remove this on my own? Never worked on a car before besides oil changes and removing fenders and bumpers. I really want to take this off because it makes my interior look ugly even if it's just a small wire.
JFunk is offline   Reply With Quote
Old 06-06-2016, 07:57 PM   #73
OH CRAP!
Get that thing out of there. You have a positive wire shoved through the sharp stamped sheet metal. That is a time bomb just waiting for the wire case to get cut by vibration and burn your car up. I am not overreacting, exaggerating or joking here!!!!
Edit: I missed seeing what could be a fuse tucked down beside the battery but still get rid of that wire.
Old 06-06-2016, 07:58 PM   #74
JFunk
JFunk's Avatar
OH CRAP!
Oh my god, how do I go about removing it if you know? Or should I take it to a shop?
Old 06-06-2016, 08:00 PM   #75
Pickleahoy
Drives: 10 Series #1617
Dont let Tcoat and his Canadian freak out take over you, simply remove the wire from the positive terminal and pull it out later at your convenience.
Pickleahoy is offline   Reply With Quote
Old 06-06-2016, 08:01 PM   #76
JFunk
JFunk's Avatar
Picking up my FRS tomorrow
Got it I imagine I disconnect the battery or just leave the car off will do
Old 06-06-2016, 08:05 PM   #77
Ya just unhook it.
It was a much bigger concern before I spotted the fuse. Still a dumbass way to run a wire. That gauge wire, hooked directly to the battery, going to dead ground would be a major issue.
Old 06-06-2016, 08:06 PM   #78
Just leave the car off and remove any fasteners holding the wire. Easy as can be.
Old 06-06-2016, 10:51 PM   #79
I would've said exactly the same thing. I about shit myself when I saw it.
@JFunk, if you disconnect your battery be prepared for some lousy throttle response until the ECU sorts itself out again. There are some shortcuts but you have enough on your plate. Just drive normally. Get out onto a highway and drive steadily for several miles.
Old 06-06-2016, 11:02 PM   #80
FingerDiddle
Drives: Camry 08
Inb4boom
FingerDiddle is offline   Reply With Quote
Old 06-07-2016, 12:50 AM   #81
Heck, I'd just snip the wire up next the battery and cap it off with a wire nut .......
Old 06-07-2016, 01:42 AM   #82
JFunk
JFunk's Avatar
Update on the wire took it off and immediately started working on a friend's motorcycle, the wire came off pretty easy after I took some plastic from my interior off just pulled right off. The previous owner was so shit at all as the wire from the battery wasn't connected to the back because it was cut and places under the trunk carpet thing (wth is that called) and wrapped with electrical tape
Old 06-07-2016, 08:13 AM   #83
stevesnj
stevesnj's Avatar
Who knows if its the correct fuse for the wire.
My 2016 Build thread
Old 06-07-2016, 08:22 AM   #84
There is that as well. If somebody would run it through the stamped hole with no protection god only knows what else they would do. If it was a small gauge wire then even though still bad it wouldn't have been as scary as having that huge, braided, heating element running the length of the car.
manual, newbie
Picking up a Scion FRS tomorrow! Olivervaldez Scion FR-S / Toyota 86 GT86 General Forum 46 12-23-2013 10:43 PM
Picking up BRZ tomorrow... sub_stance CANADA 17 03-25-2013 12:48 AM
Picking up my FRS Tomorrow! Tips please! peachsnow Scion FR-S / Toyota 86 GT86 General Forum 35 12-14-2012 11:47 PM
Picking up my Asphalt AT tomorrow! pixel67 Scion FR-S / Toyota 86 GT86 General Forum 21 09-19-2012 01:58 PM
Picking up my Asphalt FR-S tomorrow! markmatley Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2012 09:34 PM
