Old 05-31-2016, 02:28 PM   #1331
taiguy
Drives: 2013 Black BRZ Limited
Originally Posted by Kodename47 View Post
@taiguy did you swap the injector O rings over? Looks like fuel/oil leak from somewhere.
Yep, o-rings were in place, although I don't know what you mean by swapping them over.
taiguy is offline   Reply With Quote
The Following User Says Thank You to taiguy For This Useful Post:
86Tony (06-06-2016)
Old 05-31-2016, 04:21 PM   #1332
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by taiguy View Post
However, while both were put in dry, when I took them out, they were visibly "wet". More fuel buildup?
Also double checked the hoses going back into the throttle body top to bottom: evap, brake booster, and PCV.
After shooting Mike a quick email my plan is to put it all back together later this week and see if I can't generate some new logs.
Puzzling...
We're both of the gaskets wet or just the passenger side? If they are both wet, could it be just blowby?
Was only one injector dirty on the passenger side?
djdnz is offline   Reply With Quote
Old 05-31-2016, 04:43 PM   #1333
taiguy
Both gaskets were wet.
Only the front passenger side port injector was visibly dirty on the outside.
Old 05-31-2016, 05:01 PM   #1334
MrDinkleman
Drives: 2016 Oceanic, "base" model
I searched on "IS300" and "lower gears" but found nothing.
Did anyone install the lower gears from an M/T, LSD, IS300 after installing this? If so, did you get better mileage?
MrDinkleman is offline   Reply With Quote
Old 05-31-2016, 07:51 PM   #1335
djdnz
1337
Originally Posted by Edelbrock LLC View Post
We appreciate the feedback. If you have not already, please reach out to our tech department first to relay info pertaining to your specific vehicle. There are many factors that could contribute to your case and we want you to be 100% satisfied with our product.
Hey Edelbrock, could you share the part number for MAF o-rings? When I checked my MAF to make sure it was clean, I noticed there was a small tear on the side.
Old 06-01-2016, 12:10 PM   #1336
Edelbrock LLC
Edelbrock LLC's Avatar
Drives: 2013 Subaru BRZ
MAF Sensor O-ring:
51-4223
For future part numbers you can also reference Pages 3-7 of the installation notebook. Each part included in the kit will have designated "P/N."
In the above case see: PG. 3, Bag #4, Item 6.
Please let our tech dept. know of the torn o-rings and we should be able to mail replacements right out.
Edelbrock LLC is offline   Reply With Quote
The Following 3 Users Say Thank You to Edelbrock LLC For This Useful Post:
CSG Mike (06-01-2016), djdnz (06-01-2016), taiguy (06-01-2016)
Old 06-02-2016, 12:04 PM   #1337
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Short update with my BRZ. I had an opportunity to dig into the car over the holiday weekend.
A few bolts later, the supercharger and manifold were also free so I took a look at the gaskets. Both manifold gaskets were seated correctly and no signs of tears, cuts, or squishing.
Hi taiguy,
From the picture, it seems like there might be some tearing on one of your seals. Somewhat hard to tell if it's damage or grime from just the picture. Edelbrock suggests using lubrication on these to keep from folding or tearing during installation.
Nitro22 is offline   Reply With Quote
Old 06-02-2016, 01:29 PM   #1338
toast
Drives: 14 BSP Edelbrock BRZ
That looks like casting flash that just has oil on it.
Sent from my Nexus 6 using Tapatalk
toast is offline   Reply With Quote
Old 06-02-2016, 07:23 PM   #1339
Nitro22
Nitro22's Avatar
That would be a poor place to have flashing from a mold. There was another Edelbrock customer who had damaged his manifold gaskets in the same area.
http://www.ft86club.com/forums/showp...&postcount=749
Not definitively saying this is the reason for his problems, but just something to look out for in future installs.
Old 06-02-2016, 07:40 PM   #1340
toast
Nice catch, that does look like exactly the same place that got snagged on the other install.
The Following User Says Thank You to toast For This Useful Post:
Nitro22 (06-02-2016)
Old 06-02-2016, 09:20 PM   #1341
taiguy
Have a whole (small) tub of silicone grease dedicated to putting the new gaskets in. Will probably be a project for next week, I'm still rushing to get motorcycles prepped for the weekend.
Old 06-05-2016, 01:07 AM   #1342
EJ.
e85!
EJ.'s Avatar
Drives: 2013 Scion FR-S M/T
Finally threw some DTCs this afternoon.
P0171 - System too lean bank 1
C1201
B14A1
This may pertain to you since you have similar idle issues, and CEL codes as I did relating to a vacuum leak. My vacuum leak was coming from the actuator that sits under the driver side of the Edelbrock supercharger housing. Every time I sprayed it with the car on and at idle, it bogged down and stalled out. Huge shoutout to Topher from Edelbrock for helping me get the replacement asap. Same day as I called Edelbrock, Topher shipped out a new actuator and it arrived 2 days later. I replaced the actuator, spray tested the new one, and engine idle remains constant. Cleared the code and I'm good to go. Idle is back to normal after testing and no longer jumping or stalling out. Haven't popped a code since. Again, thank you Edelbrock for the quick response and awesome customer service.
Scion FR-S M/T | HRI Tuned - AMS Catted Header - DW 700cc injectors - DW 265lph Fuel Pump - MotoEast Flex Fuel Kit - Greddy Evolution GT Catback Exhaust - Exedy Stage 2 Clutch - Edelbrock Supercharger
EJ. is offline   Reply With Quote
The Following 3 Users Say Thank You to EJ. For This Useful Post:
BigFatFlip (06-05-2016), stoked_on_spool (06-05-2016), taiguy (06-06-2016)
Old 06-05-2016, 12:43 PM   #1343
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^also, I've been told by Edelbrock to never actuate that by hand since you can accidentally tear the rubber diaphragm inside.
The Following User Says Thank You to BigFatFlip For This Useful Post:
EJ. (06-06-2016)
Old 06-06-2016, 12:02 AM   #1344
taiguy
Is this actuator part of the supercharger housing? So an edelbrock part?
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
