Old 06-03-2016, 09:21 PM   #295
Astral Abyss
Drives: 2016 Halo FR-S
Yup, I have an auto.
Astral Abyss is offline   Reply With Quote
Old 06-03-2016, 09:22 PM   #296
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Cool!
http://www.ft86club.com/forums/showt...=96615&page=13
That's the thread where I started the issue and we eventually got the TSB created feel free to read through it.
Old 06-03-2016, 10:49 PM   #297
Astral Abyss
Originally Posted by FRSBRZGT86FAN View Post
Cool!
I took another video of it tonight while it was idle searching to show the dealer. I'm hoping to take it in next week. Calling tomorrow for an appointment. I will update on that thread once I get the reprogram done and road test it.
I have the hard shifting issue in Sport mode as well.
Thanks for starting that thread. This form is a great resource and good folks like you are what make it so.
Old 06-04-2016, 12:06 AM   #298
FRSBRZGT86FAN
It's really down to the dealer honestly, some, like in my case, are super chill and would just flash it immediately without asking and no big deal. Others would refuse and say it's not in the VIN range so they wouldn't, best of luck to you.
Old 06-05-2016, 02:49 AM   #299
Lastexile
Lastexile's Avatar
Drives: 2013 Firestorm FR-S
Since none of these are really safety recalls (well there are a couple but they are minor, a sticker on the car and one that applies to AT cars if you can pull the key out while in a gear other than park) it would have to be under warranty, and showing the problems.
A car purchased used can still be under warranty. A 2013 is very unlikely to still be under the 36 month/36K bumper to bumper warranty, although I suppose its possible if it were purchased late in the 2016 model year (the 2013 first went on sale in 05/2012). The powertrain warranty (60/60) may still be in place, and would cover a few of them.
If you aren't the original owner and have no proof of when it was originally purchased the dealership will use the VIN to determine the start of warranty, which will be the day it was originally sold.
One I would consider getting done is the fuel pump one, but I would put it off until near the end of the warranty period. Not so much because it's a real mechanical issue but because it ends up giving you a new fuel pump.
Thanks a lot for all that information. I bought it from a Toyota dealer and it's certified. I think it might still be under warranty. I'll call them and ask.
Lastexile is offline   Reply With Quote
Old 06-09-2016, 05:37 PM   #300
Astral Abyss
Took my FRS to the dealer yesterday. No issues with getting the flash done. I handed them the TSB, told them the issues clearly, and they did it. They mentioned afterwards that I was the first person to report and bring my FRS in for this idling/hard shifting issue.
I can already confirm that it works and stops both problems (idling and hard shifts) from occuring. After driving home yesterday from work (25 miles) my FRS did what it always does right before the idling issue starts... the tach makes a weird spike up to 1000rpm (almost like the gauge is sticking) right after I put it in park. But instead of slowly dropping to 500rpm, starting to stall, and then spiking back to 1000rpm, it stabilized at 700rpm immediately.
No sign of hard shifting in Sport mode either. In fact, it's been shifting better than it ever has.
You can't imagine how happy this makes me. These were two niggling problems that are now gone.
Old 06-20-2016, 03:05 PM   #301
@Sigh-on-Rice
Looks like the Southeast Toyota "Gross Weight Sticker Gate" has been extended to include various 2015 models with a total of 2,520 of all models impacted. The original link is no longer valid.
Here is the updated link.
Originally Posted by NHTSA 16V420000
Southeast Toyota Distributors, LLC (SET) is recalling certain model year 2016 Toyota Camry and Highlander, 2015-2016 Toyota Tundra, Scion FR-S, and tC vehicles. The Load Carrying Capacity Modification Label may not reflect the correct added weight of the installed accessories. As a result, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 110, "Tire Selection and Rims for Passenger Cars."
Old 06-20-2016, 03:27 PM   #302
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
@Sigh-on-Rice
Thanks. I updated the first post.
Old 06-24-2016, 02:18 PM   #303
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
Would any of you be able to send me the PDF for Subi Bullet 02-132-12R.. it looks like 02-132-12 was revised a about a year ago.
Thanks,
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 02-12-2017, 08:09 PM   #304
SooNomi
Drives: 2016 BRZ Limited
TSB 16-96-15
PDF of TSB 16-96-15 (TCM Reprogramming File Availability for Engine Idle RPM Fluctuation on 6AT- Equipped Models) is attached.
Reference: AT Hard Shifting issues
SooNomi is offline   Reply With Quote
Old 02-12-2017, 10:29 PM   #305
Sigh-on-Rice
Thank you. Updated the first post.
Old 04-07-2017, 03:55 PM   #306
Khánh
Khánh's Avatar
Drives: sc00ter
what is the warranty on the oil leak on passenger side timing chain cover for FR-S? is it the same Bullet as Subaru 02-136-12R?
Khánh is offline   Reply With Quote
Old 04-19-2017, 05:41 PM   #307
DarkSideFRS
Drives: 2013 pearl white FR-S
seeing that there are 3 different TSBs for the Chirping Noise from High Pressure Fuel Pump issue, are the older TSBs voided and only the current one is active? I ask this as my VIN is covered in the original TSB but not in the 2 revisions
also, it doesn't look like there is anything on the rod bearing #4 issue (due to oil starvation)? I just found out abt this today.
DarkSideFRS is offline   Reply With Quote
Old 05-22-2017, 09:32 AM   #308
Minor Safety Recall 2017 Toyota 86, Gulf States
There's a NHTSA safety recall today for a large list of 2017 Toyotas from the "Gulf States Toyota" region for underinflated spare tires. Impacts a grand total of 409 cars spread over 12 models.
NHTSA ID: 17V295
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
