Old 06-03-2016, 03:34 PM   #127
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
Originally Posted by Uplink View Post
Yup. If you're flat out up the Esses and stay on it as late as you can before the bus stop crashing the first ones pretty hard 120 is about the best my stock plus exhaust & drop in FR-s saw and it's struggling.
Even on the Pocono Mega Configuration we run (3.something miles), exiting the infield at the top left red (see below) and running clockwise all the way to the 1st top right blue, 120 is still about it. You're just revving the bejesus out of the motor and not really getting any faster.
Jeez even at Pocono? I haven't ever been there but I would expect a bit faster. I want to get one more baseline on all OEM bits at the Englishtown road course and then I'm splurging for a light set of wheels with 245 wide RE71R tires and a tune. I'm willing to bet after that I can bring up my top speed to ~125 before the bus stop @ WGI. If the twins had a power curve like the S2000, they would be FAST.
Yanbags is offline   Reply With Quote
Old 06-03-2016, 03:55 PM   #128
dp1
driving smoother faster
Drives: Sold
135mph per GPS with JRSC at Pocono Raceway South East option 3. Could have squeezed a few more mph but it feels like even stock aero fights acceleration considerably above 130mph.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Uplink (06-03-2016)
Old 06-03-2016, 03:56 PM   #129
Originally Posted by fumanchu1 View Post
YEs please!!!! Now I really wonder how fast I could get on one of those... provided it's a closed course, private road(with guaranteed no traffic) or an abandoned airstrip or something.... I keep wondering whether or not my small local airport would allow me to get on their runway to do logs and try my top speed ? probly not
Well, you could ask them.
You could say that you have this "special wing" that you think will allow your machine to fly ..... and you want to test it out.
If the airstrip doesn't have a control tower, be sure to monitor the appropriate radio frequency and keep an eye out for landing aircraft.
That strip in my picture has two road exits at one end and one road exit at the other. The donut shop is about 2 miles away.
However, I didn't feel "lucky" that day ...... so, I stood down .....
Old 06-03-2016, 04:04 PM   #130
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
it's a very small local airport with only regional flights in tiny planes. I don't even think they have flights running 24h/day lol
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
humfrz (06-03-2016)
Old 06-03-2016, 04:06 PM   #131
Uplink
Uplink's Avatar
Drives: anything you let me
For our cars stock, the factory 160mph speedo is WILDLY optimistic. We're power/aero limited even though the gearing may be there.
It actually goes to show that if you're sticking with stock(-ish) power, a diff upgrade may be the way to go since you won't cut down the practical top speed even though theoretical top speed drops.
Uplink is offline   Reply With Quote
Old 06-03-2016, 04:11 PM   #132
Uplink
Uplink's Avatar
This is probably exacerbated on any car not running the factory exhaust. That open area behind the diff probably creates a lot of turbulence and the bumper cover makes a mini-scoop. @VeloxEric could answer this better though.
Old 06-03-2016, 04:15 PM   #133
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I gotta stop reading this thread, it's got me wondering if finding out my top speed at the local airport is worth the repercussions and probable police chase
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 06-03-2016, 04:58 PM   #134
fumanchu1
If they can even keep up...
Tectoniic (06-03-2016)
Old 06-03-2016, 05:15 PM   #135
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We've heard and seen significant gains in aerodynamic efficiency through our diffusers. With the stock exhaust, we notice about 5% increase in economy at 75 MPH (36MPG no diffuser - 38MPG diffuser). Without the stock exhaust, we saw an increase of approximately 12% (34MPG no diffuser to 38MPH diffuser).
The cars are fairly aerodynamic to start with though. Best bang for the buck would be a diffuser than a small splitter that doesn't create a ton of downforce. Check out the rear diff/transmission tunnel covers, those both aid in reducing turbulence underbody, as well as the JDM underbody covers.
Hope this helps some .
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Uplink (06-03-2016)
Old 06-03-2016, 05:29 PM   #136
Uplink
Uplink's Avatar
Thanks Eric, that's what I thought!
Old 06-03-2016, 07:44 PM   #137
DarkSunrise
DarkSunrise's Avatar
Between 121-122 mph at various tracks. Car is stable even at those speeds, but does not feel like it has much left.
I can't imagine how much room it took magazines to hit the ~140 mph tested top speed.
2022 BRZ Build
2013 FR-S Build
Old 06-03-2016, 07:51 PM   #138
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Runways bro and a good entry, mechanically speaking the transmission and gear ratio are limited to 165-175
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
DarkSunrise (06-03-2016)
Old 06-03-2016, 07:56 PM   #139
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
This actually brings up an interesting thought. The car will go fast, but not get there fast, no power, duh, so it seems that top speed would be an easy sacrifice to get some more acceleration to a lower top speed. It's got me thinking of going with a taller rear gear.
The Following User Says Thank You to themadscientist For This Useful Post:
chaoskaze (06-05-2016)
Old 06-03-2016, 08:58 PM   #140
Allow me to drag up this formula from a past post.
Who would like to do the math .. ??
(please include the parameters involved, especially frontal area).
chaoskaze (06-05-2016), Ultramaroon (06-05-2016)
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
Need For Speed... Really? Texas BRZ Tracking / Autocross / HPDE / Drifting 61 01-11-2013 11:59 PM
Top Speed L3P47 Scion FR-S / Toyota 86 GT86 General Forum 6 12-18-2012 12:06 AM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 09:23 AM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
