Drives: '88 BMW 535is Turbo
Nameless Performance Equal Length Stepped Header
We just wrapped up our first equal length stepped header for the BRZ, featuring mandrel bent T304 stainless construction and an optional high flow catalytic converter in the factory location for SCCA racing compliance. We're excited to take this and the next design or two we are working on to the dyno on Thursday.
![]() So far this is what we have got to show - the first prototype system is a Tri-Y design featuring 1.625" equal length (within 0.8%/.125") primaries and equal length (within 8%/.5") 1.750" secondaries into a 200 cell high flow catalytic converter with a 2.5" outlet to the over-pipe (will be fabricating a 2.5" overpipe also). There are two secondaries at the bend that is facing left, they are stacked on top of each other, and the higher of the two is not visible in the photo. This header does fit in the factory skidtray and ceramic coating will be an option. We have also discussed a faceted sheet metal heat shield. Our goal is to include our customers in our development process at every turn and we've got a fork in the road to determine which of the four other design ideas we should test first. So we'd like your input. According to our exhaust flow dynamics software the existing design is optimal with secondary runners being of a length that requires the removal of the catalytic converter. We were considering replicating this system exactly with long 1.75" secondaries in place of the catalytic converter. This would most likely require a jetted secondary oxygen sensor fooler to keep from throwing a check engine light. Alternately, we can build out a torque biasing design using 1.5" primary pipes and 1.625" secondary tubing with a high flow catalytic converter like the first design. The other alternatives are to run a long tube stepped 4-1 design with or without a catalytic converter but utilizing one of the above primary/secondary sizes, or going up in size (not looking terribly favorable from our preliminary calculations). So what would you like to see, we would love to have your feedback. All of the designs will probably get prototyped one way or the other. This is the first production header we will be offering and we'd like to gain as much development knowledge as possible from the process. Lets chat! Jason Griffith Engineering Director Nameless Performance Last edited by Jason@Nameless; 06-20-2012 at 04:27 AM. |
| The Following 90 Users Say Thank You to Jason@Nameless For This Useful Post: | 20valvewynn83 (10-08-2012), 2fast4you (06-19-2012), 3MI Racing (06-20-2012), adprokid (06-21-2012), AJUSA.com (07-17-2012), altezza280t (09-13-2013), Anthonytpt (01-29-2013), armythug (06-19-2012), autobrz (06-19-2013), BAE (07-30-2012), baldolera (06-19-2012), blackfireball5 (07-04-2012), BobDigi5060 (06-21-2012), Bonburner (01-24-2013), boxer 2.5 (10-18-2013), Brzce (08-23-2012), BugeyedWagon (06-25-2012), CamryDS (07-05-2013), chanomatik (09-10-2012), chulooz (06-19-2012), civicdrivr (06-20-2012), CoRi J (06-20-2012), dura1198 (08-30-2012), Efferalgan (07-28-2013), ESBjiujitsu (06-20-2012), F3dzo (06-26-2012), flippy (08-10-2012), Fly Guy (06-19-2012), Freeman (10-25-2012), FRSPirate (06-19-2012), FT86POWER (07-03-2014), ftc~brz (02-02-2013), Grateful Dave (02-14-2014), GT86_PRAGUE (12-14-2014), Guff (06-21-2012), Ice_Man (06-25-2012), ill86 (06-26-2012), illmatic (06-19-2012), irax (01-04-2014), Jayde (06-20-2012), Jeff86 (11-18-2012), karbon (07-25-2012), karma003 (11-03-2013), Kiske (12-09-2013), kwood9000 (02-17-2013), lazyluka (07-28-2013), LivingLegend (06-19-2012), m0nty (07-03-2012), MannyO (06-20-2012), MarkRacerX (06-27-2012), MattR (06-19-2012), MaXimus (01-02-2013), Mike86 (05-01-2013), mpicher (06-23-2012), Mr. (09-18-2013), Neilus (06-22-2012), Noble713 (06-26-2012), QFry (08-09-2012), raul (04-15-2013), RazBRZ (09-11-2012), Ricepuddin (07-02-2012), RRnold (11-15-2013), RWD_only (06-19-2012), Scooby South (06-29-2012), Sexyeve (07-05-2015), Silp3 (02-21-2013), SkAsphalt (10-04-2012), sklimo (04-01-2014), Slartibartfast (10-12-2012), Snoopyalien24 (06-20-2012), soros151 (11-20-2012), sparks (06-25-2012), Spartan65 (10-12-2012), SprayedBigCube (07-08-2012), suaveflooder (09-07-2013), Surok (03-04-2013), Tad_07 (06-28-2012), Tainen (06-19-2012), tech4pdx (07-14-2013), Theothanatologist (10-30-2012), Touge Monster (06-28-2012), tripjammer (10-12-2012), ultra (01-05-2013), Visconti (07-04-2012), WazzuGrad (10-18-2014), wheelhaus (08-23-2012), wlwarfield (01-17-2014), WRB-DZA-BRZ (06-20-2012), WRXGuy1 (01-23-2013), zoomzoomers (02-01-2013) |
#3 |
Update: Up 46ft lb and 36whp in the dip:
![]() Dyno results of prototype 1.625 primary 4-2-1 Catted Header with full exhaust: Combined Data (note that lower peak modded run made 29hp vs. the lower peak power baseline, albeit at the very top of the range). Needless to say, once the tuning solutions start popping up, this header will support some serious top end capacity...and the catless versions should do even better based on their ability to run more appropriate, longer, secondaries: ![]() Horsepower Alone: ![]() Torque Alone: ![]() Gains in HP/TQ and % Increases: ![]() (note, these graphs above are still for prototype parts, we're pretty confident there is more power to be had with other configurations that we will be testing very soon) Weight Specifications: Factory Header w/o Heat Shields: 15.0lbs Nameless Performance Stepped 1.625-1.750 Catted Header w/o heat shields: 11.6lbs Nameless Performance Stepped 1.500-1.625 Catted Header w/o heat shields: 10.9lbs Last edited by Jason@Nameless; 02-13-2013 at 10:17 PM. Reason: Added ballistic torque graph.... |
| The Following 33 Users Say Thank You to Jason@Nameless For This Useful Post: | autobrz (06-19-2013), Bonburner (01-24-2013), carbonBLUE (06-27-2012), chanomatik (03-10-2014), Efferalgan (07-28-2013), fuddbutter (08-03-2012), Future (06-26-2012), GT86_PRAGUE (09-11-2015), Ice_Man (06-25-2012), juliog (08-09-2013), Kiske (12-09-2013), kwood9000 (02-17-2013), lantsalot (05-18-2017), LeeMaster (12-31-2012), MarkRacerX (06-27-2012), Metabrz (06-24-2012), Mr. (09-18-2013), RehabJeff86 (12-01-2013), Scooby South (07-24-2012), ShoGun (06-28-2012), SkAsphalt (06-15-2013), sklimo (04-01-2014), Slartibartfast (10-12-2012), Snoopyalien24 (07-12-2012), soros151 (11-20-2012), sparks (06-25-2012), Surok (03-04-2013), Tad_07 (06-28-2012), tech4pdx (07-14-2013), tripjammer (02-16-2013), UNREAL (04-27-2016), WRB-DZA-BRZ (06-13-2013), XCIV.Andrew (09-05-2013) |
#4 |
Site Moderator
Drives: Stuff
Wow FWIW that header looks nice. Since this will be a DD more than anything for me I'd prefer to keep the cat. Who makes the high flow you use btw?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Fly Guy (06-19-2012) |
#5 |
Registered you sir
Drives: 99 impreza coupe
I'd like to see results for this baby before I suggest your next move. (no cat/longer secondaries)
#6 | |
Jason Griffith Engineering Director Nameless Performance, Inc. |
| The Following User Says Thank You to Jason@Nameless For This Useful Post: | Strife26 (11-17-2016) |
#7 |
Drives: First SWP BRZ-L
I'd be real wary of a non-catted header system right now I think. I say that because we don't have any tuning solutions, so the stock o2 sensors are expecting a cat of some sort. I'm no tuner so I don't know what that would do, but without the ability to properly adjust the ECU to account for cat-less, I'd stay with the cat. Maybe target a catless system for 4 months out or so, when ECU tuning is more prevalent.
For now, my biggest concern is the heat soak. It's right next to that coolant line, and surrounds the oil pan. Doing some sort of a coating or wrap would probably help, but I'd love to see temperature data on the difference to know that a coating or wrap would be good enough to keep coolant/oil temps in check (and to keep that line from melting). Where does the 02 bung go? Will I melt my coolant line without coating this thing, or cause bad coolant temps? For a torque bias design with smaller diameter pipes, what would you think it would do, higher torque down low but less overall power? percentages or thoughts? excited to see dyno graphs.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#8 | |
Site Moderator
Drives: Stuff
-Dave
#9 | |
Site Moderator
Drives: Stuff
However, headers on Hondas can be <1" from the oil pan and very close to AC lines and some coolant lines and it's never caused an issue there. Although I'm sure they can offer a model with a heatshield.. IMO it's just one more thing to break. Coating wouldn't be a bad idea. I don't like wraps myself..
-Dave
#10 | |
Heat concerns: This is a naturally aspirated car with very little backpressure in the primary catalytic converter. If it were a turbo car, I'd expect to see manifolds glowing white hot, but in this application I am not a bit concerned about proximity to the coolant line or the oil pan if some method of shielding is provided. As for melting the coolant hose, you'd have to work REAL hard to accomplish that. Even a small air gap in that are is going to provide enough thermal barrier to prevent that heat from reaching damaging levels. The good news is, we do have the ability to build faceted heat shields to selectively reduce the thermal transfer between critical components. We also have laser temp guns to monitor temperatures on the dyno. And we will be doing so. The other thing to note is that a two dimensional photo doesn't do justice to the distances that exist between these components. We did our best to keep the equal length while optimizing clearance for future development of heat shields as well as keeping this as clear as possible from the engine. Additionally, if you're worried about track oil temps, we have plans for a thermostatically controlled oil cooler as well - but I think your track driving behavior is going to be the oil temp modifier far more than the headers proximity to the oil pan. Again, all things we plan on monitoring and gathering data from in order to add components that are necessary for optimal design on the street and the track. As for the O2 sensor bungs, they are in the factory locations up top. Torque biasing header I think you would indeed sacrifice top end power, but it's really a testing question - if you gain 8 additional ft-lb of torque and lose 2hp at the top end, that's an easy selection to make. We could also do a triple stepped design, but again, that requires all of the real estate occupied by the header. More questions/thoughts!! Keep em comin'! Jason Griffith Engineering Director Nameless Performance, Inc. |
| The Following 9 Users Say Thank You to Jason@Nameless For This Useful Post: | autobrz (06-19-2013), Bonburner (07-23-2012), civicdrivr (06-20-2012), dun3 (03-25-2013), GT86_PRAGUE (09-11-2015), lucchesi423 (06-20-2012), sparks (06-25-2012), tripjammer (02-16-2013), WRXGuy1 (01-23-2013) |
#11 |
Drives: Scion FR-S/ Subaru BRZ
sweet header!!!!
I also think a torque increasing header is a great idea....the high flow exhaust and intake will increase top end power.....the ideal powerband for racing (track) is 4500-7000 or so....unless you need 2nd gear, then it would be 7400 (redline)... It looks like I will use 3-4-5 (maybe) at my home track, Thunderhill in Willows CA...I think 2nd is a bit too low, since the slowest corners are 40-45mph, and followed by turns...so you would have to short shift, or redline shift at the apex (not a good idea) My current race car performs quite well, due to its high low end torque.....it provides a significant advantage getting off the corners.... |
#12 | |
#13 | |
| The Following User Says Thank You to Jason@Nameless For This Useful Post: | civicdrivr (06-20-2012) |
#14 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I vote for:
1) Keeping a primary cat 2) A metal heatshield for a more "OEM " look (so upon a brief inspection it doesn't look "modified") As far as flow designs - I would test the current design vs. the torque biasing. |
| The Following 4 Users Say Thank You to uspspro For This Useful Post: |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
